Green Light Triggers
At my work we keep a chunk of metal next to the automatic gate so when we need to get out after hours we wave the metal over the sensor area. Although sometimes it opens just by riding over it, the sensor that is. In CA for motorcycles there is a law the bike can proceed with caution if the light does not change.
§ 21800. Intersections without functioning traffic control signals or yield
sign, or with all-direction stop signs, except left-turning vehicle with
vehicle
approaching from opposite direction
(a) The driver of a vehicle approaching an intersection shall yield the
right- of-way to any vehicle which has entered the intersection from a
different
highway.
(b) (1) When two vehicles enter an intersection from different highways at
the same time, the driver of the vehicle on the left shall yield the
right-of-way to
the vehicle on his or her immediate right, except that the driver of any
vehicle on a terminating highway shall yield the right-of-way to any
vehicle on
the intersecting continuing highway.
(2) For the purposes of this section, "terminating highway" means a highway
which intersects, but does not continue beyond the intersection, with another
highway which does continue beyond the intersection.
(c) When two vehicles enter an intersection from different highways at the
same time and the intersection is controlled from all directions by stop
signs, the
driver of the vehicle on the left shall yield the right-of-way to the
vehicle on his or her immediate right.
(d) (1) The driver of any vehicle approaching an intersection which has
official traffic control signals that are inoperative shall stop at the
intersection, and
may proceed with caution when it is safe to do so.
(2) When two vehicles enter an intersection from different highways at the
same time, and the official traffic control signals for the intersection are
inoperative, the driver of the vehicle on the left shall yield the
right-of-way to the vehicle on his or her immediate right, except that the
on a terminating highway shall yield the right-of-way to any vehicle on the
(e) This section does not apply to any of the following:
(1) Any intersection controlled by an official traffic control signal or
yield right-of-way sign.
(2) Any intersection controlled by stop signs from less than all directions.
(3) When vehicles are approaching each other from opposite directions and
the driver of one of the vehicles intends to make, or is making, a left turn.
See section D 1
vehicle
different
highway.
right-of-way to
vehicle on
signs, the
intersection, and
See section D 1
Originally Posted by khuon
The metal in the drivetrain of most bikes should be able to trigger the more sensitive detectors and those with quadrapole loop configurations.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
Originally Posted by Rowan
Carbon frame and bars and wheels and pedals, stainless chain, alloy chainrings and Ti sprockets, pedal spindles... not much ferro maagnetic stuff there. But wait, there's still steel there in the ball bearings
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Bikes: Trek 930, Redline Conquest, Surly LHT, Surly Troll
Quoted: 18 Post(s)
Here's an letter written by someone who seems to know what he's talking about. I've been following his advice with good success. (WHen you get to this site click on "site index" under the main title and then scroll down to "Traffic signals, triggering them.") https://bicycleaustin.info/ A little further down in the discussion there is a guy who reports on a trial he did with the Green Light Triggers.
Ride the Road
Bikes: Surly Cross-Check; hard tail MTB
Liked 5 Times
I complained to our city's bikeway coordinator, and he gave me a personal lesson on how to trigger lights. He said that if I can't make them work, he'll talk to the powers that be to see if he can increase the sensitivity. I tried his technique this morning on a light I have never been able to trigger, and it worked.
In the attached diagram, I have marked the most sensitive portions of the sensors. Place you bike directly over that portion of the sensor. On rectangular sensors, that means your bike will be on the crack. Even if my diagrams are not perfect.
DEADBEEF
Liked 6 Times
Bikes: trek - lemond
Some lights have a light sensitve trigger. Only ones near schools, hospitals, firehouses, etc.
In Maryland, school bussses and other vehicles have a strobe light to trigger them.
Not sure how it would work for a bike.
Ride the Road
Liked 5 Times
Yep... I believe that was what I was trying to say in a previous post.
In a single rectangle sensor, you need to be on the wire on one side or the other, as close to the middle (from top to bottom) as possible.
In the case of two rectangles that share the middle line, you need to be in the middle of the middle line
DEADBEEF
Liked 6 Times
But the key is not just to be on the wire, but to be on the right place on the wire:
DEADBEEF
Liked 6 Times
khoun, would you say this diagram is more accurate?
Felt Z65
Bikes: 2007 Felt Z65, low-end 2002 Schwinn
I'm the original poster and I appreciate the good information starting when folks really started addressing my question. Thanks a lot people; I'm looking forward to trying these positions out.
The red light triggers do really work, though there are some sold at auctions that are too weak. I have one called RLC-40 from redlightchanger.com that's the most powerful made, but there are others you can search for using google or alta vista search engines. The key is to get one with a lifetime warranty that's coated with epoxy, and use it correctly by tracking your motorcycle right over the sensor wire marks on the pavement. I never get stuck waiting for red lights again, unless the traffic light is broken. Then all you can do is notify the local traffic department. Tennesse allows you to run the red light, but you better be ready to prove to the cop that the light is not working!
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
1/2 a binding 1/2 a brain
Bikes: Serotta Ottrott ST, Titus RX100, Seven Sola 29er HT in the works
The Institute of Traffic Engineers bears the greatest culpability since 1982 when it was sued over the death of a cyclist who was forced to run a red light.
Run the light ...just be careful.
Lone Fixie
Bikes: Fixie/SS: Specialized "Langster", Hobo SS: Schwinn World Sport
In most places they will have what is called a "Clear Box" (a little clearish cilinder next to traffic lights), what the purpose of this "box" is, is to set up a "trigger-based algorithm", they can be programmed for different numbers of lanes, set up to which lanes turn, go straight, and do both. It is quite effective, and costs less than the sensors that are dug into the ground. Also what these are good for is that they can be programmed in with the set pattern of emergency vehicles (most cities with these have all lights, firetruck, ambulance, and police all running on the same timers) when the "clear box" picks up one of these patterns it automatically/quickly turns green, allowing the traffic to be safer for the emergency vehicle and for the cross-traffic.
In most cities it is ILLEGAL to copy the patterns with strobe lights to turn the light for you, and the little metal magnet isn't going to do the job.
I'd scope all of the intersections that you usually ride and see if they have the rectangles in the ground or the "clear box". If you have the rectangles, go the the city/town hall and ask if it is legal to attach one of these to your bike, better to be safe than sorry.
"Like the ones you sell for $20. Sotty but your competition has you beat by $5 and has a better website"
I appreciate your feedback, and I'm sure the other changers have something that's good, and I won't knock other products, it's just that you usually get what you pay for. I've tried them all, and the one I have on my bike has nearly 10 times difference in strength, epoxy coated, patented material, lifetime warranty, vs. 30 day warranty, etc, etc, etc. and it's a good value. The RLC-40 RedLightChanger is more expensive to make, and you're right: the website isn't as fancy, but it's still the best product. And the company who makes it, whom I won't mention, will stand behind the product 100%, as all companies should. But I'm not selling the product here, and although it works on bikes, it's not made for bicycles, it's too heavy, at about 1.5 ounces, it's for motorcycles, and this is not a selling forum.
Robert
Robert
This website sells a traffic Light trigger, I bought one, was sceptical at first, but it seems to work... $10.95 - https://www.cyclecolor.com/id47.htm
Make sure you mount it at the lowest point on your motorcycle.
