Clyde Friendly Chains
Bikes: 2016 Raleigh Merit 3
I'm in the market for a new MTB. At 6'2" 285# it is no small task deciding on what to buy. After going to various shops I have narrowed down my choices to: Motobecane Fantom ProSL, GF Cobia, or Giant Talon 29er 1.
I'm really leaning towards the Moto due to the amazing feature set for the price. I plan on buying the Park Tools AK-37 as well as a new chain for the bike. I tried doing some searches in the forums but can't say I had any luck finding chain recommendations.
So....what chains are you guys using? Also, what are your thoughts on SRAM Powerlink and clydes?
TIA
TIA
Bikes: Klein
I'm not sure why you would want to buy a new chain for a new bike, but my guess is that any chain that would fit the bike would be much stronger than necessary. Chains are very strong. I suspect the re-usable links are even stronger.
It seems the chain that comes with the Moto is junk. Sorry I didn't mention that in the first post.
https://www.mtbr.com/cat/drivetrain/c...49_110crx.aspx
I'd go with the SRAM PC-971. I've always had good luck with SRAM chains and their quick links.
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
I use the SRAM PC 51 ($20). In 5 years, never a chain broken or problem. BeforeI used Ultegra and 105 for 10 years, never a problem there either. I go for price unless I have a problem, never have.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Spin, don't mash. You should ride your bike, not wreck it.
Bicycle n00B
Bikes: None yet
I use an SRAM PowerLink (weight about 250 lbs atm), and no issues so far. I ride an 8-speed commuter (aka hybrid) from REI. Was using the SRAM chains with it, but just switched to a Shimano because of a better fit for the Shimano hub.
Fat Guy Rolling
Bikes: Bacchetta Agio, 80s Raleigh Record single-speed, Surly Big Dummy
I've only seen broken chains in the following conditions:
1) Fixie skidding
2) Worn out, unlubricated, and rusty
1) Fixie skidding
Bikes: only 8 or 9 at present.
I've broken several chains on my mtb, I'm a clyde and a grinder so they don't last many months.
but I switched to a Rohloff chain and it's the first chain that have lasted more than a season.
There are no real difference between Sram and Shimano chains if you ask me, they are not suited for mtb riding.
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
I have this chain on 2 of my bikes: My brevet/long-distance bike, and on my ss/fg bike. I've never had a problem with it on either one, and I stomp my way up some steep and long hills on the fixed gear.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
Quoted: 26 Post(s)
I have KMC DX-10SC chain. I bent a link couple of weeks ago due to my lousy shifting technique. First time I ever had a chain problem.
Bikes: Trek 830 Mountain Track Drop bar conversion
I now have a SRAM PC850 w/ Powerlink - got it for $17 at REI. I've had it on a few weeks. Not much of a track record to report on yet, but I assume it'll be fine. The chain that came stock on my Target Schwinn (chain brand unknown, maybe cheapest Shimano entry at best, but certainly no better than the SRAM) lasted me through over 3,000 miles of year-round all weather commuting and not always the best chain maintenance practices.
As others have said, chains are strong. I wouldn't worry.
Bikes: See Signature...
Quoted: 9 Post(s)
I have never had a chain break in my life, and as a kid we didn't ever oil our chains, and those were cheap walmart/Ames bikes.
I have always used SRAM chains, except my Sirrus came with a KMC, and I bought a KMC BMX chain for my SS MTB. I even put a SRAM powerlink on my Sirrus, so that I could remove the chain easier. It works fine on the KMC chain, too.
Proper maintanence will keep a chain running strong for many miles on the road, however offroad I would replace the chain more often. No matter how well you keep a mountain bike chain clean when your NOT riding it, when you ARE riding it there is dirt and grime and all sorts of abrasives in your chain doing damage. That is why I use wax lubes on my off-road/stone path bikes. The wax, IMO, creates a better barrier for the chain than oil does.
I've broken 3 shimanos. never a sram. The shimanos use a pin that you have to replace. The sram quick links have always work great for me. I use a sram 8 speed n my ss, and a 9 speed on everything else.
Quoted: 11 Post(s)
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
Chains that break have either been abused or they were not properly installed in the first place.
Abuse can take several forms:
1) Not keeping the chain well maintained, failure to properly clean and lubricate the chain.
2) Chain suck.
3) Mashing starts.
4) Dérailleur into the spokes due to improper limit adjustment.
5) Shifting under heavy load.
6) Excessive cross chaining.
I've never broken a chain, ever, I first rode a bicycle when I was 6, and I turned 49, yesterday... Now I did take a few years off in there (like 20), but still. I have put enough distance on a few chains to wear them out, but have never actually broken one.
VoodooChile
Bikes: Salsa Casseroll
You have to take the mtbr.com "reviews" with a grain of salt, or more like a 20kg bag of salt. I remember reading a review a few years ago, where a guy took a $350 mountain bike, jumped it off a 20' cliff, and called it a piece of garbage because the 65mm fork broke. I guess he expected the same level of performance from the 65mm travel fork on a $350 bike as the 15cm travel on a $3500 bike.....
2) Chain suck.
3) Mashing starts.
2) Chain suck.
3) Mashing starts.
This is my experience, too. I'm pretty hard on chains, and they wear out pretty quickly. I also replace them at the first sign of wear. I got around 1,000 miles out of a $40 Wippermann, and only about 1500 miles out of an $80 Sram PC1070, which showed no measurable wear at 1200 miles. I've now gone back to the Wippermann. At that rate of wear it's economically more sensible to use whatever is on sale at my LBS.
This is the only chain I've ever had a problem with! The one on my touring bike stretched to the point of being useless in less than 750 miles, and the (aptly named?) Missing Link let go almost causing a crash! I went back to SRAM chains; they've never given me a problem...
Downtown Spanky Brown
Bikes: Motobecane Phantom Cross Pro Kona Lana'I
I have no real opinion on your bike choices, but there is an awesome Specialized dealer on Trindle Road in Mechanicsburg that might be worth checking out.
Also wanted to say hello from over on the West Shore
Thanks for all the replies guys. I'll take the advice and wait for it to break before replacing it. I can always buy the chain and have it on standby.
Thanks again for the reply to my PM. Those guys on Trindle aren't bad but I ended up getting the Moto. I just couldn't settle for a Dart3 with the Rockhopper Comp/Expert 29 when I could get a Reba and XT/XTR components with the Moto for the same price range. If you ever get a chance check out Downhill From Here in Hummelstown. They had some great guys working in there and the owner is really hip!
Quoted: 3390 Post(s)
Liked 5,571 Times
Ignore the MTBR site.
KMC is one of the top chain mfgrs and produces chains for at least one other very well-known brand.
Ride the chain that comes with the bike until it is worn out.
Then replace it with a SRAM.
My preference for SRAM is mainly because it comes with a separable link.
The *only* chain problem I ever had was a Wippermann separable link separating during a shift.
So did you got ahead and order the moto? If you did I would be very interested in seeing it, I've never had a chance to check out a bikesdirect bike in person. Perhaps we could meet up on the greenbelt sometime. Thanks for the tip about the shop, next time I'm in the market for a new bike I'll check them out. Hopefully that won't be anytime soon though. Mrs. Bautieri might be a little sore with me if I bring another bike home.
Liked 5 Times
Dang it, I forgot all about that PM
I'd have no problem meeting up on the 'Belt to show you the bike.
elcyc
General Cycling Discussion
1
12-13-15 11:21 PM
3speed
Classic & Vintage
44
08-06-14 09:53 AM
TrojanHorse
6
12-20-12 08:18 AM
