How to stop at red lights properly?
When I stop at lights, I usually just lean my hand on a street post. If there isn't one, I usually get off. My friend tells me that I should be standing on the ground, right pedal halfway, with my crotch on the tube, but I basically have negative standover height (aka my nads are pressing against the tube)! My LBS tells me that the 17 mountain bike I'm riding is perfect, and a 15 would be too cramped. What's the correct way to stop and idle?
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
The Mtn bike is perfect? For what, road riding? Mtn bikes are designed for mtn biking. There is a reason it's called a mtn bike and not a roadbike. Usually mtb's run a bit smaller for added clearance on bumpy terrain. If you have a negative standover clearance on a mountain bike, it is too big!
Ridin' South Cackalacky
But you mean how to be stopped at an intesection? Whatever looks the coolest, has you in a balanced, ready stance for when you start off and doesnt have you falling over like a doof.
Your friend is pretty much spot on.
This works too:
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
As long as you stop you are good, IMHO.
I agree that if you are negative on the stand over on a mountain bike there is a fit issue. FWIW my rough stuff mountain bike is a 21", when I use one exclusive on the road I go one size larger to 23" my road bikes are 25.5" I have been riding long enough that I don't usually listen to what bike shop sales people have to say about fit. Unfortunately too many of them don't have a clue what proper fit is.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
OP - if you need to dismount, lean your bike. That gives you a little more standover clearance and is also a technique you can use on the trail. Practice dismounts on either side.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
20 years of cycling, and I didn't know there was a "correct" way to stop at red lights.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
By "actual riding", you mean riding offroad as MTB's are designed to do? If so, then your MTB is too big for you.
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
If your "nads" are on the tt on a mtb then the bike is WAY TO BIG!!!!!!!!!!!!!!!!!!!!!!!!!!!!
MTBs suck on the road BTW, in fact, they suck everywhere but in the dirt.
MTB's turned into road bikes are functional, i.e., they go down the road and get you from point to point. But they are a compromise on most levels., requiring you to adapt to them. It can be done, sure... anything can be done. Is it the highest and best use? Often, no.
In other words, there 'aint nothing like the right tool for the job at hand.
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
So what did I say that was any different from your correcting(?) statement? My statement is that the MTB frames are smaller to allow for bouncing while riding offroad. The word "usually" is thrown in my statement to show it is not written in stone, as are your words "not necessarily".
My point was that standover clearance is over-rated and sizing a MTB based purely on standover clearance is not a good way to do so. Ideal fit depends on the mix of typical terrain and rider's strengths/weaknesses and body type. For a lot of riders, a longer top tube/shorter stem (ie sizing up one) can help. Sometimes, that means a bike where the nads can brush, gently touch or softly graze (depending on how much you love your bike) against the TT when you straddle it.
However, I do agree with you that if Dz Nuts are *actually* being squashed, then the MTB is *most likely* too big.
V.
"If you have a negative standover clearance on a mountain bike, it is too big!" This wasnt qualified.
I'll give that all the attention it deserves
V.
V.
That's funny, first MTB sizing search comes up with the same result I've read and known for years. I'm sure just about any search will produce the same re*****.
If you ride offroad, you need clearance.
3/4 down the page........#9 long top tube ok but bottom line, make sure there is plenty of clearance.
https://www.mountain-bike-world.com/m...e-fitting.html
A longer seat tube will however increase the height of your top tube and reduce your standover clearance – be careful here and make sure there is plenty of clearance in case you come off the bike.
If another rider is willing to smash his nutties by way of inccorect frame sizing, be my guest! But then again, the OP is using an MTB for roadriding for which it is not designed, but like mentioned above, functionable. Using the right tool is the key so I guess if he isn't concerned about using the right tool, why worry about the right sizing?
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Anyway, I have made my point (ie, reach and overall weight distribution should take priority over standover).
Enough people on MTBR.com and other places will agree with it, and anyone who is interested can do their own research. I know what works for me, and I'd rather have my Niner with its reduced standover rather than, say, a Trek with a greater standover - while I am happy to provide more info on why this is so for anyone who is interested, winning an argument or proving anything to you or anyone else isnt very high on my list of priorities.
