Can I wear denim over cycling shorts and be comfortable?
Quoted: 5 Post(s)
Or at least more comfortable than denim alone? Cycling 10-20 miles in denim takes it's toll. I'm not much interested in aerodynamics - to me, cycling is just an economical and healthy way to get from one place to another - I want to be able to wear everything I normally wear, plus something padded between my body and my jeans to prevent discomfort.
These look fancy but will these do the same job for less?
Thanks.
Thanks.
Bent builder
Bikes: Magic leaning delta FWD trike, various bents and Fisher Sugar 3+
Just watch for chain tattoos and make sure the fit isn't painted on.
:)ensen.
:)ensen.
Bikes: Kona Ute, Nishiki 4130, Trek 7000, K2 Mach 1.0, Novara Randonee, Schwinn Loop, K2 Zed 1.0, Schwinn Cream, Torker Boardwalk
It is rather silly that you ask us if you can wear denim over cycling shorts because you know the answer...YES and you can wear whatever you want. The problem with wearing denim or any fabric that fades and wears easily is a sweat ring around the rump. Certain fabrics don't do well and deteriorate from rubbing and sweat even with the bike shorts worn under. I have ruined two pair of pants already so I just wear designated pants and skirts.
Bikes: rockhopper, delta V, cannondale H300, Marin Mill Valley
Liked 5 Times
The downhill shorts you linked to are padded to protect in the event of a fall, you probably don't need the hip pads and they might make you look fat on your jeans.
The second link is a product that is designed for the sort of use you have in mind, a better choice for you, I think. I've used similar padded underpants and found the padding to be a bit thin, which might fit better in your jeans but doesn't provide the same amount of cushion as most bike shorts. I've purchased baggy style riding shorts with removable padded liners. I use the liners with the shorts they came in and with other pants. If you think you would get use out of the outer shorts as well as the liners, this is a good option. The shorts I have from Zoic came with thicker pads than the pairs I have from Pearl Izumi, both have thicker pads than the padded underwear I have.
Blue jeans are pretty uncomfortable on or off the bike, stiff and heavy with thick seams that are badly positioned for any sort of seated activity. Was that to keep the cowboys from falling asleep in the saddle or just a crude design? Of course, I lived in jeans as a youngster and rode many miles in 'em with normal underwear. I had a Brooks saddle on the bike of my young adulthood. Perhaps something about leather saddles and blue jeans works well together.
I find the seams on denims to be seriously offensive on a bike saddle, even for a short spin down to the corer store, even with a Brooks. The padded under shorts, any of them will help, but choosing a pair of pants/trousers that have flatter seams will be a much better option.
Loose fit might be fine, Andiamo is a maker of liner shorts with crotch padding,
but they are priced about the same as some as cheap Lycra nylon shorts.
saddles with the cut out in the middle would present less of an issue with the thick center seam on most denim trousers.
I got 2 pair of cheap charity store gaberdine pants ,and had a local alterations sewing shop taper the legs, keep em out of the chain, and double the seat and they are a good alternative..
Bikes: Salsa Fargo, One-One Inbred 29er, Blue Norcross
Do you have a particular need to show up at your final destination in denim? If not, I concur with what the other posters have said; wear something else.
For work (which is a situation where you don't want to be wearing lycra for any amount of time) and running errands, I ride in nylon cargo shorts (they look a bit dressier than athletic shorts, but don't have the same seam issues as a thicker fabric such as denim or even many khakis) or athletic shorts with either synthetic boxer-briefs (for sub 20 km rides-they dry faster) or a pair of the liner shorts (for longer rides when running errands). I change when I get to work, but it allows me to show up looking semi-presentable.
I have picked up all my padded liner shorts for less than $20, though I don't know what you can expect for sales on your side of the pond. Happy riding!
One Man Fast Brick
Bikes: Specialized Langster, Bianchi San Jose, early 90s GT Karakoram, Yuba Mundo, Mercier Nano (mini velo), Nashbar Steel Commuter, KHS Tandemania Sport
you will get a lot more responses on the Commuter forum.
Not surprisingly, there's a lot about the design of a classic style of blue jeans that people don't understand. That includes many of the people who try and make copies of them, unfortunately. The flat felled seams on jeans are located at the points of maximum wear, and keep the trousers from falling apart. I agree they're not well suited for bike riding, but they're quite well suited for what they were intended to be, which was a comfortable pair of working trousers. Working doesn't involve sitting...
The Professor
Bikes: Alex Moulton Double Pylon, Surly Big Dummy, Alex Moulton GT, AZUB TiFly
Liked 6 Times
FWIW I started using one of these with my Big Dummy. I find I can wear pretty much whatever I have on with this saddle and chafing is not an issue. For me it works well with the BD's more upright riding position but not with my road bike, but that certainly isn't the case with everyone.
Liked 5 Times
I've seen one of those. Probably would see more if they didn't look so different. The guy who had it was very pleased with his MoonSaddle!
Blocking your fire exits
SO and I wear mountain bike shorts during cooler weather or when we don't feel like walking into establishments in tight clothing. They have the lycra undershorts and padding, and look like cargo shorts. You can get lined/unlined versions. Like these.
