removing cup-and-cone bottom bracket without special tools
Old 09-03-10 | 07:56 PM
I recently inherited an old mixte frame and assorted parts. A "Made in France" Motobecane. It was neglected by its previous owner and many of the parts are seized (it took about 2 hours to remove the seat post yesterday). The bottom bracket either needs to be replaced or greased because it does not spin freely.
I got the crankset off after quite some effort (using a crank-removal tool). I got the lockring off the adjustable cup using a standard household wrench. I've removed adjustable cups before because they had wrench flats, but this is threaded all around. It does have holes around its surface, suggesting I need a spanner tool. But I don't have such a device and I prefer not to have to buy something I'd only use once.
Is there another way to remove this cup? Would a hammer/nail on the holes to create torque work (like removing the lockring on a freewheel)? Any suggestions before I damage the frame?
ghostm42 is offline
Reply
Old 09-03-10 | 08:08 PM
Old Fogy
I'd use a punch, rather than a nail, but adjustable pin spanners aren't very expensive, and won't deform the holes. I don't know if this one is big enough, measure the distance between holes. https://www.harborfreight.com/adjusta...nch-36554.html
waldowales is offline
Reply
Old 09-03-10 | 08:10 PM
17yrold in 64yrold body
These pin spanners are relatively inexpensive, so you may want to get the right one rather than chance damaging the frame.
badamsjr is offline
Reply
Old 09-03-10 | 08:16 PM
Bikes: Trek Madone 5.5, Klein Q Pro Elite, Surley LHT
First, DO NOT use a hammer and nail. We call people who do that hammer mechanics. Yes, this is a derogatory term. Second, soak the cup with some sort of penetrating oil and let it soak over night. Go the LBS and get a pin spanner. Now you should be able to remove the cup. IF YOU MUST USE A HAMMER GET PUNCH OF THE PROPER SIZE AND TAP, NOT HIT HARD THE CUP.
kycycler is offline
Reply
Old 09-03-10 | 08:26 PM
20 Anniversary
make your own spanner tool. some sheet stock and some old drill bits or some nails.
reptilezs is offline
Reply
Old 09-03-10 | 08:48 PM
JanMM's Avatar
rebmeM roineS
20 Anniversary
A hammer and nail set or punch works better on a lockring than it would on an adjustable cup. By working better, I mean that it can get the lockring off but has a high probability of damaging the part. Track down or make a pin spanner.
JanMM is offline
Reply
Old 09-03-10 | 08:49 PM
Bianchigirll's Avatar
Bianchi Goddess
Titanium Club Membership
15 Anniversary
Community Builder
if that frame says 'made in france' be gentle with the BB you may need to reuse it. take it to a shop and have it overhauled. it is easier and maybe the same price as finding tools
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Reply
Old 09-04-10 | 01:49 AM
BCRider's Avatar
Bikes: Norco (2), Miyata, Canondale, Soma, Redline
Listen to B'girl. You may well have a french threaded BB that is more difficult to replace than you figure at first glance.
BCRider is offline
Reply
Old 09-04-10 | 06:58 AM
A shop can pull the bb for you for a small fee even if you don't want them overhauling it. It may turn out to be pitted and useless and you can inspect it at home. Plus, make sure you are turning it the right way because French bbs did not use a reverse thread direction on the opposite side.
I guess you could probably reuse a pitted spindle by installing the crank opposite to the way it was before, so the fatigued area of the spindle is facing the other way. I have not tried this.
garage sale GT is offline
Reply
Old 09-04-10 | 07:03 AM
That would work only if the spindle is symetrical. Most aren't and have a longer projection on the drive side.
HillRider is offline
Reply
Old 09-04-10 | 08:08 AM
Kimmo's Avatar
The only wrong tool I'd attempt to use for the job you describe is circlip pliers.
...Or an unloved pair of longnose in a pinch
Kimmo is offline
Reply
Old 09-04-10 | 08:19 AM
curbtender's Avatar
15 Anniversary
Community Builder
Community Influencer
Bikes: Miyata 618 GT, Marinoni, Kestral 200, Soma double cross 2002 Trek 5200, KHS Flite, Koga Miyata, Schwinn Spitfire 5, Mondia Special, Univega Alpina, Miyata team Ti, Santa Cruz Highball, Waterford rs11
Are you replacing or servicing?
curbtender is offline
Reply
Old 09-04-10 | 09:29 AM
Bikes: 8
There is a Kludge, requires a Big Bolt a matching nut and a stack of split washers ,
with that common hardware you tighten and clamp the fixed cup
then unscrew the cup via hardware clamped onto it.
