Tires for our touring tandem
flypaca
Hi, Just a quick question about tires we ride a lot of dirt(improved) roads and have a chance to pick up a pair of Continental touring + tires. Anyone with experiece with them? Enjoy the forum and for a person riding c+v tandems it's been very enlighting.
Thanks for the replies.
Peter
Peter
Tandem Vincitur
Bikes: BMC Pro Machine SLC01, Specialized Globe, Burley Rock 'N Roll tandem, Calfee Dragonfly tandem.
So, this is what you are using? In 28 mm?
Continental Touring Plus Reflex (700c)
Originally Posted by Bike Tires Direct
When conditions are at their worst and only maximum puncture protection will do Continental PLUS breaker is the reliable answer. The PLUS breaker utilizes an extra-duty, highly elastic casing belt that is virtually impervious to road hazards. What this means is you get a lively feeling tire with out all the extra weight of a tire liner but the added protection to get you where you want to be. Smooth center for low rolling resistance and a more pronounced side tread for water dispersion and extra grip in the rough stuff. Also features a reflective sidewall stripe for added visibility in low light conditions. Wire Bead. 700c (622 ISO) Sizes.
flypaca
Not so much the 28s but the 35s. Our improved roads are almost like fire roads and require more cushion than a narrower. Used to have the old orange michelin 35s but they got too old and gave up . The walk is never pleasant. The closest paved road is 5 miles away. and its not fun sometimes.
Peter
Peter
I am running a pair of Continental Touring Plus Reflex tires on my Trek Multitrack. I weigh 180 and usually have a big bag on the bag averaging about 25 extra pounds. I have been running the Touring Plus Reflex tires now for almost a year. About 1500 miles. No flats so far. Use them on asphalt paved MUPS and gravel trails. Have run them over coarse rock parking lots. No traction issues and low rolling resistance. I run them at 65 psi normally. So far them have given good handling on any surface I had them on.
I am running the Conti TravelContact Reflex tires on the wife's hybrid. Those also have been free of flat problems and have been good on any surfaces we have been on.
You might want to download the Continental catalog off the Internet. They list several sizes for these tires but it becomes a question of what my local LBS can get.
My Conti's replaced a pair of bontrager Hard Case 700 x 35c tires. The Hard case tires had very high rolling resistance.
flypaca
A big thanks to all who responded. I had heard good things about that tire and had a chance to get them locally. Not a lot of selection from the LBS. Small towns don't offer quite the selection of larger places or the web. But I like to shop locally if possible. No micheliens were avail. FWIW the micheleins that quit had about 3000mi and almost 30 yrs (with a long layoff).
Peter
Peter
Peter
Peter
Now of course this would mean paying list price. No bargain prices. So I downloaded the Conti catalog and read up on what each tire's specs are. Then told him what I wanted. Matched rim size off the rims ID labels to what I was looking at in the catalog. Then ordered them. Most of the time I had a week, or less, waiting until the tires came into his shop. It depends on where he has to order them from.
Did the same thing with lights I wanted for the bikes.
For clothing needs we use an LBS near the MUP we normally do day rides on.
Bikes: Co-Motion Mocha, Trek T100, Schwinn Fastback Comp, Specialized Stumpjumper
We have been running on 26x1.5 Sshwalbe Marathon Racer, got good use out of it, until last week when the rear tire blew out, with about 6000 km (4000 miles), not sure what that would translate to (700c x 32 or 700 x 35). Did plenty of dirt roads on this tire, but on coarse gravel it turned out to be a little narrow. Our next touring tire for Patagonia roads will be another Schwalbe Marathon, but 26 x 1.9.
40 yrs bike touring
Bikes: Bruce Gordon Ti Rock N Road [1989], Fat Chance Mountain Tandem [1988], Velo Orange Neutrino (2020)
Quoted: 14 Post(s)
Liked 6 Times
We have been using Conti Top Touring 26x1.75 [47mm] on our Fat Chance Mtn Tandem for the last three years with no problems except in really loose and rocky uphills due to the limited tread. Lots of air volume for us clydesdales yet not too heavy. On the road they roll well and just will not wear out.
