Onguard sucks too - Just in a different way
Old 09-26-04 | 08:23 PM
46x17's Avatar
dances with bicycle
20 Anniversary
Just got an Onguard mini brute. Man what a beefy, tough looking lock!
BUT...
I am at home, my bike in my garage, I decide to try my new lock, I lock it on my bike, I try to reopen it, the key brakes in half, one part of the key is stuck in the lock and the other part in my hand!
After dicking around with this gosh darn P.O.S., I have the great idea to stick some tweezers in there an I manage to get the piece out and am able to use a spare key to open it. The whole process took 2 hours.
I was very gentle with the key, no excessive force used. These keys are just very, very sissyish!
I tried to snap another one (they give you 5 spares) by holding it between some pliers and twisting the other part with my hand. Only takes a little...ping! and it snapes.
Needless to say that silly lock is going back to the bike shop tomorrow.
46x17 is offline
Reply
Old 09-26-04 | 10:21 PM
catatonic's Avatar
Chairman of the Bored
20 Anniversary
Bikes: 2004 Raleigh Talus, 2001 Motobecane Vent Noir (Custom build for heavy riders)
hmm havent had that kinda luck yet, but i use an ultimate, maybe their keys are different.
catatonic is offline
Reply
Old 09-27-04 | 07:09 AM
dobber's Avatar
Perineal Pressurized
20 Anniversary
You Stud Muffin
dobber is offline
Reply
Old 09-27-04 | 08:21 AM
20 Anniversary
maybe get a copy made?
Phatman is offline
Reply
Old 09-27-04 | 08:47 AM
20 Anniversary
You are not a girly man, for sure!
wmt3rd is offline
Reply
Old 09-27-04 | 09:57 AM
46x17's Avatar
dances with bicycle
20 Anniversary
certainly not a girly man, but not a governor either. Definitely a girly man key though!
46x17 is offline
Reply
Old 09-27-04 | 04:48 PM
20 Anniversary
Sounds like the Quadrachain, that happened a lot with those. I've still got one with half a key stuck in it...
luckycat is offline
Reply
Old 09-27-04 | 04:51 PM
randya's Avatar
20 Anniversary
Bikes: who cares?
I just received a shipment of three OnGuard U-locks, but I haven't tried them yet. The keys are indeed pretty small, tho...
randya is offline
Reply
Old 09-27-04 | 04:52 PM
bostontrevor's Avatar
Retrogrouch in Training
I had one similar problem with my OnGuard Mini the day after I got it. I'm used to the insert-and-twist simultaneous motion that works so well on Kryptonites. I tried that on my OnGuard and found myself about 3/8 the way around with only half the key in. It took a little wiggling to get it properly position to get the key out. Since then I've been careful to fully insert the key before turning. I believe a shop owner posted a similar warning on the Krypto thread. Lesson learned.
Still, I would rather that sort of sucking (the kind where the onus is on me to not screw up and it's pretty easy to avoid) than the other (the lock mechanism is fundamentally flawed and there's no reasonable way to secure it).
bostontrevor is offline
Reply
Old 09-27-04 | 04:58 PM
46x17's Avatar
dances with bicycle
20 Anniversary
Yes, my scenario definitely sucks less, but damn was I wishing I could open it with a pen when that key broke.
46x17 is offline
Reply
Old 09-27-04 | 05:43 PM
Bikes: rockhopper, delta V, cannondale H300, Marin Mill Valley
Yeah, the onguard lacks the smooth flow action of a Kryptonite. I decided to break the plastic off the crossbar on my Ultimate Brute, making it easier to achieve the necessary full insertion and less bulky to handle. It's getting easier to use. Maybe your key had a shape that made it too thin in one spot. The keys do look weak, get it all the way in before turning.
qmsdc15 is offline
Reply
Old 09-28-04 | 07:18 AM
catatonic's Avatar
20 Anniversary
that's how most disc locks work, you must fully insert the key before turning...that's part of what makes them as secure as tehy are...extremely low tolerances.
Reply
Old 09-28-04 | 10:25 AM
46x17's Avatar
dances with bicycle
20 Anniversary
Yes, those keys have very low tolerances indeed...
46x17 is offline
Reply
Old 09-28-04 | 12:08 PM
randya's Avatar
20 Anniversary
Bikes: who cares?
