Ugly cracks on the sidewalls of Schwalbe Marathon Plus tyres
Hello,
Recently, I discovered some ugly cracks on the sidewalls of the two Schwalbe Marathon Plus tyres installed on my bike. I noticed them after having a flat on the rear tyre. Both tyres have the same symptoms. The tyres are 5 months old, and they have only 2.200 km.
I looked on the internet and I read on Schwable's website a new version of the Marathon arrived on the market. It's written :
"In everyday life bicycle tires are frequently ridden with insufficient air pressure and thereby become overloaded. After this kind of "abuse" cracks can appear, so Schwalbe redesigned the sidewall. The tire will now tolerate this "low inflation overloading" for much longer before ugly cracks eventually start to appear."
However, the min pressure written on the tyres is 3.5 bars, and I regularly check my tires pressures and I make sure it's always between 4.5 bars and 5.5 bars
Does anyone go such a problem with Schwalbe Marathon Plus tyres ? I sent an email to Schwalbe, but I still waiting for their answer.
Thanks !
Nicolas, Paris.
Thanks !
Nicolas, Paris.
Where's my dinner?
I have Schwalbe tyres on my older hybrid, they're City Jet's i think, they've probably done about 1000 miles and are cracked all the way around the edge where the tread meets the sidewall, on both sides. I'm not particularly worried about it they've been like that for ages and they're still just thin cracks. If they look like they're starting to open up i'll replace them.
Formerly Known as Newbie
Me, I'm just moving this thread from Commuting to Bicycle Mechanics, as per OP's request.
But to contribute on topic, I have used various Marathon versions over the years and have not experienced this. I run them at about 80-90 psi. Marathon Racers in my commuting use tend to last only about 2000-3000 kms though, so those get replaced pretty often in any case.
--Juha, a Forum Mod
--Juha, a Forum Mod
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Quoted: 19 Post(s)
Usually, I'd say tiny cracks are not of any concern, but yours do not appear tiny looking at those pictures. I'd say something is not right with those tires, and advise you to stop riding them until you hear back from Schwalbe. You did send them those pictures, did you?
aka Phil Jungels
I second the referral to Schwalbe -
I know you said you check and maintain pressure religiously ---- but those sure look like classic low pressure stress!
Ya know, like the guy on his cheap MTB almost running on the rims! Usually on the sidewalk, with the cheapest tires money can buy!
I would think they would be interested in them!
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Where do you store/park your bike? Try to find out if there could be a source of ozone gas from big electric motors nearby as on an airconditioning system fan and even elevator machine rooms. Ozone gas can cause/accelerate rubber degradation. Trashed new tires on my motorcycle within a year an a half parking it next to my apartment's mechanical room in an underground garage. There's a good chance that the manufacturer might give you replacement tires as you do not have that many miles on them and they most likely do not want you to resort to riding their cracked tires as it exposes them to litigation if you get injured. Just make sure you deal with them calmly (working with the LBS you might have bought them from will help too) and not get all hostile about it so they keep the discussion going for a good resolution for both parties.
Chombi
Chombi
Commuter
Bikes: Specialized Sequoia Elite
What size are the tires that you have? What is the max pressure rating of the tires that you have?
I run on Schwalbe Marathon 700x25C and overinflate them from the 115psi "rating" to 120psi. I typically get 1500 miles before the tread wears through to the "blue" stuff inside. I have not had a problem similar to yours in probably 10 sets of Marathons, although I did see delamination at the bead on one of my last tires... and I think this is due to my overinflation.
I would not ride on the tires you have... safety / personal injury issue.
Good luck getting replacements. I don't think that there is anything you could have done to have caused the problem.
The cracks themselves are not the ruin of the tire but those cracks allow moisture and grit to reach into the threads that make up the structural belting of the tires. Over time water and grit will rot and cut away at the cords and eventually the tire will fail.
