Which handlebars?
Bikes: Cannondale F2000, Co-Motion Periscope Torpedo, and many more
Which handlebars?
The new bike came with the Ritchey Biomax Pro handlebars with the strange double bend on the drop portions of the bars. I can't find a comfortable drop position with these bars and am thinking of replacing them with a more traditionally shaped bar.
Ritchey Biomax Pro
Any one of you have a favorite bar for long distance riding?
Ritchey Biomax Pro
Have bike, will travel
FSA Compact;
Commuter & cyclotourist
Bikes: Boulder All Road, Surly Long Haul Trucker, Bike Friday New World Tourist, Breezer Uptown 8, Bike Friday Express Tikit, Trek MultiTrack 730 (Problem? No, I don't have a problem)
For a couple years I used the stock Kalloy drop bar that came with my Surly Long Haul Trucker. It has been OK for rides up to 200K (my longest so far).
Then I ordered Nitto Randonneur bars (42 cm) with the Bike Friday New World Tourist that I got to take to England and Ireland this summer (mostly work, a little vacation). I love them! The ramps are really comfy, and the flared drops angle the brake levers so that it's really easy to brake from the hoods. The ramps and hoods are closer together than on a traditionally bent drop bar, but it doesn't bother me. The flare also feels comfortable when riding in the drops or the hooks, since it's close to the natural angle of my wrists when I extend my arms.
When I got back home this fall and went back to riding the LHT, I immediately noticed that the Kalloy bars were a lot less comfortable than the Randonneurs. The bikes' geometries are almost identical, so I think it must be the bars. I've decided that the LHT is getting Randonneurs too.
I've also heard good things about the Nitto Noodle, which has a much smaller flare, as well as the Salsa Woodchipper.
Bikes: Colnago C-50, Calfee Dragonfly Tandem, Specialized Allez Pro, Peugeot Competition Light
Before you go buying new bars, have you tried rotating the current ones or adjusting the hood positions? You'll get a lot of recommendations for different bars that work for different people but you have to remember they may or may not work for you. We all have different sized hands, shoulder width, arm reach, handlebar rise etc. than you do. Don't forget, changing your hand position will/can change your seat position slightly. Will that cause you a problem? Everything is inter-related. It'd be a real bummer to have someone say "these bars are the best" only to have you buy them and find out too late they are worse than the ones you have. This is another reason that every serous long distance rider should be fitted properly.
i got a set of bars that have the wing shape at the top and i love them. i never used the tops of my bars until i got these. i did a 500 mile week this summer and the "new" hand position was very welcome when climbing and casually riding.
edit: they also make the invisible aerobar position nicer
By the way, the style of bars like the Ritchey Biomax are typically called "ergo."
I prefer ergo bars, so of course it's my bad luck to get stuck with round bars.
I agree with Homeyba that you should try adjusting them first.
Also, keep in mind that different bars often have a different reach, and this can impact your riding position. For example, the Biomax has a 75mm reach, and the Nitto Noodles has a 95mm reach. This leaves a little more room for your hands when you're riding in the hoods, but to maintain the same position you will want a stem that is 20mm shorter.
I agree with Homeyba that you should try adjusting them first.Also, keep in mind that different bars often have a different reach, and this can impact your riding position. For example, the Biomax has a 75mm reach, and the Nitto Noodles has a 95mm reach. This leaves a little more room for your hands when you're riding in the hoods, but to maintain the same position you will want a stem that is 20mm shorter.
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
I like the Salsa Moto-Ace Bell Lap. It's got the ergo hooks, a short bottom on the drop, comfortable shape to the bend (IMO), and I like the wide (12 degree, iirc) flare they have.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
I personally detest anatomic/ergo bars. I've never found one that allowed me to place my hands where I want in the drops. I prefer a more traditional (read: almost impossible to find these days!) bar like those sold through the Bicycle Quarterly website. (Yes, I drink the KoolAid.)
My favorites are the upswept Randonneur model, but I could understand how someone with a modern bike might not want such an old fashioned bend. For me, they are the most comfortable bars around. I agree with other posters who note that there is no single bar (just like there is no single saddle) that will work for everyone.
<edit> Traditional advice for folks with large hands was to use a deep drop bar. In my day that generally meant a Cinelli 66 "Campione del Mondo". I used it extensively for road racing but now find that my back doesn't tolerate such a low position.