I bought three Ultimate series OnGuard locks and I checked them last night. I had no problem opening any of them, and the keys, though small, seemed substantial enough to me. However, the keys for one of the three locks looked a little weaker than the keys for the other two, based on the amount of metal removed to form the 'cut' of the key, relative to the other locks' keys. And in fact, two of the three locks had a warning sticker on them that said the key needed to be fully inserted into the lock prior to turning. Apparently, OnGuard may be having problems with returns caused by partially inserted broken keys. Personally, I'd attribute this more to operator unfamiliarity with this type of lock mechanism and thus to operator error more than to flaws in the design. I didn't find the action 'rough', either; but rather, 'positive'. I expect the lock action will get a little smoother with use.
randya is offline
Reply
Old 09-28-04 | 12:25 PM
catatonic's Avatar
20 Anniversary
exactly...so long as the key is full yinserted before rotation, you should be fine.
Also note tugging on the key while doing the locking motion will cause a jam-up as well...the key to this is smoothness. I bet krypto is going to feel this pain too soon enough.
I had prior experience with this lcok type though, since the captive shackle lock i use on my chain has a disc-style cylinder as well.
Reply
Old 09-28-04 | 12:37 PM
absntr's Avatar
Frankly, Mr. Shankly
20 Anniversary
The OnGuard locks are ugly (sorry, just an aesthetical opinion) - and I was sort of freaked out by the five pack of keys that came with it.
I picked up a Kryptonite NY 3000 lock, the kind that comes with the flat keys but that too has similar pains with the OnGuards. I feel like I have to be so gentle with it, on top of the fact that the lock itself is super beefy. The key feels slightly flimsy and I have to hold the lock and carefully insert the key because I feel like I'm going to snap it. Sometimes (like all of you above) I have to make sure to insert it properly and get the right amount of contact/tension/alignment before it unlocks. I've found it's not uncommon to pull out the key and then try again.
However, it gives me great piece of mind.
absntr is offline
Reply
Old 09-28-04 | 12:47 PM
pitboss's Avatar
cxmagazine dot com
20 Anniversary
Bikes: Titus road, Fort CX
use this https://www.lowes.com/lkn?action=prod...2-930KADLHPFCC
with a NY Chain
pitboss is offline
Reply
Old 09-28-04 | 01:51 PM
s2sxiii's Avatar
All Things Go
20 Anniversary
Bikes: 01 bianchi pista, custom. 04 felt f-15, full record.
Originally Posted by [165]
cut off hand, attach this
https://www.lowes.com/lkn?action=prod...175654-572-141
use with fixie to vanquish evil
NO! It is the FARGATE! It is not some other kind of gate from a movie or TV show that I've never seen! Notice that it has a wheelchair and a pink mohawk? We're not getting sued!
s2sxiii is offline
Reply
Old 09-28-04 | 03:00 PM
pitboss's Avatar
cxmagazine dot com
20 Anniversary
you win, that would rule. S-Mart
pitboss is offline
Reply
Old 09-28-04 | 03:08 PM
s2sxiii's Avatar
All Things Go
20 Anniversary
What's that on your face?
old news of interest to ash fans....
s2sxiii is offline
Reply
Old 09-28-04 | 03:14 PM
bombusben's Avatar
Ðây la`xe Ðạp của tôi
20 Anniversary
groovy
bombusben is offline
Reply
Old 09-28-04 | 03:36 PM
I'm getting better w it. Almost smooth today. K mini had a self alignment feature w the bent end opposite locking end. Onguard requires more care getting cross piece all the way on and key must be fully clockwise to close. Some things that make it less convenient are what makes it more secure.
Removing the plastic makes it less ugly, less bulky, and easier to use but might be saving a step for thief using brute force methods.
Its a little bigger and gets around parking meter and top tube, w K mini I had to lock down tube to meter which was a little more difficult.
qmsdc15 is offline
Reply
Old 09-28-04 | 03:41 PM
46x17's Avatar
dances with bicycle
20 Anniversary
The bike shop took my lock back and refunded my money. Thanks!
They also agreed with me that weak keys are not a security feature.
46x17 is offline
Reply
Old 09-29-04 | 06:07 PM
randya's Avatar
20 Anniversary
Bikes: who cares?
FYI, the German-manufactured ABUS granit locks have sturdier keys and smooter action than the OnGuard Ultimate locks.
randya is offline
Reply
Old 09-29-04 | 06:48 PM
20 Anniversary
i hope i never get mass-produced in key form. that would be a lot of broken mes.
ephemeralskin is offline
Reply
