To patch a tire?
To patch a tire?
Old 06-23-10, 10:02 AM
To patch a tire?
Is it a good idea to patch a tire? I got a flat yesterday and upon inspection today, I found the tire has a .5cm rip in it. The rip is along the wall headed to the bottom of the tire. Is a tube repair kit fine for this sort of repair?
thanks
flattireJason is offline
Old 06-23-10, 10:08 AM
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times in 623 Posts
You need a tire boot.
Roy got 9500 miles after this flat at 400 miles on a new tire.
Fred "The Real Fred"
10 Wheels is online now
Old 06-23-10, 10:16 AM
digger's Avatar
Quoted: 1295 Post(s)
Liked 157 Times in 132 Posts
thanks
Yes, you can use a boot, but I would recommend ONLY as an emergency repair. That tire is toast my friend.
Blessed Jayus 10Wheels! Never seen something like that in a bike tire before. But if that is how you get your deck screws....ummm....you know you can pick 'em up at the hardware store right?
digger is offline
Old 06-23-10, 12:48 PM
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
I repair tire cuts with 1/32" thick fiber reinforced rubber gasket material. I super-glue it in place and then cover it with a piece of duct tape to keep the stiffened edges from fretting thru the tube. With this repair you should be able to wear out the tread of the tire.
davidad is offline
Old 06-23-10, 04:48 PM
pmt
Experienced
Quoted: 16 Post(s)
Sure, it's the only way to fix Road Tubeless. Just don't use self-stick patches.
pmt is offline
Old 06-23-10, 05:24 PM
Liked 3 Times in 3 Posts
Use an automotive tire patch. Cut the patch so as to overlap the damaged area by 3/4". Light buff the back side of the tire with red Scotchbrite. Take care not to damage the fiber. Apply a thin layer of rubber cement and apply the patch. A cut on the sidewall can be repaired using shred-resistant dental floss. Again, apply a patch on the back side of the tire.
furballi is offline
Old 06-23-10, 06:36 PM
Asi
Engineer
Asi's Avatar
Bikes: 1989 Krapf (with Dura-ace) road bike, 1973 Sputnik (made by XB3) road bike , 1961 Peugeot fixed gear, 2010 Trek 4400
Quoted: 38 Post(s)
At one time after an explosion (a really old cracked tire) I repaired it so i could get home by sewing it. I knocked at the door of the first house I could find and ask for a needle and some string and a piece of electrical tape for the inside. It held up for 50km (back to home). Now in my emergency kit is found a needle and some heavy duty string (for sewing leather), along with a tire boot.
Asi is offline
Old 06-24-10, 08:49 AM
peripatetic's Avatar
Bikes: All 70s and 80s, only steel.
Gluing closed the hole and using a boot can work wonders. You can also glue a patch cut from old inner tube inside the hole.
peripatetic is offline
Old 06-24-10, 09:15 AM
Ruffinit's Avatar
Bikes: Bridgestone T700, Colnago International, Cannondale SR and ST 700, BH Vento, C. Itoh Super Light, Schwinn High Sierra
+1 to Furbali
We used to fix automotive tubeless tires in this manner also. Whatever manner you use to repair the tire has to be non abrasive to the tube AND when you inflate the tire to full pressure (especially high pressure tires <100psi) make sure your repair doesn't cause the tire to appear to rupture or have a "goose egg" on the outside. I normally carry a spare tire on longer tours. (figure 8 and attach to lowriders with cable ties.
Ruffinit is offline
XXLHardrock
Bicycle Mechanics
19
07-14-15 06:35 PM
wilfried
Bicycle Mechanics
9
03-18-15 09:15 AM
MrWesson
Road Cycling
8
07-31-13 08:28 PM
Blue_Bulldog
General Cycling Discussion
4
06-19-13 12:22 PM
Solorouleur
Road Cycling
6
09-05-10 05:34 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
