Rolf rear wheel failure
Bikes: Co-Motion Speedster Tandem, S-works 29r, Specialized Tarmac SL4
Quoted: 14 Post(s)
Well - was cleaning the tandem on Friday and noticed that a paired set of spokes had pulled through the rear rim. Wheel is 5 years and about 10k miles old. We didn't even notice a problem during our last ride. Sent the pic to Rolf and want to look at my options.
Been wanting to run dual disks and depending on what Rolf is going to do (if anything) I think I'll investigate a good set of disk wheels. Only issue is that i'll need a new fork as well.
Bikes: Erickson Signature, Paketa D2R
Quoted: 5 Post(s)
I've commented a few times previously about our failed Rolfs - same symptoms. What is your team weight? What kind of riding? Have you been using them with a disk? I ask because ours failed soon after some fairly steep cobblestone descents, 340ish pound team + 50 or so of bike and stuff. Of course this may have been only coincidence - it wasn't a controlled experiment.
Quoted: 5 Post(s)
Also: We had way fewer miles on ours (2-3k?). Rolf agreed to repair it "because you were not satisfied", not because they admitted that the wheel should hold up better. I guess this means it was not a warranty repair, but rather a customer satisfaction repair. I love the ride on these wheels, darn it. Too bad about the failures. I see an awful lot of reports like yours and mine, and I can't help but think there is a real problem here, not simply some bad luck.
join the club
Quoted: 14 Post(s)
Not sure if I'm glad to hear of other similar failures or not :-)
I've got a love/hate relationship with these wheels. I love the way they ride - but I hate the damn bearing adjustments which work themselves loose. I had one broken rear spoke and one front spoke that came loose for no apparent reason. As most have said - Rolf has been pretty good on fixing them, but we'll see what they do here.
We are a relatively heavy team - 350 or so pounds. It does have a rear disc.
So, both the Rolf and the Sweet 16 are prone to rim failures, a joy to ride on, and a pain to upkeep. The difference maybe that Rolf stands behind its product and Santana blames the consumers for the failures.
Quoted: 14 Post(s)
Oh well - decision time for a new wheelset.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
With expensive wheels, sold as complete wheelsets, and stuff being more durable these days, I think we expect wheels to last indefinitely, which may not be a reasonable expectation for lightweight stuff.
If we get 5 years out of Rolf's I'll be happy. (until I have to stroke a check in 3 years)
You could get lost and die.
You could hit a tree and die.
Just heard back from Rolf - I'll have to pay the standard $285 to have them replace the rim and spokes using my old hub. Since the wheel is 5 years old - I understand their position - was just hoping that they would help a bit more considering the type of failure.
The guy is really an expert wheel builder.
Although I have not actually bought any wheels from him, I did a get a quote and he has given me a lot of good free advise on wheel building.
hors category
Quoted: 8 Post(s)
Liked 5 Times
For mortal cyclists, unless we found fatigue cracks around spoke holes, saw excessive brake track wear (which took a lot longer before they started machining the brake tracks), or encountered a bent a rim there was really no good reason to replace a rim. Yeah, there were a lot of rims that did get replaced fairly often BECAUSE signs of fatigue were discovered, but they were typically the uber-lightweight rims that were designed for race use... not rims that were marketed for use as every day trainiing rims.
Heck, I think I still have a set of MAVIC GL330's that I used in the 80's and 90's at the house on my Raleigh's that probably have 12k miles of use but don't look much worse for wear. Admittedly, I never weighed much over 140lbs back when I rode sew-ups all the time, but I always expected to get many seasons of use out of any rim I bought... right up and until I bought my first integrated, super-light MAVIC Helium wheelset. I had low expectations for their longevity and was hardly surprised when they became unreliable after about 5k miles of every day use.
However, we're not talking about single bike race wheels here: these are wheels being marketed for use on tandems as everyday wheelsets that are purportedly as durable as 40h wheelsets in the case of the Big-S. So, if your benchmark for rim life and durablity is 20k miles for rims like MAVIC T217s, CXP30s, Velocity Deep-Vs and the like then that's the expectation. As to how long it takes to put 10k or 20k miles on a tandem wheelset and whether or not your wheels will last that long, that seems to be the wildcard... well that an honest mileage records. Clearly, there are many sets of Rolfs, Santana Sweet 16's and Bontrager RL Tandem wheelsets out there with a lot of hard miles that are doing just fine. However, there sure seem to be an awful lot of them that don't. That's the crux of this on-going issue with 'performance wheelset' reliability, never mind the value proposition.
Quoted: 14 Post(s)
Good grief... what type of rims were you using and/or how many miles a year were you putting on these wheels?
