Dropped too often.
Boomer
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times
Dropped too often.
I've dropped my chain 3 times in the last week. My fault, I've been trying to get by with a left over triple derailleur on a compact double mountain crank (24/36). I finally bit the bullet and ordered a new top swing Shimano SLX compact front derailleur.
I'm still a twist shifter who is in the habit of grabbing 3 or 4 gears in the back at the same time I'm changing the front ring. The old bottom swing (sitting just above a bottle bracket screw) was always just a bit high on the chain rings and all of those bumps and compromises on the inner face of the cage simply didn't maintain control of the chain in all circumstances.
I know we've beaten the compact question to death on road bikes but is anyone else using a compact mountain double setup (still 9sp, not the new sell your house stuff).
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Not yet, but thinking about going that route on my Stumpy one of these days. I never use the big ring on my MTB. What crank are you using?
Where are the pictures?
So, is the chain coming off the crank, I gather? Which way? If you're loosing it off the big ring, then first thing is to check the limit screws for the DR. If the little ring, likewise, except that you can also get good old mountain-biker's "chain suck" from any number of things, from insufficient tension on the chain (from the rear DR springs) to having the chain be a bit too long to just being all crudded up and and adhering to the chainring.
Sounds like your shifting practices might be a bit suspect... On my old police patrol bike (a Trek MTB) I got chain -suck rather often till I started shifting onto the little ring only slowly and deliberately.
Boomer
Liked 1,457 Times
Truvativ stylo 24/36/bash. (Try Pricepoint BD) SRAM X9 components all around (new this year as as the last bike sale departed with my old ones) SRAM chain sized for 1 extra link on the 36 ring 34 cassette. The chain is dropping off the inner ring during down shifts as it falls through the granny notch on the incorrect triple derailleur that is set slightly too high because of the aformentioned bottle bracket mount. I'm sure that the SRX FD-M665 double will solve the problem as it will mount below the bottle bracket and the double variety inner cage plate will confine the chain. I may even be able to put my chain keeper back on for extra insurance.
Once that's done I'll get back the normal 2 hands full of twist grip shifting. It's a very nice feature to have when you ride into something that bogs you down.
Boomer
Liked 1,457 Times
I believe that once the system is set up correctly you should be able to bang through the gears at will. That's one of the reasons that I prefer the compact double on both MTB and Road bike...........bulletproof shifting. I just cheaped out and used stuff from under the work bench to create a bad system.
Boomer
Liked 1,457 Times
Just as a follow up for Bluesdawg and others, the mountain double front derailleur solved the problem completely. It is necessary to adjust the height so that the cage just barely clears the outer bash ring while shifting up to the mid (high on the mountain double crankset) ring. At that point, the inner and outer cages can be adjusted so close to the extreme positions (inner/inner and outer/outer) that the derailleur acts as a chain keeper.
This restores the ability to use what might be my favorite feature of twist shifters, the ability to drop from the high to low chain ring while simultaneously changing up 3 or 4 gears on the cassette. All done in one pedal rotation. This is the dreaded 0 change shift while moving from the inner front ring to the outer and vice versa. Traditional shifters may choose not to, or be unable to make this change in the same quick motion.
Liked 6 Times
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Dharma Dog
Bikes: Rodriguez Shiftless street fixie with S&S couplers, Kuwahara tandem, Trek carbon, Dolan track
Luis
Boomer
Liked 1,457 Times
masi61
Bicycle Mechanics
19
12-16-17 10:19 AM
MrClyde
Mountain Biking
4
11-24-10 12:37 PM
