2" reciever for a truck step bumper: will this work?
fareless square
Bikes: crabon
Hi,
I drive a Ford Ranger pickup with a topper. I'd like to be able to transport two bikes to the trailhead using a 2" receiver rack...but I lack the receiver / hitch.
Hitches are expensive, so I was wondering: would this thing work? Though intended for ATVs, It fits the ball hitch hole on the step bumper of my truck:
Any risks? It's definitely beefy enough to hold the relatively light weight of two bikes and the rack itself (70-80lbs, I'm guessing), but do you think the leverage of the rack and bikes would allow it to sway-- possibly working the nut loose?
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
I might trust it with a Huffy, but I sure wouldn't with a Madone. I know my rack has a longer insert that would hit the bolt head. What you want is a step bumper receiver.
https://www.northerntool.com/shop/too...&ci_sku=330681
Quoted: 8 Post(s)
I think it would work fine. Just keep the mounting bolt tight . After you install rack & bikes, you may want to use a " bungee cord " at the outside wheel of a bike & attach it to somewhere on the frame or bumper. Without the cords , some of these racks wobble & rattle a lot & are distracting .
I would not use this to pull anything larger than a small utility trailer, though. Remember, you are still only pulling with your bumper.
Quoted: 1572 Post(s)
Liked 643 Times
My question is: Will your rack slide in far enough to fit the retaining pin through the hole? If not that would be a deal breaker for me.
If your rack will anchor in the receiver, I'm thinking that the torque spec for the receiver mounting bolt is around 140 lb/ft. That's a bunch! Grease up the threads, use a lock washer and tighten that nut as much as you can with a 15" crescent wrench.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
I would probably go with something like this.
https://www.sjdiscounttools.com/16165.html
I trust 4 bolts more than one, but your going to need premium drill bits to drill through you step bumper. I welded a reciever to the back of my dirt bike trailer so I could take pedal and motor powered bikes with me camping and it has held fine from Tejas to Moab and up to Mena Arkansas a couple times.
fareless square
Bikes: crabon
yeah, I figured I'd kill a few drill bits trying to get through the chrome and all that. I ended up picking up a 2" class III hitch off craigslist for $35. now I can use any old 2" rack!
had to use a breaker bar on my bumper bolts to get it mounted, though. luckily Harbor Freight had a serviceable one for $9!
New Daddy
Recreational & Family
18
11-08-14 01:54 AM
garysol1
General Cycling Discussion
6
10-07-14 08:55 AM