We don't ride the tandem exclusively - although it is our main choice on the weekends. 10k is probably a bit high of an estimate - but definitely somewhere between 8k and 10k.
pan y agua
Liked 727 Times
Fiamme Yellow label. Around 5000 a year. I don't know that I replaced them that often, but standard advice for racers back in the day was to rebuild your wheels each season with new spokes and rims as preventative maintenence. Of course that was probably a $100 or so job for both wheels then.
pan y agua
Liked 727 Times
Rolf rims (as well as Sweet 16's), by their design are going to be more prone to fail at the spoke hole than conventional wheels as a result of the high spoke tension inherent in the paired spoke design.
When you buy them I think you have to recognize the tradeoff that they are not going to be as durable, as other less aerodynamic higher spoke count wheels, and that is part of the decision calculus of whether they're worth it for you.
As for ours, we've got about 7- 8,000 miles on our Rolfs (I say about because I have a fairly accurate idea of the mileage on the bike, but a less accurate handle on how that splits between 2 wheelsets) with no issues.
I hope we get another 8,000 out of them. But if I had to replace a rim tommorow, I woudn't feel like Rolf had let me down, or I hadn't gotten my money's worth.
Aero, light, inexpensive, durable. You can pretty much have 3. Not sure anyone's packaged all 4 together yet.
Quoted: 1572 Post(s)
Liked 643 Times
To me it all comes down to use and expectations.
Finding a failed rim while you are cleaning up your bike at home is one thing. Having such a rim fail in Eagle River, Wisconsin on Wednesday of a multi day tour is something else. It doesn't matter if Rolf will replace the rim for $285.00, unless you can come up with an alternate plan, your vacation is over.
pan y agua
Liked 727 Times
Personally, I wouldn't do a multiday tour away from support with them. I would take them on a multiday tour, if I had another set of wheels back in a car which I could get to each night.
Bikes: Paketa V2r, VECdM29er, a bunch of singles gathering dust.
About 5500 miles on our Rolfs until the above failure in the rear wheel. I paid for them to replace the rim. We are about 340 total weight including the tandem, with rim brakes.
Guest
Posts: n/a
Quoted: Post(s)
There are 3 photos of cracked rims here https://share.ovi.com/album/currentresident.bicycle this is a common failure the mathematics of it is simple make that part twice as thick and it will never fail at your weight.
hors category
Quoted: 8 Post(s)
Liked 5 Times
That explains a lot. What were they, like 290g or some insanely light weight like that? As noted, my GL330's were about the lightest rims I ever used and having eyelets seemed to give them a much longer life than the non-eyelet rims like the Fiamme Yellow label / Ergal rims. I think the Red label Fiamme rims were on par with the GL330s, made a bit more durable by the use of eyelets.
Interestingly enough, and related to this thread, I'm pretty sure FiR acquired all of Fiamme's assets when Fiamme went out of business.
Quoted: 77 Post(s)
Liked 19 Times
Chris King hubs, Velocity Aerohead rims, 32H front and 36H rear.
Got just over 22,000 miles on rear wheel when rim had to be replaced.
Front wheel still doing great at 30,000+ miles.
Way-back-when, we used Mavic rims; usually got 20 to 25 thousand milesw off rear rims. One front rim lasted 56,000 miles.
Just our experience.
Pedal on!
Rudy and Kay/zonatandem
Pedal on!
Hit a huge pothole Sat. Destroyed front rim. 14,000 miles on Rolf's. Going to replace both front and rear rims 7 spokes. Hope these last as long.
Quoted: 14 Post(s)
So looking at options - a place called prowheelbuilder.com does custom builds. They are limited in Rim choice on their website - but give a good estimate of weight and their costs seem reasonable.
As a comparison - Rolf Tandem Disc Clincher 31mm 20 / 24 Bladed 885gm / 1050gm 1935gm $1099
So looking at DeepV's with WI Mi disc hubs, sapim cx-ray spokes and brass DT nipples - all in black with 32h front and 36h rear - estimated weight was 1,935 at $785. With Mavic CXP33's instead of the Deep V's - weight drops down to 1,836 grams but price goes up to $820.
The ONLY thing i'm a bit unsure of is the 32h fronts with disc - especially with our team weight at 350lbs.
Thoughts? Suggestions?
I would go with a 36 holer for sure with a front disc. More so if using a big rotor. Our last tandem had a 203mm rotor up front and on steep decents at a pretty fast clip I could get the back wheel off the ground. I sure miss that stopping power. Not sure I would go that far with a carbon fork. The Winwood disc fork with a tandem rating only accept's a 160mm rotor, and probably not much better than rim brakes as far as stopping power, but, no heat on the rim. A rotor this small would be rendered useless on a steep decent in a very short time, and may warp quickly. Just a guess, but I've run a front disc for years on a Cannondale with a steel fork and a 203mm rotor. The ultimate stopping power, with a rim brake on the rear.
Quoted: 14 Post(s)
Good choice. Make sure length is compatible, from crown to dropout. Rake is somewhat important within a mm or two. Awesome stopping power. I looked @ the prowheelbuilder site. Thats where I'm headed for my next wheel build. I'll use the Rolf's for special occasions. Sonoma County roads are nothing but dirt roads with a bit of pavement over the top.
