Mounting a rack on an extra-small frame
Old 06-11-10, 09:03 PM
n00b
Bikes: 1995 Nishiki Cascade
I'm attempting to mount a Topeak Explorer (mounts to seatstays, not to seatpost) on a size XS Giant Dash. This rack has 2 bent pieces of non-painted metal that protrude from under the front-end of the rack (see picture here).
I got the bottom of the rack mounted fine to the lower holes in the seatstays (near the hub).
The problem is with the upper part of the rack. The upper set of holes in the seatstays are blocked by the rear brake assembly. What's the best workaround here? I figure there must be some way attaching the 2 top mounting points to the seatpost, but maybe there's some better way? If I do go the seatpost route, is there some product available or should I just go to the hardware store and see what I can find?
Thanks.
Edit: Here's a picture of a giant dash 3. On this one, the upper seatstay holes are high enough, but on the extra-small frame I'm trying to work with, the holes are actually further down the stay than the brakes are.
Sam N is offline
Old 06-11-10, 09:19 PM
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1242 Post(s)
Liked 94 Times in 65 Posts
You can either bend the stays until you get them to line up with the holes or get one of these:
https://www.universalcycles.com/shopp...6&category=168
joejack951 is offline
Old 06-11-10, 09:29 PM
CACycling's Avatar
Bikes: 2009 Fuji Roubaix RC; 2011 Fuji Cross 2.0; '92 Diamond Back Ascent EX
Liked 16 Times in 12 Posts
Or take one of the silver pieces, sandwich it between the brake caliper and the frame, bend it up to meet the center of the rack and bolt it in place. The front support does little to carry the weight. The weight is carried by the legs.
CACycling is offline
Old 06-11-10, 09:33 PM
n00b
Does this replace the existing collar or go on in addition to it?
Giant's site says the seatpost is 30.9mm, but that product seems to only be available in 29.8mm, 31.8mm, and 34.9mm.
Sam N is offline
Old 06-12-10, 06:01 AM
joejack951's Avatar
It replaces the existing collar. Seatpost collars are spec'd by the outside diameter of the seat tube that they clamp around, not the seatpost size. Remove your current collar and measure the diameter of the seat tube. To convert from inches to millimeter, multiply the number by 25.4.
Old 06-14-10, 07:23 AM
Likes to Ride Far
Chris_W's Avatar
Bikes: road+, gravel, commuter/tourer, tandem, e-cargo, folder
Quoted: 37 Post(s)
Liked 12 Times in 11 Posts
If the seatpost is 30.9, then the outside diameter of the seat tube is almost certainly 34.9mm, but it would be better to measure to be sure.
Chris_W is offline
Old 06-14-10, 07:51 AM
TomT74's Avatar
Bikes: 2010 Windsor Tourist, 2004 Custom SWB Recumbent, Unicycle, and a pile of pieces
Bending the front supports works fine. Like this: https://s837.photobucket.com/albums/z...thpanniers.jpg
TomT74 is offline
Paul Barnard
Touring
44
07-02-19 01:22 PM
Wittyname
Commuting
7
10-13-16 12:41 PM
SGMongoose
Singlespeed & Fixed Gear
21
11-24-14 04:17 PM
Cheyou
Touring
10
01-16-12 02:43 PM
Mr Pink57
Commuting
12
10-06-11 07:57 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
