Newbie ??. 53/42 with a 12-26 cluster means what??
Old 08-29-10, 10:02 AM
Bikes: Mongoose
As I read here, I keep coming across talk like...
"I prefer 53/42 with a 12-26 cluster"
I believe this is refering to the gear sizes, but don't really understand it. Is this the teeth count or what. It is not that I really need to know this stuff right now... just curious. Thanks.
Venturous is offline
Old 08-29-10, 10:04 AM
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1349 Post(s)
Liked 1,243 Times in 621 Posts
Yep, number of teeth on each chain ring and cassette cogs.
Fred "The Real Fred"
10 Wheels is offline
Old 08-29-10, 10:29 AM
Bikes: 8
Quoted: 7607 Post(s)
do the Math .. https://sheldonbrown.com/gears/
fietsbob is offline
cyclist2000's Avatar
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times in 604 Posts
That mean the front chainrings have 53 and 42 for the outer and inner rings, respectively. The 12-26 mean that the gear cog on the rear wheel has gears that ranges from 12 teeth to 26 teeth. What this will tell you is when the chain is on the 42 tooth chainring and 26 tooth cog gear, divide the 42 by 26 and this will tell you how many revolutions of the rear wheel for each revolution of the crank, in this example there is 1.6 wheel rev/crank revolution.
cyclist2000 is offline
Old 09-02-10, 04:33 PM
Bikes: Mongoose
Cool thanks! Neat stuff. I never worried about all this stuff when I rode many years ago as a kid. I just rode til I got to where I was going or got tired, then stopped. Now I have this need to understand everything.. Oh how did we ever get anywhere before cycling computers...
Thanks all..
Old 09-02-10, 04:42 PM
Rides again
HiYoSilver's Avatar
Bikes: Giant OCR T, Trek SC
Then go to https://www.jbarrm.com/cycal/cycal.html and put in the numbers. The primary display will give you "Gear Inches". Don't worry about understanding it, just use it as a relative number. The lower numbers mean it is easier to pedal. The higher numbers mean you go faster. The key here is to look at shifting % differences. Less than 3% means you have a duplicate gear. Between 10 and 12% mean moderate change when shift gears. Anything higher, unless it's on the lowest gear means a big difference in effort. You will either lose speed or rhythm when shiftiing.
The second screen will tell you how fast you will travel on flat land at a given gear choice and give you the speeds for different speeds of cadence, i.e, revolutions of feet.
Have fun playing, you can add and subtract gears and see how that would effect your shifting choices.
Another translation. The 12-26 is a good smooth cassette without too many horrible gear changes. When you combine with a 53/42 you will be able to handle some hills and flatlands. Steeper hills and mountains will be a challenge.
HiYoSilver is offline
Old 09-02-10, 08:35 PM
Yep, that is pretty "tall" gearing. The standard for a front crank is currently 52/39. Most folks would be more comfortable on hills with a rear cogset in the 12-28 or even 12-30 range.
You see a lot of older roadsters set up like the OP describes, either men were more manly back then or a lot smaller....
Bikewer is offline
sricabla
General Cycling Discussion
12
05-10-18 03:52 PM
Gdando
Classic & Vintage
9
02-01-14 11:30 AM
Bike Gremlin
Bicycle Mechanics
20
10-27-11 10:10 PM
divtag
Bicycle Mechanics
5
08-14-10 10:34 AM
cwiz
Commuting
2
05-21-10 11:49 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
