First Time Racer: Crit or Circuit?
SLO-1
Bikes: '09 BMC Road Racer SL01
What would you guys (or gals) recommend for a first time racer. They're holding an event here next month with a Circuit (3.4 mile) followed by a TT then a Crit the following day. I have group ride experience but no racing experience. Am I assuming properly that a circuit should be safer than a crit to get my feet wet racing? Both would be strictly Cat5 fields, not cat4/5.
Do all of them.
Circuit races (usually) means less corners, so for pack handling skills it's less tricky. However, since it's hard to hold a meandering line (think of a pack riding around a kidney shaped lake), circuit races can get a bit iffy. Look at my helmet cam clips on Nutmeg State Games - I mention the side to side "scrunches" where riders kinda sorta conveniently forget there are guys to their inside on meandering bends.
Crits, you have to do them sometime. Usually you'll have real turns, i.e. 90 degree, so you have to follow a somewhat concrete line through the turn (i.e. you follow the others). You'll experience the easing before turns, the turn, and the acceleration out of them. I think they're safer in general than circuit races because you can kinda predict if someone's gonna eat it. In circuit races when crashes happen they happen suddenly and out of the blue. In crits you see a guy going into a turn really hot and you think, "Oh jeez.." Not as surprising, a little more predictable.
The TT is nice too. You can work hard for yourself and get some idea of how hard you can go. This is especially good after your induction into racing with the circuit race. Usually the peak speeds in a mass start race are a bit higher than expected. Armed with that knowledge you'll push yourself harder in the TT.
Sounds like a great schedule. Have fun at the event.
cdr
cdr
Elite Fred
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 42 Times
As a Cat 5 I would skip the TT unless you want to become a TT specialist and want the experience. You pay $'s to enter the TT and don't get anything toward your upgrade with a TT.
Do the crit and the circuit. Lots of folks think that road races are safer than crits/circuits, but my experience is that there are a lot more crashes in road races and the crashes are worse. It isn't logical, but that is my experience.
I'd say do the circuit and the crit, but if you must choose, do the crit. Even if you have the fitness to do well, it's not uncommon to get dropped in a circuit race (if it's hilly), which can be discouraging. But I am biased, as I love crits and dread RR's like the plague.
cycle-dog spot
Bikes: Look, Niner, Ellsworth, Norco, Litespeed
Assuming you are going to stay on, go for the circuit. Especially if you are concerned about turns, etc...
Things just happen much slower in a circuit race.
-Z
-Z
Making a kilometer blurry
The circuit won't be any safer than the crit. I think I've seen more crashes in RRs than crits that I've been in. Often the crit crashes are slower because it's in a corner anyway. In a road race, it's often a horrible 35mph downhill jitterbug causing the whole thing.
Race them both and don't sweat the crashing.
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
I'm with cdr, why not do them all?
Is it an omnium, where you can choose to not do one/two of the events, or are you locked into all three?
Bikes: 1982 Trek 710; 2008 Cannondale F6
Do both. I agree with cdr and waterrockets about safety: circuit races are no safer than crits. If anything, it's the other way around. I think that crits are reputed to be dangerous because everyone is on "high alert" the entire time. In road races, people zone out or lose focus for a second, and can cause really dangerous situations as a result. The worst crash in any race that I've ever been in was caused by something like that; the guy next to me just wasn't focused and holding on firmly while the pack was descending at ~35 mph or so, maybe a bit slower. He hit a bump from a water or gas connection embedded in the pavement and lost his grip on the bars. He basically did a face plant, then half of the field plowed into him, with the result being a massive TdF-style crash that spread across the entire road and took down probably 15+ riders (I just missed going down, his wheel hit my bike). It was horrible to behold. That just doesn't happen in crits.
pan y agua
Quoted: 1441 Post(s)
Liked 710 Times
I'm assuming you're referring to the Sunrise Classic, and I agree with others; do both.
