Dc to dc
Dc to dc
Hello
i have a electric Nike with a 48v battery and i was thinking to build an electronuc device to convert the 48v to several output, as an example a 12vdc to charge aa batteries and a 5vdc (USB) to' charge the iPod
is there an easy way or something already built outside?
Thanks
Thanks
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
A friend of mine runs several things including a pair of MagicShine lightheads off his eBike's 48 volt pack. He built the regulators himself using National Semiconductors "Simple Switcher" chips. They have a website where you can type in the input and output voltage, required current, amount of board space you will allow it to take up, and the desired efficiency, and it'll pretty much design the thing for you.
Work: the 8 hours that separates bike rides.
Quoted: 1855 Post(s)
Liked 664 Times
Bikes: '07 Giant OCR3
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
Yes, you do NOT want to use a linear regulator for this application. You'll be throwing away almost all of the power used, and many linear regulators can't even handle this level of drop. If you want 500 mA charge current at 5 volts off a 48 volt feed, the linear regulator would have to be able to dump (48-5)*500mA = 21.5 watts of heat. That's a WHOLE LOT of heat. You're talking a fist sized heatsink getting too hot to touch. And the efficiency at best can't be better than 5/48= 10%. 90% of the energy will just be dumped as heat.
I doubt most off-the-shelf linear regulators could even dump this much heat without cooking themselves.
A switcher wouldn't be that much harder to build, and could easily be 90% efficient. Buck regulators are dirt simple.
Keep in mind though, if your USB device is "well mannered" it won't draw more than 50mA, and in fact will probably refuse to charge if you just put power on the USB. You need to have a chip on board to "talk" with the device and tell it it's OK to pull more current and begin to charge.
The easiest and best thing to do might be to get a 12V to USB adaptor that you know works - it will already have the USB chip built in, and you can get these for $5. Then all you need to do is to get the voltage down to somewhere in the 8 to 15 volt range; those adaptors already have regulation built in and are designed to take a range of voltages from a car. THEY are not likely to be very efficient, but they'll be more like 40% efficient, which is a damn sight better than 10%.
You'd still want to build a switcher to feed that device though, or you'd be introducing a 25% efficient part in before you even got to the final regulation stage.
Besides, having a 90+% efficient regulator that can deliver a couple of amps at 12 volts from your battery will be useful for many other things.
Quoted: 9 Post(s)
Sorry, my brain was thinking 12v source when I typed linear, scratch that idea.
I was able to a few years ago get a sample of a powertrends, I was using their 8-18v in to get 12v out for a car computer.
Quoted: 9 Post(s)
Liked 664 Times
If I was designing this for work I'd use a push-pull or full-bridge buck driving a step-down transformer, regulate it, then use LDO linear regulators on the lower current windings.
Might use a SEPIC instead of a buck, but the transformers are fully custom.
jasonhall
Electric Bikes
2
10-06-17 02:56 PM
Monsoon
Electric Bikes
23
08-03-13 09:38 PM
crotch_rocket
Electric Bikes
9
06-16-11 04:15 PM