I know that when I've looked at some Marathons I was amazed at how thick the sidewalls are. Being thicker the rubber is under more stress from flexing at the outer surface. Hence the splitting and tearing that you're seeing. Frankly I'll stick with the thin sidewall tires that don't suffer from such short term damage. This just confirms for me what I've thought all along about Marthons being over rated. There's a lot of other options with strong flat resistant treads that have thinner sidewalls for better overall performance and that won't suffer from this sidewall tearing.
Bikes: 2004 Giant OCR, 2002 Specialized Stumpjumper, 2008 Trek 6500 Disc
I had some bigger cracks that that, and someone suggested using Sho Goo on it. I used it and it added many many miles to the tire. The crack did not expenad after using the shoe goo.
nashcommguy
Bikes: Commuters: Fuji Delray road, Fuji Discovery mtb...Touring: Softride Traveler...Road: C-dale SR300
Nice. I just filed this one away for future reference. This is why I read the commuter forum everyday. One never knows what new tidbit of info will show up here...
Frankly I think I'd avoid any tire, regardless of how big a brand name on the side wall, that needs to be patched with Shoe-goo to get a full life out of it.
There are so many other flat resistant tires out there which do not suffer from having thick sidewalls that tear like this that I just can't see the appeal of the Marathons. It would be different if this were an isolated case but from the sounds of it this seems to be fairly regular for these tires.
The bike (and therefore the tyres) are stored outside. However, the tyres were 5 months old only, and it didn't rain a lot at that time of year. I don't know of any ozone source gas near the place were I park my bike. However, the city (Paris) is quite polluted.
Since the tyres were mounted on a bike I bought new, I went back to the store. They had a look at the tyres, and decided to replace them. However, they were not able to replace them with Marathon Plus, since they don't get them in stock. They offered me to install two Vittoria Randonneur.
Since I don't trust Schwalbe anymore, I accepted. Ever if those tyres are less puncture resistant, at least they won't explode.
I read on the internet some people got the same problem (cracks on Marathon Plus tyres) and got them replaced by Schwalbe. I sent an email to Schwalbe 1 week ago, and they didn't reply.
The Marathon sidewalls, even of the older design, don't routinely tear up like this. According to Schwalbe, if you keep them underinflated (for the load you have), you have a possibility of running into this problem. Underinflating your tyres is a bad idea anyway. OP states he hasn't done this, so in his case it seems he received a faulty tyre.
--J
Hi, if Schwalbe still haven't responded, The forum member "Kojak" works for them, you could try and PM him
https://www.bikeforums.net/member.php?153248-Kojak
Senior member
Quoted: 943 Post(s)
Liked 658 Times
I appreciate the fact that in your opinion Marathons are over-hyped. But exactly how do you go from there to stating this is common occurrence? If that were the case, we should have seen a flood of FAIL reports in Bike Mechanics, Touring and Commute forums at least, if you consider how popular these tyres are.
--J
--J
Quoted: 19 Post(s)
I think it might be simply a bad batch or similar. I've ridden quite a lot of Panaracer made tires, and while most of them were good, once in a while I would get a tire that would get cracks, really bad cracks in the sidewall like on your pictures, and it would start bulging eventually. That would take maybe a few months of riding, then I would buy a new one and no problems whatsoever. I think it's mass production and related errors that are bound to happen, in every batch of every product there will be some that are bad. But, that's what guarantee is for. I wouldn't discount Schwalbe so easily.
+1 on the bad batch. I am on my 3rd tire and I haven't had any problem. The crack I used Shoe Goo on was not a crack in the tire, it was more of a gash that I received from running over something. The tire was not that old and I did not want to shell out for a new tire just yet. But, the goo helped the tire keep going.
Advisor
The picture is difficult to see clearly but small cracks can be something called checking and it can be normal for some tires. It could come from low tire pressure or too heavy a rider. I had checking on a pair of Vittoria Zaffiro shortly from the start and I rode one 8,000-10,000 miles and the other for 25,000 miles. I wouldn't worry about it.
ColonelSanders
Hybrid Bicycles
57
09-04-15 08:33 AM