Haven't done that race before, but looking at the flyer, it looks like the Circuit Race on Saturday is almost a crit anyway, given that your race will 40 minutes plus 2 laps.
My bet is the "circuit" is likely jus slight longer than a typical crit course, and they are choosing to call it a circuit race because they don't want to market a race weekend with 2 crits.
The Sunday cirt sounds like it might be a bit more technical from the description. But by Sunday, you'll have the benefit of Saturday's experience.!
You could get lost and die.
You could hit a tree and die.
SLO-1
Thanks for all the advice. Funny how when you have no experience you can get the wrong idea about things. By description, the circuit would seem safer than the crit. Everyones right though, I'm just going to register for all 3 to get a feeling for different races.
cdr: I watched the videos and see exactly what you mean. Position seems to be very important in the circuit around the soft bends. As for the crit, my entire understanding of crits come from your videos.
Merlin: Yes, it's the Sunrise Classic. It seems like the perfect event to get my feet wet. The circuit is supposed to be 3.4 miles long, not all that big and I'm assuming it goes around the bank atlantic center. They didn't post any info on the crit apart from "fast and technical" and I also didn't see any info on the TT distance. Will you be coming down for this race or is it not something on most Florida racer's schedules?
pan y agua
Liked 710 Times
It's a Florida Points Series Race, so you'll get people from all over the state. Not sure how much turn out you'll get from NE Fl just because of the drive. I may go, not sure if I can fit it in the family schedule yet.
SLO-1
Oh OK. It would be cool to meet some BFers out there
Anyway, corners in crits are a bit different when you ease a bit, go through the turn, then accelerate. My Plainville clips has some stuff like that, Hartford a bit too.
have fun at the races,
cdr
Primate
Bikes: Concorde Columbus SL, Rocky Mountain Edge, Sparta stadfiets
Liked 5 Times
I've done hilly, winding courses that were called crits, And rectangular two-block courses advertised as circuits.
The designation seemed to have little to do with the course geometry.
Marketing?
Marketing?
Biggest difference racing wise is that crits can have free laps. Circuit races don't.
Now I'm waiting for a correction.
cdr
pan y agua
Liked 710 Times
2010 rulebook says Circuit course should be at least 5km, and a Crit course should be 800 meters to 5km.
Around here, it seems that Promoters are pretty loose using the term "Circuit Race". For example the Winter Garden circuit race was well short of 5km, and they ran it with a free lap rule, but called it a Cirucit race.
SLO-1
Registered for all 3 events, baptism by fire. Figured if I did it early, I can't back out. Now I'm going to have a looooong wait for April 10th.
slow up hills
Bikes: Giant TCR, Redline CX, Ritchey Breakaway, Spec S-works epic
2 things:
1) crits and circuit races count for the same number of points, so who cares what you call them and
2) My new favorite set of photos, and a link I will post every time someone claims RR/circuits are safer than crits. Thanks to whoever put this in the race report thread (and thank god I was out of town for this race):
https://hcphoto.smugmug.com/DBC-My-Ho...4_G4KXX/Medium
Criterium Coach
Bikes: Klein
Do the criterium!
I would suggest doing the crit. Criteriums are a great way to experience the thrill of riding in a pack and corning shoulder to shoulder at speed.
I have a lot of information about how to race a crit at https://criteriumcoaching.com.
I would suggest you read: https://criteriumcoaching.com/2010/02...st-critierium/
Steve
Steve
Bikes: 2000 Cannondale CAAD3 Triple 105/Ultegra
Do them both.
My personal belief is that Crits are safer than RR. RR tend to be slower, people bunch up more, yellow line rule is in effect and people are trying to get through. Crits are faster, can be on wider roads, often more strung out, so (not counting corners), and thus, IMO, are safer.
My crit accidents have resulted in road rash mostly (sliding out). My RR accidents, well the bad one, I'm still recovering from.
