De-rusting assemblies of steel and aluminum
What is the best way to remove rust from an item such as a derailleur which has both steel and aluminum components? I've read that OA is not good for aluminum and the same for vinegar. This part definitely needs a full soak in something that won't harm the aluminum but will take the rust. It is a 600 arabesque front derailleur and the aluminum items are pinned to the steel, no removing them I'm afraid.
Thrifty Bill
Vinegar is the common name for acetic acid. Acids and aluminum do not pay well together. So go dilute, and not for too long.
I've kinda done that too with a stronger OA solution...just brush it on carefully but the gel is a good idea. Wonder if you could somehow gel the OA solution?
Restoring cars, we always use phosphoric acid to remove rust. While we get it in gallon jugs from NAPA, you can get a weaker solution from your local supermarket, in the form of Coca Cola. You just soak whatever in the Coke for a few days and the rust should be a lot easier to brush off after.
Thanks guys. It looks like a small bit of the aluminum slipped into the solution last night anyway. It just seems to have brightened it a bit which is ok by me. The rest is soaking now.
Scarlson, good to see a fellow car restorer here! I use phosphoric acid quite a bit as well, but I must say that I've been very impressed with this oxalic acid. I'm trying to figure out why we car guys don't use it more! And thanks for the tip on the coke. I always dilute the strong stuff, but having that trick in my bag could be useful.
