Shimano A050 Shifters
Old 05-02-10, 07:54 PM
Hey, I'm changing my Diamondback Insight I to have drop handlebars, and I was planning on purchasing Shimano A050 thumb shifters. I would like to know if they can work with 21 speed bicycles. If not, does anyone know any thumb or stem mounted shifters that would? I cannot use integrated brakes/shifters because the bike uses V-brakes, and I can only find one set of drop brake levers that work with long-pull breaks. Thank you for your help!
madrista1 is offline
Old 05-02-10, 08:57 PM
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1242 Post(s)
Liked 94 Times in 65 Posts
They sound like they'll work just fine.
FYI, if you really wanted to use integrated shifters, you have two options. First, you could install Travel Agents to correct the cable pull allowing you to use your current brakes with the road shifters. Second, you could install cantilever or mini-V style brakes in place of your v-brakes. Either of those brakes is compatible with the road shifters and will mount directly to your frame's mounting bosses.
joejack951 is offline
DorkDisk
Mountain Biking
4
10-06-14 12:25 PM
toshko321
Road Cycling
6
03-06-14 10:15 AM
HardyWeinberg
Bicycle Mechanics
2
04-24-13 04:16 PM
Ancient Mariner
Bicycle Mechanics
11
02-14-13 01:17 PM
hopefulnewrider
Bicycle Mechanics
11
01-11-13 04:42 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
