WANTED: DIY Rack Plans for my garage
Granite State Destroyer
Bikes: Specialized Rockhopper Comp A1x
Hey Bikers,
I want to earn some points with my "Mrs." and clean up the garage by building a rack like the attached pic for 6 bikes. Can anyone help out with suggested plans, materials & measurements?
Bike on
Addison
Bike on
Addison
Old School
Bikes: 1990 Specialized Allez Carbon, 1997 Specialized Ground Control AIM Comp
Try instructables.com for lots of ideas. Lots are made of easy and cheap materials. i am going to make mine out of pvc tube now that i live in apt again and need to stack them above each other with equipment in between
Made in Taiwan
Bikes: Camerotti ti roadbike, Old Sears Free Spirit Tange Hi-Ten Single Speed built from a 12 speed, 1997 Cannondale CAD3 r500 with Shimano 6400 groupset
Quoted: 35 Post(s)
Liked 11 Times
If you want to save on space in the garage. There are $2.99CDN coated hooks that you can buy from Home Depot that screws right into wooden beams. Then you just hang your bikes by the wheels. They are rated for 75lbs, provided you have them installed in 1" thick solid wood.
Super simple and easy, just pick a spot. Drill a small pilot hole and screw it in.
All dogs want to be lap dogs doesn't matter the size
-Animal loving friend
I like this kind... The kind you want to build seems pretty simple to build too though. Just build it so the bikes are two feet apart and fit the width of the rear wheel...
Scuba, I'm already using a couple hooks for a couple bikes. I need this rack on the ground so my kids can easily park their bikes.
ScottNotBombs - I just needed a number to start with. 2 feet sounds good.
Thanks, fellas!
Thanks, fellas!
Don't worry about the weight on the wheel doing any damage. I've hung my bikes that way for 20 years.
