effing V-brakes, time to get calipers, need help on reach
i have a 2008 trek 520 with V-brakes - i'm over them. it looks like the frame is drilled for caliper brakes but i don't know which reach i should be getting? maybe someone out there knows? if not, how would i go about measuring the reach i need?
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Since it comes stock with stock 32mm tires, I'm guessing it will take at least a medium reach brake, probably around 57mm.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Measure the distance from hole in the fork to the center of the rim surface.
I have know idea but would guess that on a Trek 520 you would need long reach road calipers.
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
What's the actual problem with the V-brakes?
I see that on Trek's site, the current 520 comes with Avid SD-5 V-brakes and Tektro RL340 levers. Aren't those levers meant for caliper/cantilever (short-pull) brakes, not long-pull V-brakes?
The actual problem with the V-brakes is they suck a&s!! Adjusting them is a nightmare. I'd rather just switch over to calipers and call it a day!
Yup, Measure.. Maybe a dual pivot side pull will satisfy..
I've run cantilevers for decades they're OK, for Me.
but some people are not willing to see a job thru, and work out problems..
not all have mechanical aptitude.
What is a nightmare about adjusting them? I can't see removing the current brakes and reinstalling the new brakes being easier than setting up some Avid V-brakes properly. Can you check the model or post pictures of your brake levers (see JiveTurkey's point about compatibility).
I'm Carbon Curious
I got the same exact model year Trek 520. The Avid Single Digit 5 V-brakes work fine and V-brakes are dead easy to adjust. I don't understand your problem.
I'm Carbon Curious
The brake lever on the 2008 trek 520 is Dia Compe 287. Those are meant for V-brakes with long pull. You will need to replace the brake levers too.
Too much time and money for doing this downgrade. Just have a bike shop adjust the brakes if you don't know how to do them and call it a day.
Is your wheel out of true? V-brakes have a very low tolerance for wheels that are out of true. Is this your problem?
V-brakes are notorious for needing as straight a cabling path as possible. My LBS set up my 520 with a housing too long into the rear brake & this caused me all sorts of fits with brake rub until I figured it out. My suggestion is to inspect your housing path & try to make sure they are not causing your problems. FYI, the cable needs to enter so that the cable goes as horizontal as possible across the brake arms otherwise they will favor one side.
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
Quoted: 8 Post(s)
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Quoted: 13 Post(s)
Liked 5 Times
I also have a Ritchey BreakAway cyclocross frame and am using the Tektro Mini-V brakes with normal brake levers (campagnolo) and I find them to be pretty easy to deal with. OP, can you describe why your v-brakes are giving you trouble? I'm sure people here can post some good tips.
One thing I did right off the bat was use Jagwire brand noodles that have a brake adjuster built right in so that I could easily adjust the pad-to-rim distance on the fly. Then I set up the brakes so that the arms were parallel when engaged: this may require you to swap around the concave washers on the brake pad holders to move the pads either further or closer to the rim while at rest.
Quoted: 8 Post(s)
Bicycle Repair Man !!!
I'd also lose the Tektro pads and get Salmon Kool Stops... your braking will improve and your rim life will be extended.
Just overhauled my friend's 520 and he was stunned at how much better his brakes were after I was done dialing things in.
moogyboy
Bicycle Mechanics
7
03-04-17 10:54 PM
