Shimano approves radial lacing.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
Yes, shimano says you may lace their hubs radially.
However, only on select hubs.
What's interesting is that a few older models are listed as okay.
If you can find a link to techdoc SI-WH001-006, then props to you.
warning: big images
first image has english in the top left corner.
warning: big images
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
MARGINALS
Bikes: 09 Tarmac Pro SL / Sunday BMX /
Yeah, only some are approved.
There is an older tech doc floating around that approves some older hubs. I happen to have a front 5501 hub which is approved but the regular 5500 is not. Its strange because they look identical except for the different logo.
My shimano R540's are radial laced and they're a few years old... or are they considered a different kind of lacing because the spoke nipples are on the hub?
Edit: actually they might not be as old as I thought... but I bought them used.
A little North of Hell
Quoted: 71 Post(s)
https://techdocs.shimano.com/media/te...9830611787.pdf
Edit-
Aero hub.
https://bike.shimano.com.sg/publish/c...e-hb_road.html
Edit-
Aero hub.
Liked 5 Times
Is there one available from, say, 2006 or so? That way we could check if the front hubs from that time frame - like the HB-6600 - were approved for radial lacing. Note that in the 2003 document, the HB-6500 is approved for radial lacing, and in the 2009 document the HB-6700 is approved.
Liked 5 Times
HB-6500-A and HB-5501-A
the A might be for Aero or something.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
The hubs are approved for radial lacing because the hub is made differently. The hub flange is much thicker for the radial version of the same hub vs the non radial approved version.
