10 speed chain & cassette w/ 7/8 speed chain rings?
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times
Has anybody successfully used modern a modern 10 speed chain and cassette w/ a crankset that has 7/8 speed chain rings? Any issues to speak of?
Bikes: Cannondale t1, Koga-Miyata World Traveller
I replaced a 10 sp Shimano 105 crankset with a Shimano LX trekking 9 speed crankset. It works fine.
No Talent Assclown
I've used the 9-speed chainrings with 10-speed components, but I'm quite certain that 8-speed and lower have a different width.
Fällt der Pfarrer in den Mist, lacht der Bauer bis er pisst.
then you grasp why they push towards 8>9>10>11? obsolescence
make reasonably priced parts
obsolete and make you spend 4X as much..
Fender1,
I have an old Specialized square-taper road triple crankset (24-38-50) from the 80's, (no pins, no ramps) and use it with new KMC brand 10-speed chain and Ultegra 10-speed cassette and it works just fine. Shimano long cage 105 RD, Dura Ace 7803 triple FD; Shimano ST-6603 brifters. All components are shifting/running just fine together...... no issues at all. Go for it!
2fer
2fer
Measure the thickness of the teeth. Normal 10 speed teeth are about .078 inch thick. Much thicker might be a problem. I've got an old 7 speed hybrid with steel chain rings that are .078 inch thick, just like modern 10 speed.
Quoted: 2026 Post(s)
Liked 1,096 Times
9 and 10-speed cranks are for all practical purposed interchangable. I'm using a 9-speed Ultegra crank with a 10-speed cassette and a 5.9 mm Wippermann 10-speed chain with absolutely no problems.
7 and 8-speed cranks have a slightly larger gap between the big and small (or middle if it's a triple) chainrings so a 10-speed chain may hang up between the rings if the shift is done under duress. Anticipate your shifts and there should be no problems.
This is what I found on Sheldon Brown's site when I was researching the samething. Hope it helps.
https://sheldonbrown.com/speeds.html
Last edited by simp77; 09-28-10 at 06:42 PM. Reason: only part of the post was visible
You won't have a problem with a 7/8speed crank. You may have a bit of noise but that's it. I tried a 10speed chain on a 6 speed freewheel and it would slip in some of the gears, but the freewheel is 25 years old so maybe no surprise there.
maartendc
Bicycle Mechanics
11
09-09-18 12:49 PM
Barrettscv
Bicycle Mechanics
9
09-14-11 08:48 AM
