slipping seatpost
slipping seatpost
the seatpost on my super pista is slipping down as i ride. the seatpost is fine (thompson elite) i can find any problem with the frame, and the bolt tightens fine. does anyone know what would be causing this? the post is the right size this problem just started happening after about 500 miles
Single-serving poster
Maybe the seatpost is crumpled a bit, is the clamp clamping? is the seat-tube still squeezing down as evidenced by the notch? It could be that you've worked it into an oblong shape instead of the circular shape if you rode with the seatpost above minimum insertion..
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
I had a similar problem and it was the binder bolt.
Bikes: Meercat
u could drill a small hole in the seat-post, at the ideal hieght, and put a small pin/screw in it? Not tried this myself.
Bikes: NOYB
Slipping posts are almost always due to them being the wrong size for the frame. The Bianchi Super Pista needs a 27.2, I believe. First thing you should do is verify that.
Quoted: 9 Post(s)
somewhat common with thomson's. if using a qr clamp replace it with one that has a brass or bronze bushing instead of the nylon or go to a bolt on non qr collar
its the right size post, it was way below minimum insertion, not a quick release, ill check the binder bolt i guess, it still tightens down but i guess it could be loosening as i ride
Yes, I was having the same problem with my Thomson, I wiped most of the grease off (and switched to a bolt-on collar) and it stopped slipping.
Hisamatsu
General Cycling Discussion
0
08-03-17 05:15 AM
echo victor
Classic & Vintage
67
05-07-16 11:43 AM
