Newbie question: What angle for the bar extensions?
Bikes: Trek 7200 25" frame
Initially when I purchased my bar extensions at the LBS the shop guy had them nearly verticle. I asked him to tilt them forward. The photo shows where he left them.
I look at others on here and see the bar extensions pointing more considerably forward for many people with hybrids.
As the extensions are now I am not comfortable using them, really. Maybe if they were pointing more forward (bull horns) I'd get more use from them?
The goal for me was to give varied hand positions and maybe aid in finally heaving my big butt off the saddle.
Bikes: 2010 Trek 7.5 FX
I believe there's no hard and fast rule as to the degree of the angle for bar ends. I would suggest experimenting as you ride (bring along a bike tool) to find the most comfortable position for you. I originally had mine set at the near vertical angle, but switched to an approximate 35 degree.
It depends on how you ride and how you use 'em.
If you are going to sit on the saddle all the time and just need barends to switch handpositions, you may want to have them pointing slightly upward.
If you are a sportive rider and want to use your barends to get off the saddle and pull on the handlebar while climbing hills (like me), you may want them pointing more forward.
I have mine at about 30 degrees i guess and find them perfect for having less strain on my wrists while climbing.
I definitely prefer them pointing further forward. They put me in a nice relaxed forward position for long stretches of highway, and help me to get on top of the bike when climbing hills.
I also started with my bar ends quite vertical. I rotated them, bit by bit, until I hit that magic spot where it became very easy to move my hands from the grips to the bar ends, with no loss of control.
As previously mentioned, you may want to experiment with them rotated more forwards. Pick something that works for you.
Your handlebar position is already high and close to you. You may even decide to remove the bar ends.
One more piece to the puzzle of how they are so "up in the air" is that I'm 6'6". Even with this 25" frame I have the seat up a bit and so my handlebars are up, too for the upright position.
Then again maybe I should consider a different bar style and give up on the upright riding position.
Born Again Pagan
Bikes: Schwinn hybrid, Raleigh MTB
I agree with meanwhile. IMO the bars should sit in a position that mimics the angle that your wrists/hands would be in naturally. You don't walk around with your wrists cocked in a flexed or extended angle, therefore it only makes sense that they are most comfortable when placed in as natural a position as possible when on the bars.
