OU Interval question
sittin' in
In Carmichaels book he has a Over/Under Interval workout described as: 3x9 minute OU (2 under, 1 over) 6 minute RBI.
I get that the "unders" are done at SS intensity and the "overs" are done at CR (climbing repeats) but I am having a hard time understanding how this interval is structured. Am I correct in assuming you would do 6 minutes at SS then immediately ramp to CR intensity for 3 minutes before resting for 6 minutes (repeat 3 times)?
It gets even more confusing when another workout calls for 3x10 min OU (3U,2O) (6 min RBI). How is this even possible when every OU interval is supposed to end on a "over".
Thanks for any clarification you can offer.
3x9 OU (2 under, 1 over) 6 min. RBI (Rest Between Sets) would look like: 4 min. SS followed by 1 min. CR followed by 4 min. SS. That is 1 set. Rest for 6 min. do another set. Rest for 6 min. Do another set for a total of 3 sets.
3x10 min (3U, 2O) (6 min RBI) would look like: 2min. SS, 2min. CR, 2min. SS, 2min. CR, 2min. SS=1 Set. Rest 6 min. Set 2. Rest 6 min. Set 3.
I read the book but decided not to follow it. But I believe the workouts should go like that.
I'm guessing that the 2 under, 1 over refers to the time at the under/over pace, not the number of intervals at the pace, so:
3x9OU(2U, 1O) would be: 2 minutes under, 1 minute over, 2 minutes under, 1 minute over, 2 minutes under, 1 minute over, rest 6 minutes - repeat two more times.
Your second set would be:
3 x 10min (3u, 2 o) would be: 3 minutes under, 2 minutes over, 3 minutes under, 2 minutes over, rest 6 minutes, repeat 2 more times.
(It's possible that the set would start at the over interval, because I'm not sure how much sense it makes to start with the steady state).
sittin' in
I haven't read the book, but this doesn't sound right to me. (way too few work intervals in the first set).
Bikes: 2 cdale Caad7. Scatantte CX/winter bike. SS commuter.
might be possible to do this with 2 other teammates on a flat course, each rider taking 1 minute pulls and sitting in for 2 minutes @ SS.
