Stem Help
Old 04-06-10, 12:30 PM
xavier853's Avatar
Bikes: Pegueot UO8, Tommaso Augusta
Stem Help
I am in the middle of my current bike build and it is now time to order a stem!
I am particularly drawn towards the Velo Orange stem here. I like the look and the polished silver.
I like the 17 degree stem so that it will be parallel to the ground when on the bike, but I want to use Nitto b123's and they are 25.4mm. The stem is 26mm
My question is should I by this stem and a shim, or are there any VERY SIMILAR classy looking stems with a 25.4mm clamp?
xavier853 is offline
Old 04-06-10, 12:40 PM
Veteran Racer
TejanoTrackie's Avatar
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times in 431 Posts
I use a Nitto B125 bar with a 31.8mm stem and shims w/o any problems, so you can certainly do the same with a 26mm stem. I am only aware of quill stems that fit 25.4mm bars.
TejanoTrackie is offline
Old 04-06-10, 12:47 PM
xavier853's Avatar
Velo Orange also makes a 25.4mm threadless stem but it is a 6 degree.
Old 04-06-10, 04:00 PM
I have a cannondale stem that I bought from the bike shop used and it is threadless and 25.4mm.
Atleast, that's what it says on the specs that are printed on the stem itself.
I always thought that my bars were 26mm though...
Thrahl is offline
Old 04-06-10, 04:18 PM
Deshi's Avatar
Bikes: 1990 Waterford Paramount, 1986 Pinarello Pista 195? Raleigh 3sp, 2001 Surly 1x1, 2014 Canfield N9, 2015 Canfield Balance, 2013 Rocky Mtn Flatline, 2012 Intense SS2, 2014 Transition Klunker, + more!
Iv used a 25.4mm flat bar in a 26mm stem with a strip of GoFast Energy drink can and never experienced any slip. Id say just use a pop can as a shim an do it.
Deshi is offline
Old 04-06-10, 05:09 PM
Don't fear the shim. I am using the VO 17 degree stem with nitto b125's and a nitto shim and haven't had any problems.
Derreck is offline
Old 04-06-10, 05:25 PM
Get on your bikes & ride!
xB_Nutt's Avatar
Bikes: See signature (it varys day to day)
Ditto, although my stem is a Nitto. The good thing about going this route is that you can put 26mm bars on there some day.
Litespeed Classic
Soma Double Cross DC
xB_Nutt is offline
Old 04-06-10, 07:18 PM
xavier853's Avatar
Ok thanks for the tips. I'll order the 17 degree Velo Orange stem tomorrow. Yes, the shim was making me a little worried, but your comments are reassuring.
max5480
Classic & Vintage
27
11-20-21 04:32 AM
Wafa
Bicycle Mechanics
1
06-19-17 12:36 AM
Blackguyrides
Singlespeed & Fixed Gear
10
09-08-11 11:16 AM
Psychkle
10
11-11-10 03:47 PM
Charbon
Hybrid Bicycles
2
04-03-10 10:47 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
