first report of the Cateye's new rear LED TL-LD1000
https://www.primera-bournemouth.co.uk...sories&ID=1443
I just got it today. It is about the size of a d battery. Bigger then I expected. Man is it bright. I bet it rivals my xenon flasher. Even with the lights on looking at it is hard on the eyes from arms length. Really easy to change the batteries just twist one end and there you go. You have two rows of lights and one button for each. You get blinking steady and running two speeds on each one. So you can get away with just one set running at a time.
I think this is a better choice overall then the xenon. Far longer run times and cheaper in the long run.
I bought mine off of eBay as it is not available yet for the most part in the us. Here si the fellow https://search.ebay.com/TL-LD1000_Lig...ertyZ1QQsotrZ2
Or just do a search for TL-LD1000
The box claims 100 hours. I think that would be with one set of lights running. But it is so bright one is about all you need.
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
This looks like something I may need to get.
However does it offer (non user hacked together) mounting options beyond seatpost? My under saddle bag hangs too low and blocks seatpost mounted lights.
Al
Al
Arizona Dessert
Liked 2,169 Times
Does it quick release from the mount? I haven't been able to zip tie my other light to the light strap on teh back of my saddle bag without it sagging badly or else requiring a total hack looking job.
It would be great if there was a second mount with a clip that these quick release lights could use intead of the post clamp. Especially when paying so much.
Al
Al
yes it is quick release. but since you don't have to remove it to change the battery you can have more options. myself I would use the quick clamp put a couple holes in it and use a zip tie to go around the triangle right below the seat.
(G) the xenon flasher is nice but it sure sucks up the juice. I had mine wired to some 4/3 4800mah cells. thsi is far less juice hungry
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Originally Posted by koffee brown
I would love to get my hands on that. Thanks for the heads up.
Koffee
Koffee
Originally Posted by jlin453
nice, but that's an expensive tail light
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
https://www.sheldonbrown.com/harris/lighting/index.html
Sheldon brown's got them in stock.
