Small Pannier Recommendations?
Old. Slow. Happy.
Quoted: 5 Post(s)
I need something for commuting 2-3x week. Tubus Cosmo rear rack, and I'll be carrying a change of clothes, shoes, and lunch (in addition to the usual flat/repair items).
Here's what I'm considering:
Any obvious winners/losers in that lsit?
ah.... sure.
Bikes: Specialized.... schwinn..... enough to fill my needs..
Don't forget Orlieb Front Rollers. They work great on the back as well. Nice size for 90% of most my commuting needs.
Pacific Outdoor makes some nice looking stuff along the same lines as ortlieb. Worth looking at.......
https://pacoutdoor.com/bike-gear
my partner and I each have a par of Lone Peak -099 panniers.
they are a good size for a small load, have worn and worked well -
Leave a pair of shoes at work. Put your flat/repair stuff in a kit that fits under your saddle, or in one of your water bottle cages.
Then, you can get by using one pannier.
I use this: the Arkel Bug:
https://www.calhouncycle.com/productc...7&idcategory=0
Plenty of room for clothes + laptop + lunch.
Old. Slow. Happy.
Quoted: 5 Post(s)
I think I have it narrowed down to the following:
Comments/suggestions would be appreciated.
- Lone Peak P-099
- Lone Peak P-100
- Arkel B-26
Lone Peak packs are available in several colors, if that makes a difference, black, red and blue. If you want the Lone Peak packs, check with Wayne at TheTouringStore.com He also has a hybrid pack, the P-150, that is the same size as the P-100, but has the mesh outer pocket as the P-099. It's a little more expensive, but is also available in a special yellow/black color scheme that he has made arrangements to get from Lone Peak.
BE the Ferrari.
Bikes: Co-Motion Nor'wester Tour
I got a set of Axiom Kootenay panniers. Seem very well made. Going to use them for weekend tours this summer. They will fit front or back. I think they are very nice.
Quoted: 163 Post(s)
Lone Peak P099 is a lot lighter than Arkel T28 (I don't know the B 26). I'm quite satisfied with my p099's as front touring panniers, back credit card touring panniers, and around-town shopping panniers.
If you do get Lone Peaks, you need to specify the hook size, the Tubus racks use the bigger hook.
+1 for Wayne at thetouringstore.com
Quoted: 1182 Post(s)
Liked 833 Times
+2 for Wayne. IMO__ Waterproof panniers are more practical for commuting. We live in Oregon so my comment is probably biased. My wife uses the Ortlieb Front Packer Plus's for commututing. She also used the same set for an across the US trip. She is small and her gear does not take up too much room I have a pair of the Ortlieb Front Rollers , and while not using them for commuting, they are great for touring. I have a pair of older Nashbar waterproof front panniers that I use to beat around.
The Arkels are good .....a tad heavy but just about impossible to destroy.....should last you a good long time.
Cyril
Cyril
LCI #1853
Bikes: Trek Madone 5.2, Fisher Caliber 29er, Orbea Onix
For medium to light commuting, the Ortlieb Front Rollers or Back Rollers either one are really hard to beat. Size depends on just how much stuff you typically pack along, and they are very weather and dust-proof.
Old. Slow. Happy.
Quoted: 5 Post(s)
Absolute waterproof-ness isn't a must-have for me (due to local weather and the use of stuff sacks). The lighter-weight Lone Peaks might just be the way to go.
Soma Lover
Bikes: one bike for every day of the week
I don't know about 33 liters for commuting. Sounds like overkill to me.
I live in Utah, ride mostly dry roads on a road-ish bike with a lightweight rack, and get by with less than 20 liters.
I swap back and forth between some Nashbar Daytrekkers at 13 liters and Delta Compacts at 16 liters. Tools are wrapped up burrito style in waterproofed cotton duck and secured with mini bungees to the top of the rack. The only thing I'm leaving out is the shoes.
I don't do extended tours as I can't get time enough off from work. I pack light, like a legit hiker/backpacker does, and I find my Axiom Mackenzies at 36 liters are more than sufficient for 2-3 night camping excursions when combined with a handlebar bag. The tent, pad, and sleeping bag are secured to the top of the rack.
Bikes: 2007 ICE Trice T; 2008 Brompton M6L; 2009 Surly LHT; 2010 Surly Cross Check
The little pocket that Ortlieb happily includes in most of their bags now is really nice to have for papers, a book, stuff like that, and also has a zippered compartment for all the loose, small doo-dads that would normally filter to the bottom of the bag.
Bikes: Co-Motion Americano - LBS Build, 90something Fuji Sunfire hybrid
I use my Carradice Super C Universals pretty much the way you describe and have been very happy with them. If I leave the work shoes at work I only carry one pannier. I avoid commuting in heavy rain, if you don't then I guess the Ortliebs might be a better choice, but really I've yet to have a problem with my stuff getting wet in the Carradice bags.
Quoted: 137 Post(s)
Liked 81 Times
The Super Cs can be waxed to prevent them from getting wet in heavy heavy rain. The material is very strong and i can see mine lasting a life time....
Old. Slow. Happy.
Quoted: 5 Post(s)
I've got it narrowed down to:
Since my frame has been delayed again, I've got a little more time to figure out which ones I should get.
- Ortlieb Sport Packer Plus
- Lone Peak P-099
- Lone Peak P-100
- Lone Peak P-150
- Arkel B-26
blujosh
Commuting
6
02-01-13 04:01 PM
