road stem or mountain stem
Sheik Yerbouti
Location: in the state of Confusion, formerly from state of Denial
Bikes: 2006 Trek Pilot 2.1, Jamis Sputnik 2009
Aside from measurements, is there a difference. If the size matches my needs, does it matter if it's road or mountain?
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
No, it doesn't matter.
However, most road stems now take 26.0mm bars whereas MTB stems use the old 25.4mm (1") standard. 31.8mm (1 1/4", "oversize") bars are becoming more common for both road and MTB and will fit in any stem with 31.8mm handlebar clamp diameter.
Likes to Ride Far
Even some stems that have the same dimensions are now marketed as "road" or "mountain". Often, the ones marketed as mountain versions use a beefier construction and so are a bit heavier and stiffer. The differences range from minor to quite dramatic. Using a super feather-weight road stem for some serious MTB'ing might not be a good idea in terms of durability, and using an overly chunky MTB stem on a road bike might make for a harsh ride. However, in between the extremes the differences are often very small.
Sheik Yerbouti
Thanks, that's what I thought, but needed to know for sure before buying a new one..