I hated those Biomax shaped bars too (I had Salsa Poco's but same shape) - switched to Easton EA70, couldn't be happier.
When I looked it up just now I got this link - very good sale!
https://www.jensonusa.com/store/produ...r.aspx?sc=FRGL
Bikes: Trek Road Bike, Weyless MTB
Funny, I had the same experience (and am on EA70's right now)
That bump on the biomax bar created a sore / numb spot on longer rides, and there is no flat spot on the drop that is big enough to put your entire hand on.
I picked up some EA70's. They are pretty good. The flat spot on the drop is larger (though not huge). The only thing that you have to do is play with the angle of the bars so that the flat spot is at the same angle as your hands when you are climbing on the tops. Only after that angle is found should you finalize the position of your brifters (I had to re wrap my bars a couple times because of this).
Bye Bye
i found moving to something wider (i'm on 46 noodles) - and getting rid of the 'ergo' bend helped my comfort.
i also like the flat ramp on the noodles - lots of landscape on the top of the bars into the hoods for varying hand placement.
i used to run the salsa bell laps. like em enough, but the drops with the ergo bump were uncomfortable for extended cruising.
i tried some short and shallows too - but they were too short - so i couldnt get comfortable in the hooks.
pretty happy with the noodles - but i'd first try rotation / lever placement adjustments before buying new bars...
So long. Been nice knowing you BF.... to all the friends I've made here and in real life... its been great. But this place needs an enema.
Bikes: Specialized Roubaix Comp, Soma ES
I'm another satisfied noodle user. Although as someone mentioned, everyone is different and has different needs, I haven't run into anyone who's tried them and doesn't like them for long distance riding. What I like about them is that they got the angle between the drops and shoulders just right; I can rotate them so that both the drops and the shoulders have positions that don't make my fingers numb. With other bars, I've been put in the position of having to choose one or the other.
is The Stig
Bikes: 2010 Trek Madone 5.2, 2003 Trek 5500, 2001 trek 8000 disc, 2006 Rocky ETSX-30, 1999 Raleigh R-700
I just picked up the FSA k-wing, with the new top shape that's smaller and let's you wrap tape all the way up. They're effing awesome. Multiple centuries-0 numbness, great vibration dampening innthe drops, they definitely take the edge off big hits, and they're still stiff enough to race. After a race crash then 2 weeks later getting hit by a car on a training ride, the left side would flex by about 2" in the drops. Carbon cracked at the bend when the car hit my brake hood. Liked them so much I bought another pair.
Ride & Smile
Bikes: Giant OCR 3 (sold), Redline 925 (sold) Salsa Casseroll, Soma Saga, Kona Paddy Wagon?
I love my FSA Wing Pro Compact bars.
- Shallow drops
- Ergonomic top bar position by having a wider surface area
Only drawback is that your available accessory mounting space is limited on the top due to the flatness of the bar.
- Shallow drops
17yrold in 64yrold body
Is that the carbon bar that goes for $250+ ??
If so, that's a little rich for my blood. Or is there some place cheap to buy them that I don't know about?
I tried a lot of positional variation on the Biomax, but nothing clicked for me. It was just too hard to reach the brake levers and shift return key on my Ergos.
I'm curious about those FSAs that Barret showed us. I do like a shallow drop.
is The Stig
Unfortunatley they are ludicrously expensive for handlebars, but for distance riding the ergonomics just fit my hands so well, i just sucked it up and went for it, and i couldn't be happier. I know FSA doesn't make any Al bars with the wing shape up top, but they migt have the flattened out bend and same radius drop for less, which IMO are the two best parts of the bar, cadillacing it is already comfortable, you don't really need a weird shape up top. I just rode them on a bike at the store while i was shopping with my buddy (he is in the process of buying a new bike, so i ride ridiculous bikes to chase him when he goes for test rides) so i got off the bike with these bars ,and went i have to have these bars, didn't really do much research i just fell in love with them and went for it. They're not the compact, just the standard FSA drop, which i think is by far the most comfortable drops I've ever ridden. But YMMV with geometry/size/personal preference.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
FSA K-Wing is carbon but FSA makes some similar alloy versions, these are the wing pro and the price range is arount $60-$80.