Knock yourself out with whatever works for you.
V.
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Quoted: 13 Post(s)
Liked 5 Times
I'm having trouble picturing any case in which having no standover clearance would be acceptable. Even in the case of a freakishly proportioned body where one's legs are super short but torso and arms super long, such that one would need the top tube length of a larger frame, one should simply choose a frame with "compact" geometry so that the top tube slopes enough to provide plenty of standover clearance. Nearly all mountain bikes made in the last 20 years have sloping top tubes anyway.
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
For my riding style, I prefer to have my center of gravity "between the wheels" and a long wheelbase. I can size anywhere from 19-21" frames for MTBs. 19" gives me more standover but I tend to go OTB a little more. So that leads me to a 20-21" frame. For my preferred geometry (Niner's 29-specific geo), that meant a 21" frame with a standover that leaves about an inch to my nuts - but the rest of the bike is perfect. The front wheel stays planted even on really steep climbs and I feel really, really stable on fast, bumpy downhills and on loose-over-hardpack singletrack - far more than I have ever felt on a smaller 18-19" MTB. This bike fits me in a way no 19" bike that I have tried ever did - and I am able to clear more technical stuff than I ever could before.
On the trail, when the ground is uneven, even 2-3" of standover can sometimes not be enough, and besides, every time I have dismounted, it has been to the side and not straight forwards onto the TT. So this is a compromise I happily accept.
Ok, so the distinction is that I do have about an inch or so of clearance, while the OP has no clearance. Point is, just standover is a bad measure for calculating bike fit for MTBs, just as it is for road bikes.
V.
Lock both brakes, lean forward so the rear wheel lifts up about 6", then pull back hard to get on the rear wheel. Hop on the rear wheel for a few minutes until the light turns green.
HTH
HTH
Bikes: Kona Ute, Nishiki 4130, Trek 7000, K2 Mach 1.0, Novara Randonee, Schwinn Loop, K2 Zed 1.0, Schwinn Cream, Torker Boardwalk
A stop is a stop as long as you are not moving.
Usually does not mean JUST as you put it. Not sure where you got JUST from in my post.
Even you have an inch, the OP has a negative, his bike is too big!
I made a general sizing statement, you argued then came out with the same result, you have an inch clearance, again the OP has negative clearance!
How about posting some links where the riders prefer a negative standover like the OP has on his bike (which isn't too big in your opinion)?
Bikes: Specialized Roubaix Expert 09, Custom 2013 Bike Friday Pocket Rocket
I'm with Mr. Beanz. If your MTB is crushing your balls then it's not the right size. You should be able to stop a bike and not be in pain. I understand compromise on geometry, both my bikes are a tad high on standover (my road bike let's you know it's there for sure) but if a bike causes you pain in you nuts when you stop on flat ground that's just not a functional tool for a normal recreational rider. I mean you can't even mount the damn thing properly.
I used to stop by putting my foot on crap but a wind blew me over once (haha i know) so now I stop like your buddy does usually.
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Winning an argument or proving anything to me? Geeze, everything you say is pretty much agreeing with what I said from the start.
I have made my point - re-read my last post. If you have anything to discuss re the specific content, by all means. Otherwise, I have no desire to debate who has "won" this argument. You have, happy? The medal ceremony will be later
ɹǝqɯǝɯ ɹoıuǝs
Bikes: Huffy and Pacific
How to stop at a red light properly? This is what I do: https://www.youtube.com/watch?v=X975EVV3Egg
PS - if your mountain bike gives you 0 standover clearance, there's a 99% chance it's too big for you. Most mountain bikes have a sloping top tube. Why didn't get go with the 15" bike with a longer stem and/or a setback seatpost? Are you a young teenager who's still growing?
I am actually really interested to see a picture of you on the bike. It's actually pretty damn dangerous if you do any dirt riding. In emergency situations where you have to put a foot down, you'll be very sorry.
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 269 Times