fietsbob is offline
Reply
Old 09-04-10 | 06:01 PM
15 Anniversary
Depending on the date, it's either French (both sides properly threaded) or Swiss (fixed cup moron-threaded). SR bottom brackets (which is what it would have come with, unless it's very old, in which case it's french threaded) say how they're threaded, but it's sort of cryptic. The clue is that the cups on the opposite sides say different things, which tells you that one of them is moron-threaded. (bottom bracket cups don't precess off. the left threading serves only to annoy.)
dscheidt is offline
Reply
Old 09-04-10 | 07:19 PM
No, I am referring to indexing the spindle, not reversing sides. Put it together so the pits are at 12 o'clock instead of 6 o'clock when the crank arm is at 3 o'clock.
Reply
Old 09-04-10 | 08:22 PM
Kimmo's Avatar
Nice tip.
Kimmo is offline
Reply
Old 09-04-10 | 08:44 PM
Thanks for the suggestions so far. I do have a pin-spanner for a watch kit, but I doubt I can get enough torque with that. And with all the seized parts, I'm pretty certain I'll damage the pins on a lightweight spanner.
I'm not that familiar with all the different BB threadings. Which way is the adjustment cup supposed to be turned to remove it for French, English, Italian, Swiss, etc.? Which way for the removal of the fixed cup?
Granted, I have no clue what threading this might be. I can take a look at the threads when I'm back with the frame (away for Labor Day weekend), though I do recall seeing "Tange" on the cups if that's of any help. If my attempts fail with my limited tools, I believe I can rent bike work space for $8/hr (QuadBikes). They should have a spanner of adequate size. But the harbor freight pin wrench seems decent. Does anyone know if the pins actually fit or if they are replaceable?
ghostm42 is offline
Reply
Old 09-04-10 | 08:49 PM
JohnDThompson's Avatar
Old fart
20 Anniversary
Community Builder
Unless the fixed cup is damaged beyond redemption, just leave it in the frame. Removing it can be a major PITA, and re-installing it without the proper tools is unlikely to get it tight enough to hold securely.
JohnDThompson is offline
Reply
Old 09-04-10 | 08:51 PM
Old fart
20 Anniversary
Community Builder
That only works with headsets, which do not undergo constant rotation. It is pointless with a bottom bracket.
Reply
Old 09-04-10 | 08:58 PM
curbtender's Avatar
15 Anniversary
Community Builder
Unless it's rusted in, that adjustable side should turn pretty easy now that you have the lock ring off. Wrap the threads a few times with duct tape and use some channel locks to spin it out. If you're having that much trouble on that side, forget the fixed cup side.
Reply
Old 09-04-10 | 09:43 PM
Kimmo's Avatar
+1 forget the fixed cup without the right gear.
Kimmo is offline
Reply
Old 09-05-10 | 12:13 AM
phidauex's Avatar
Spoked to Death
Bikes: Salsa La Cruz w/ Alfine 8, Specialized Fuse Pro 27.5+, Surly 1x1
The home-made tool described at the bottom of this page has saved me a number of times when it came to removing stubborn French BB fixed cups: https://www.sheldonbrown.com/tooltips/bbcups.html
Remember that if it is a French threaded bottom bracket, it will be "normal" right hand threaded, which means it was probably installed VERY tight so it wouldn't loosen itself over time. Expect it to be a bear.
-Sam
phidauex is offline
Reply
Old 09-05-10 | 02:27 AM
009jim's Avatar
Bikes: Giant CRX3, Trek 7100
I had a dozen bikes like this when I was a kid and always I used a hammer and nail or punch. I did make a mess a couple of times but most times little effort was required to turn the cup.
009jim is offline
Reply
Old 09-05-10 | 06:41 AM
I'd say a headset cup or cone is more likely to be loaded across its entire face.
If the pits on the right of the spindle are turned around to face UP instead of DOWN when you are pedaling, there's no load on them. When you pedal the LEFT side, the pits on the RIGHT side face down, but the spindle is being levered so the RIGHT side is pressing UP.
However, it may still be a bad idea because Sheldon thought English spindles could be adapted to French frames and cups. If the old French spindle pits even a little more, the hard particles that crumble out can then ruin the cups, then you won't be able to rebuild your BB with an English spindle. So it depends if you're going to keep using the old cups, or just want to squeeze a bit more life out of them to see if you like the bike before spending $50 on a new VO bottom bracket.
Reply
Old 09-05-10 | 06:45 AM
+1 it works. It makes little sense to buy the old BB tools if you're just using them to remove the old bb, although I seem to recall some of the VO French cartridges looked like they needed pin and hook spanners for installation instead of a Shimano-style tool.
Reply
