So I was following the Park Tools instructions on adjusting my rear derailleur...
Bicycle Nerd
L-Limit Screw
The L-limit stops the derailleur from moving inward (toward the spokes). The limit screw does not make the derailleur move, pulling the inner wire makes the derailleur move. The L-screw allows the pulley wheels to shift the chain to the innermost sprocket and yet not shift off the sprocket into the spokes.
Shift bike to middle chainring (or smaller ring of double chainring bikes) and to second-to-innermost rear sprocket.
Pedal bike at a quick cadence, approximately 60 rpm or more.
Pull inner wire by hand to shift derailleur sprocket inward. When adjusting the L-screw, be concerned with two situations:
The inward shift from the second-to-innermost sprocket to the innermost sprocket.
How the chain rides on the innermost sprocket.
If shifting seems adequate, tighten L-screw 1/4 turn, and repeat shift. Continue to tighten L-screw until symptoms of too tight appear. These symptoms are that the chain will not complete shift even with pressure on inner wire, the chain hesitates before shifting inward even with constant pressure on inner wire, or the chain rattles excessively when riding on innermost sprocket
When symptoms of a too tight L-screw appear, loosen L-screw 1/4 turn and check shift again. Repeat process of shifting and correcting by 1/4 turns. When too tight symptoms disappear, L-screw is at tightest acceptable setting, and limit screw setting is done."
I am new to the whole "mechanics" thing but I followed the instructions on the front derailleur and got it to work great. Any advice/tips could be appreciated before I take it into the shop to have them look at it. I'd rather do it myself if I can, trying to learn. Bottom line, I couldn't get the rear derailleur pulleys perfectly aligned with the largest sprocket or two/three.
Bicycle Nerd
Too many variables. 10's are finicky.
a. You might be losing some throw if your cable isn't sitting right under the pinch bolt.
b. The end of the L-screw which contacts the little stop inside might be damaged/chewed up.... also, the little stop inside might need some love (filing).
c. Cables/routing and/or wacky angles/not seating in the cable stops.
Best place to start is describe when/why it started doing this. Did it ever shift right to begin with?
Even the brifters can do strange things after high mileage.
Bicycle Nerd
Well I didn't see it the first time so now I feel dumb, I see the hanger alignment link they offer. From the looks of it, you literally just bend it with physical force?
Bicycle Nerd
b. The end of the screw which contacts the little stop inside might be damaged/chewed up.
Just eliminate one thing at a time.
For the L-screw... shift it into the highest gear on the brifter/cassette temporarily. Then, see if you can push the derailer past that distance with thumb pressure. This wil tell you if the screw is being effective...make sense?
probably do this while turning pedals with other hand. DONT LET YOUR FINGERS GET CAUGHT IN THE RINGS.
Bicycle Nerd
Liked 7 Times
It sounds as if you simply need to add some tension to the cable. Turn the barrel adjuster counter-clockwise 1/2 turn at a time until the chain stays on the largest cog. If you turn it too far the chain will hesitate or refuse to go to the smallest cog.
no, no... not pushing on the hanger.
On the parallelogram part of the derailer body, where the name is printed.
That is the function of that screw, to stop the movement from going past that gear and into your spokes.
If you have the screwdriver on the screw and turn it, while putting some pressure on the derailer, you should be able to feel that.
Anyways, I gotta fly... good luck
Bicycle Nerd
Liked 7 Times
Also try hosing out the shifters with WD40. This will often restore shifting performance.
I do not believe adjusting the limit screws will help.
It seems that you have about hit the extent of what you can do yourself. The problem is that most of the time, it is a simple tension or such adjustment, but sometimes it can be the things that you dont think about or did know could happen that is causing the problem. If nothing from any other posts help, take it to a bike shop where they can look for the more complex reason that could be behind this
I was trying to guide him thru setting the L-screw back where it belongs, and then leave it alone... regardless, of how it shifts after that.
Realistically, the brifters control the shifting. Everything else is just in the path, unless cassette and chain have worn.
But, it has to be right.
Just take it in to the shop where you bought it. Better not to mess with it at this point. But if you must? I'd say just redo the whole rear derailleur setup from the shifter down.
I second the idea that you need to eliminate one thing at a time. Unfortunately with rear dérailleur issues, the first problem to eliminate should always be to check for a bent hanger if you can. Especially if you tried adjusting tension and limit screws and still have problems.
Deciding whether you want to buy the appropriate Park tool will depend on how many times you think you'd use it. I've already straightened 5 bent hangers in the last 18 months. But then again there are a lot of bikes in the family and I also do this for a few friends.
Bicycle Nerd
My cables needed adjusted, it was mostly all tension being the problem. Having messed with the limit screws, I had to readjust it all once I pulled the cables a little tighter. Learned quite a bit in the whole process. Probably would have taken a experienced mechanic 15 seconds, took me a day :-)
John Wayne Toilet Paper
Bikes: BH carbon, Ritchey steel, Kona aluminum
Since you had it in a trainer (and I assume that means the rear skewer was swapped for that duty), has anybody checked to make sure your wheel is all the way into the rear dropouts?
SpikedLemon
Bicycle Mechanics
8
06-10-16 10:54 AM
phylisss
Bicycle Mechanics
16
02-18-13 11:04 AM
Cliver
Bicycle Mechanics
4
01-16-13 04:11 PM
