bmx racing
Haro Monocoque
Bikes: Haro Monocoque, GT Vertigo.......
bmx racing
hey, i wanna get into bmx racing, and i think i need different forks, or do i, cuz mine are kinda heavy, but i dont know anything, ne wayz, what do u suggest i do to make my bike faster in any real way, like gear ratios and stuff (i dunno) and what are some good racing forks? the same with cranks. im hella stupid..... oh yeah, i remember somebody askin about disc brakes on a bmx bike i found them on mistake, heres some pics
~OPSEC~
Bikes: GT Timberline (mtb) and Haro Backtrail (bmx)
with the cranks, a good 180mm profile will do just fine if you're of average height, running a 38:14 gear ratio or a 44:16, and you can't go wring as far as racing goes with an answer fork, but its highly unnecessary, just any lightweight fork will get the job done, hell, I used to race on a S&M Pitchfork for a while
~OPSEC~
one more thing, you don't necessarily make bikes faster, just you. The best thing you can do for speed is a nice lightweight fork and some lightweight wheels (chris king wheelset laced to some Araya Super 7X rims with titanium spokes will rock your world.) Other piddly things like a lighter seat and some nice Tioga Comp III tires will help, as well as getting a narrower chainwheel and freewheel (or if you're running a cassette its no problem) and running a 9 speed MTB chain
Haro Monocoque
ok, do i really need lightweight rims? my rimset hubs and all weigh 2 or less pounds. is that good? my frame is a haro monocoque, hella light, and tell me a little about gear ratios, im lost. need some answer forks, though. any though wear i can get them kinda cheap.
~OPSEC~
gear ratios are simple, just run a 44:16 and you'll be fine, a gear ratio that somes out to the same (the 38:14 I mentioned) is smaller and lighter and there's less metal there to flex, so you get a bit stiffer response, but good luck finding a 14t freewheel. Your wheels, I don't know what average weight is but a chris king uses an engagement 'ring' instead of pawls, so you get quicker engagement after freecoasting, which can help as well. Cheap forks can usually be found at the racetracks along with about anything else, or ebay, but as with anything used, it may be worn beyond its stress limitations, so be careful.
Bikes: Lemond AlpeDeHuez(2004 Chorus),Felt FS850(full XT),Soon Felt TK2
One thing to remember is that a good rider will still ride fast on a $^it bike.So alot of it comes down to the person sitting ontop of the bike.
Haro Monocoque
so those numbers just mean how many teeth the sprocket and freewheel have? is the bigger the difference the higher top spead you get or anything?
~OPSEC~
the higher the bigger number is in relation to the smaller number the harder it is to get started but the more you get out of each crank revolution once going, this is something that you will be able to guage which you'd prefer depending upon which track you're at and your competition, I preferred to get out ahead early as I'm a really big guy, and it can be damn hard to pass me even if you're faster
