FD adjustment...3 positions, 2 chainrings
Old 06-11-10 | 11:55 AM
Faster than yesterday
I have Shimano 105 components (with the triple shifter) and a compact crankset. I am having issues adjusting the limit screws so that the FD will shift to the big ring without overshifting and dropping the chain. It seems it either doesn't quite reach, or it overshoots and I have to look at my chain and be careful when I shift. I already moved the FD clamp down a bit on the seat tube, because it was too high per the Park tool instructions. It just seems that to shift up, the FD has to travel too far outward. I've been losing my chain off the outside recently.
I am not sure how to deal with the three clicks of the shifter vs. the two chainrings. Should I tighten the H screw down enough that the shifter effectively has only two positions, i.e. the shifter will not be able to pull the FD out any further than the inner two positions? How is the shifter to chainring number mismatch usually handled?
tadawdy is offline
Reply
Old 06-11-10 | 01:40 PM
JTGraphics's Avatar
I have a setup like that 105 levers and 10 speed FD setup.
NOTE: 105 has a trim click that produces a short movement on first short movement of lever the second will move the FD again and move chain.
I removed cable make sure lever is all the way down to small ring push small lever right till it stops clicking with chain on small ring set limit screw just till the left inner side of FD clears chain about 1 mm clearance then with your fingers get chain on large ring push FD with your finger and set stop screw same but with clearance on right side this time.
Now put chain back on the small ring make sure lever is clicked all the way down again screw in (down) barrel adjusters and back out 1 turn so you have something to play with if needed, now pull cable tight and lock it down.
Take up slack with barrel adjuster try shifting lever should click and shift if no click the stop screw is not allowing the FD to move up enough turn stop screw 1/2 turn and try keep this up till it shifts and has a solid click.
Now shift down it should drop if you find it later dropping to far down and off small ring turn in stop screw 1/4 turn till it stops dropping, if you do this check cable slack 1/4 may not make a difference but more may so check it.
When done correctly you will also have a trim click before it moves chain to next ring with 105 levers.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
JTGraphics is offline
Reply
Old 06-11-10 | 02:22 PM
There have been some issues with the 10-speed 105 triple shifters when used with a double crankset. Specifically the shifter may bacome jammed if overshifted to the big ring. In some cases Shimano has replaced the left shifter with their new 105 double specific shifter. Try the search function for previous threads about this.
Al1943 is offline
Reply
Old 06-11-10 | 03:16 PM
JTGraphics's Avatar
Never had trouble here just remember when you are already on the big ring how hard is that?
Thats also why its important to get the shifter to click into the gear.
Reply
Sy Reene
Bicycle Mechanics
2
05-06-17 05:30 AM
soom
Road Cycling
12
01-30-16 06:51 PM
billyymc
Bicycle Mechanics
5
09-15-12 08:40 PM
zachsilvey
Bicycle Mechanics
3
10-10-10 12:25 AM
jb_alphamale
Bicycle Mechanics
8
07-19-10 08:21 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
