1993 Campy Chorus
1993 Campy Chorus
I have 1993 8sp Campy Chorus components on my bike. I need to replace the headset, cassette, chain and bottom bracket. Not sure if I can get Campy parts for replacements. Are there alternatives if I can't?
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
Any standard 8-speed chain should work. I like the SRAM PC-58. As long as the BB threads, spindle taper, and spindle length are correct, substitution should be no problem there, either. Headsets have been pretty standardized for a number of years; if you replace the whole thing, you should be OK -- watch the inside and outside diameters of the races.
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
All your stuff is easily replaceable. I have 8sp Mirage (95 vintage), and had no problem replacing the chainrings and bb last winter (www.branfordbike.com). I have an Ultegra headset which uses replaceable sealed bearings, and have always used SRAM pc-68 chains.
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
I have 91 campy chorus and used the following when rebuilding my bike:
new Record threaded HS, New Record BB (make sure lenghts, threading etc are
correct) it works with the Chorus crankset. I'm using SRAM P58 chain without
any problems.
The 8 speed stuff is nice, I don't notice not having the 1 or 2 gears the new stuff
has. Cassettes can be found on e-bay, and Branford has a good selection of
8 speed parts. The one thing that is becoming scarce (according to LBS) are parts
for the shifters, I had mine rebuilt and ordered extra parts to keep should I need
another rebuild. The part to convert to 9 speed (new gear) is almost impossible
to find now.
Marty
any problems.
to find now.
Marty
Sono pił lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
Campy is known for its "rebuildability"; almost all parts can be ordered from Campagnolo one yar or the other. Now, I really don't know how this works in real life, what the procedure is and so on. I'd recommend you get in touch with a good store that caries Campy components and go from there.
Also, evrething that was posted earlier about the part replacement by other user holds. So I gues it's up to you. If you want ot preserve the originality of hte bike you can try and get all original parts. Otherwqise go with non-original alternatives.
lurking nightrider
A Chorus 8-speed cassette is on my buy list too. I've seen them go on Ebay for about 30 or 40 bucks new. Perhaps a Record cassette would be a second choice?
I'm using an SRAM PC68 chain on my 8 speed. The PC58 is a great choice too.
Bottom bracket? Again, Ebay has a few up for bid from the early 90's as of this very moment. If your chainrings need replacing you might consider buying a newer model Chorus crankset, say a 2002 or 2003. I've got a 2003 10-speed crank/bottom bracket I'm using with my 8-speed drivetrain. To improve front derailleur shifting, due to the wider 8-speed chain, I've installed Letour .4mm spacers between the inside of the outer chainring and the crankarm. These are available at Branford Bike.
"If there hadn't been women we'd still be squatting in a cave eating raw meat, because we made civilization in order to impress our girl friends. And they tolerated it and let us go ahead and play with our toys." Orson Welles
Another question. Can I replace the cassette myself or do I need to have it done at a shop? Branford Bike does have a lot of good stuff and I found an 8 sp cassette and chain. I would think I should be able to replace it but I've never done that before.
Quoted: 15 Post(s)
Liked 9 Times
cassette replacement is a piece of cake as long as you have the right
tool to remove the lockring. I bought a 12-23 8 speed cassette, nos for
$25 off of e-bay.
Branford bikes is the place I learned about the unavailability of the upgrade
bits for going from 8 speed to 9 speed.
Be careful of the cassettes tho, there are different splines for Record/Chorus
and Daytona/Veloce etc. The two are NOT interchangeable.
Marty
$25 off of e-bay.
Marty
lurking nightrider
Record and Chorus are completely interchangeable.
Quoted: 15 Post(s)
Liked 9 Times
thanks LittleGinseng for the clarification.
Record and chorus are interchangable, but not with Daytona/Veloce etc.
(but daytona/veloce/mirage are interchangable).
Marty
Marty
