Just switched to clipless - getting some knee pain - thoughts?
Clyde - Grinder
Bikes: 2009 Jamis Aurora Elite - 2007 Specialized Hardrock
I had been dialed in on my bike with power grips. Made the switch to clipless a few weeks ago and have been getting pain in the top of my knee, more to the inside of each leg, and worse on the left than the right. Pain didn't really get worse over a 100 mile ride this past weekend, just constant annoyance. Thoughts?
Thanks!
Thanks!
Clyde - Grinder
SPD M-520 pedals and to my knowledge the cleats have 4 degrees of float.
Bikes: 2012 Scott CR1 Comp
That kind of pain I got because my q-factor (distance between my feet, basically) was too narrow. This was rectified by 3mm worth of washers on my left pedal spindle to move the foot out a bit to get under the knee. the amount and side of extension will depend on your anatomy. There are such things as kneesavers, but they are 2cm long, which is too much extension for me.
Another possibility is that your knees do not like the float, or they require more float than spd's can provide. No easy way to test that out, however.
Bikes: 2006 Raleigh Mojave 2008 Specialized Roubaix Elite
i has the same trouble- i switched from spd to crank brothers candy's which have more float
i also put a washer on my left pedal- 3000 miles later no problems
Thanks!
Thanks!
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
Also, remember, the saddle height relative to the pedals will be different with the clipless pedals. Try bumping the saddle up a few mm or so. Mark your current positio0n on the seatpost with a sharpie, though for easy reset if that's not the case.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Pain on the top of the knee is a sign of a saddle too low. Your feet may be a few mm higher with the clipless as opposed to the flats/Power Grips.
Clyde - Grinder
Clyde - Grinder
Quoted: 11 Post(s)
I find myself adjusting the saddle with new cleats (Look delta).
I got 99 problems....
Location: Does anyone know where the love of God goes, when the waves turn the minutes to hours?
When I first switched to clipless, I had knee pain on my left knee only. It never bothered me with platforms. I found that my knee was moving laterally, maybe 1.5" at the top of the pedal stroke. (Mine would push out right as I began the downstroke). I never knew it was even happening until I looked for it.
Watch your knees at the top of the stroke. If they are moving laterally at all, that will cause pain. I used the Bikefit.com wedges between my cleats and and shoes, and it fixed me right up. They eliminated the lateral movement and stopped the pain instantly.
The other suggestions may be correct also, this was just my experience when I first switched to clipless.
Quoted: 18883 Post(s)
Liked 10,646 Times
If that doesn't work, get someone to follow you while you bike. I'll volunteer if no one else will - we seem to be in the same area. I went clipless because my clips started causing knee pain, and the clipless system has made it go away completely. But the pain itself doesn't sound similar, so I'm probably wrong. Still, my guess is the cleat needs to move a little bit, and is probably causing you to pedal wrong, so that you're making an oval instead of a circle, and putting too much pressure on part of your knee at one point in the stroke.
WestCoastDan
Road Cycling
4
10-09-11 06:34 PM
