Question on type shoe for pedal?
Motorcycle RoadRacer
Okay,https://www.cehoward.net/pedal34.jpg I am a newbie, and with that said, what kind of shoe do I need to go with pedals like this??
Thanks in advance..
Thanks in advance..
mechanically sound
You need a road shoe- one that has three screw holes in a triangle on the bottom.
Greg, I am a newbie, with that said.
Are you saying that with the pedals in the picture, and the bikes shoes( Northwave cycling shoes) with the 3 holes in a triangle, I also need SPD-SL cleats for the shoes? Because I will be picking up a pair of new ones in my size I will be getting off of CL.
Thanks in advance for your feedback...
Bikes: 2012 Scott CR1 Comp
Those pedals appear to be older Dura Ace pedals, which means that yes, you will need SPD-SL cleats to be able to use them (Look cleats are not compatible). There are a 0 float and 6(i think it is 6) degree float options, which is your call. Generally unless you know you need no float at all, go with the float variant to protect your knees. Your shoes will need to have a 3 bolt (triangle) pattern, so you can't use MTB shoes, but any shoe with that pattern will work.
From, the feedback I got, I was able to get some bike shoes, and since I didn't know what is what, I took the shoe to LBS, along with a picture of the pedal. The LBS asked me what kind of pedal, and I flashed the picture. From the picture, that got me the right cleat to go into the shoe, and will fit the pedal.
For my first pair of bike shoes, I got a brand new pair off of CL in my size. Not only that, when I do put everything together, this will be my first ride on a biccycle with cleats on!! Oh boy!!
Here are the shoes, cleats and pedal.
Thanks much,
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
It looks like those shoes require a receptor plate to mount the cleats. Did a receptor plate come with the shoes?
The same shoe is for sale at STP. --> https://www.sierratradingpost.com/p/,...e-For-Men.html
Here's what is says about the shoes.
"The eye-catching Northwave Solo road cycling shoe features a separate receptor plate, making this shoe compatible with Look, Campagnolo and Miche road pedals."
Bikes: 1997 Trek 2300
Now that you have the shoes make sure you read some of the threads on tipping over while still clipped in. Trust me you will do it we all do. Don't worry it hurts you ego more than anything! I suggest practicing clipping in and out while stationary and leaning against a wall and then practice more in an open parking lot or in your driveway.
Quoted: 539 Post(s)
Liked 44 Times
I don't quite agree with this "we all tip over" thing. Most of us practiced, and exactly once came to a dead stop, forgot to clip out in time after several no-fall rides, and fell over (again, at no speed). Then never let it happen again.
I am getting top-notch feedback on this. Thanks much..
Okay, the cleats I purchased, even though I took the shoes, and the picture of the pedal to the LBS, don't fit. Even the screws in the package don't fit the holes.
On the receptor plate, I will have to find out about that. Right now, the cleats with the screws are wrong, so I will have to take that up with the LBS first. After that, if a receptor plate is needed, I will work on that..
I got a couple neighbors who ride in cleats, and they were giving me some tips. I got 5 bikes in my stable now, and only one requires cleats. The others have toe-straps. I will make this move to riding with cleats. It will be lots of practice time in parking lots to get the feel.
Right now, I just need to get these cleats on the shoe.
mechanically sound
Happened to me the first time I bought road pedals and shoes as well. The bright side: probably won't happen again.
You are right, it won't happen again...
