will these forks fit my bike
i got some 2001 rock shox boxxers as a present but im not sure they will fit on my bike. i right now i have judy sl u turns on my bike and is there any why to get the boxxers thru axle to fit in my current quick release hubs?
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Bikes: Lots
First of all, the fork should fit your frame. The question you have to ask is, "Is this fork appropriate for my bike?". The answer to that is, "No".
The reason, your frame was designed to work within a small range of travel for the suspension fork. Moving outside that range will greatly affect the geometry of your bike. You may or may not like it. However, it CAN be done.
Also realize that your frame was not designed to withstand the forces applied to the headtube/top tube/bottom tube intersection and this may become a point of failure of the frame.
However, a free fork is a free fork. I wouldn't advise it, but go ahead if you want.
I will add that I've seen a lot of people put triple clamp fork on bikes not designed for them and have ridden them for years without incident. I've also seen frames fail in 1 month of riding.
Your other question regarding converting a standard hub to a 20mm through axle. Can't be done, you need a new hub/wheel with a 20mm hub.
There are some hubs that have converters to allow a 20mm hub to be used as a standard hub, but not the other way around.
L8R
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
Originally Posted by hooligan
Will a shred or a stuff be able to handle a boxxer? If it does not or if it does, can you list a few bikes that CAN? Namely in the brands of mountain cycle, kona and marin.
I wouldn't say much from marin could...
Mountain cycle rumble should but check the warranty to be sure.
Bikes: Lots
get a Banshee or a Morphine!
L8R
L8R
