need bar help
need bar help
can a 25.4 bar work reasonably well with a 26 stem?
I'm looking for some riser bars and I have come to a dead end. I like the width at around 470mm, but my only problem is I can't tell from pictures online if oury grips and a lever will be sloping on the inside of the bars when cut to that width. Neither of the LBS's have anything I can really compare either.
I'm deciding on either a pair of cheap eastons I found or just some generic alloy bars on e-bay.
https://www.pricepoint.com/detail/195...p=195%20EASE38
https://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
Pedantic Antics
Bikes: 1 30-speed Ultegra Road, 1 43/16 Fixed, 1 47/15 Fixed, 1 Converted Beach Cruiser to Pennyfakething
They make shims, or you can use some old bike tube.
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Or you can buy a proper shim made of a less-malleable material less for $15 or less.
https://harriscyclery.net/product/nit...o-26.0-417.htm
Many bike shops have them in stock.
Bikes: klein quantum, litespeed tuscany, bianchi pista concept, centurion comp ta, centurion super le mans, traitor ringleader
you wont get any hipster cred points with those though
*SARCASM*
*SARCASM*
i used a tecate can on mine. -2 hipster points
but it matches the color of some components!
Pedantic Antics
alright perfect, I'll either order those shims or locate the nearest can.
But I'm still not sure which bars, I want the grips and lever to be straight with a width of about 470
edit:
any input on the easton bars? or a suggestion for some chrome ones?
edit:
Quoted: 7 Post(s)
get something with more rise and make sure it has a good few degrees of sweep.
I like the B-Witch (Japanese) branded bars, they are 25.4mm and come in many colours and are cheap!!
Bikes: Two unicycles duct taped together
Quoted: 8 Post(s)
+1 on sweep. I used to run straight bars with 0 deg of sweep and my wrists were killing me. Now I run Velo-Orange Milan bars.
Also, look in universal cycles. They have a lot of steel/aluminum silver ones. Not chrome, but they look nice enough.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
canali
Road Cycling
3
09-14-10 04:50 PM
