Home-brewed Belt-drive system [research stages]
I've recently been looking into the Gates belt-drive system. (Mostly out of intellectual curiosity since i probably won't be able to afford it.) The first thing I noticed is that it looks strikingly similar to a to a timing belt system on a car, or any number of industrial applications.
After finding the specs (tooth count/pitch for belts and pulleys) on the Gates/carbondrivesystems website,
https://carbondrivesystems.com/cd_specs.php?lang=us, I decided to check my favorite online "hardware" store https://mcmaster.com. It turns out they have belts and pulley in similar sizes (tooth counts and dimensions) to many of the ones produced by Gates. They even have carbon reinforced belts of the same tooth count and pitch (8mm) which is used widely in the automotive world. This got me thinking... how hard would it be to adapt a 50tooth cam gear onto a crank. I would wager that the two below could be adapted to a crank rather easily with minor machine work (milling, drillling/tapping), by the looks of the you could even choose your own offset for correct chain-line (belt-line?)
The rear gear/pulley may not be as easy to source, ( at least one that will fit with minimal modifications) However, it shouldn't be hard to find one with the correct tooth count and pitch since 8mm pitch is pretty standard. I'm thinking a water pump pulley may be the ideal candidate. Here is a Honda timing belt picture, notice 4 different potential rear pulleys, and this is just one car.
Anyways, just wanted to share my recent brainstorming. I intend to go to the junkyard pretty soon and do some poking around and teeth counting. If i can do this for cheap enough I may just try it.
My only suggestion is to start from a disc hub and use the 6 bolt pattern to connect the rear pulley to the hub rather than going for the thread-on system, assuming you're talking fixed rather than freewheel.
Bikes: Felt AR1, Cervelo S2
Quoted: 17 Post(s)
Seems to me that the car parts would be way overbuilt for a bike, and a car belt possibly too stiff since it's designed to deal with the stress and heat of much higher RPM and tension and runtime
also you have to cut your seatstay.
Hiphopopotamus
Bikes: 90s GT Outpost, Windsor Clockwork
I have had passing thoughts of a belt driven bike, too. What are the advantages? Is it just quieter? I will definitely keep tabs on this thread, especially if you figure it out with a "minimal" cost!
Also, I think automotive belts would be ok as they are not hard to bend even when cold. However, the pulleys themselves may be overbuilt as far as weight is concerned. Please keep us posted!
Thanks for the input guys, I don't believe that the gear being over-engineered would be a problem. So long as the gears are fitted to the bike properly the only drawback would be they are slightly heavier than the Al ones that carbondrivesystems offers. The carbon reinforced belts at mcmaster.com are not automotive belts. If it is a problem, the gates belt could be used with the modified automotive pulleys with no problems since the tooth pitch and shape is the same.
The necessity of frame modification is a huge drawback for me, which may derail (no pun intended) the whole idea. I have been talking about making a bamboo bike with a friend of mine. Maybe it will be our test mule.
For $32 + the cost of welding this could be an option worth looking into (as far as cutting the seat stay)
K2ProFlex baby!
Location: My response would have been something along the lines of: "Does your bike have computer controlled suspension? Then shut your piehole, this baby is from the future!"
Bikes: to many to list
Quoted: 16 Post(s)
Liked 56 Times
it will be cheaper to buy one, you'll see.
You see, their morals, their code...it's a bad joke, dropped at the first sign of trouble. They're only as good as the world allows them to be. I'll show you. When the chips are down, these...These "civilized" people...they'll eat each other. See, I'm not a monster. I'm just ahead of the curve
Cool project. Good luck with it!
Now, for my real question,
can someone explain to me how a belt drive is different from a regular drivetrain besides the cog, belt or chain and chainring? Or is that it? Is the eccentric hub on that bike just for... belt tension? Or is there something I'm missing?
i'm also very confused why that bike has a cha... i mean, belt guard. aren't they squeaky clean?
Fresh Garbage
Goon
Bikes: Rocky Mountain RC30, Soma Sport Fixed
So, what's the downside to th belt drive? is it heavier? less efficient energy transfer?
What about those shaft driven bikes?
Chain is better than shaft driven bikes, but is belt driven superior in all ways? Are you, like shaft driven, unable to have anything but SS or internal shifting?
Well i am confident I can adapt a 50t cam gear into a front "chainring" for cheaper than ~$150 As long as I can find a rear gear to make work with minimal machining then I will be in business, and much cheaper than the ~$400 it will cost to buy the parts (not counting frame modification). Point is, if I can't do it for cheap i'm not going to do it, but you may be right.
A chain is really hard to beat, and the advantages of belt drive are few. It's slightly lighter, more durable, cleaner, quieter, and of comparable efficiency if it's a SS. BUT it can only be a SS or internally geared.
Goon
coasterbrakelockup
Bikes: surly steamroller w/coaster brake, electra single speed cruiser, specialized rockhopper commuter, no-name single speed folder, 700c ultimate wheel, 24" unicycle, specialized bmx lsd, single seat single speed huffy tandem, pink upsidedown parade bike
For most bike applications, though, they aren't better than a chain. Or at least the disadvantages (SS or IGH only, proprietary parts, etc) probably outweigh the benefits.
*some folding bike designs also wouldn't require a gap in the frame, if the rear isn't triangulated.
K2ProFlex baby!
Quoted: 16 Post(s)
Liked 56 Times
Please do count the frame and the modification. ;0)
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
find a frame with elevated chainstays
weld or braze one some horizontal dropouts to it.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Liked 5 Times
I think most manufacturers have that silly cutout because they're just retrofitting their existing frames with inferior cutouts for belts, instead of a proper frame that avoids the cutout all together.
