installed bottom bracket backwards
I must have gotten confused with the bike upside down while installing it.
It was so tight installing it, I don't think it will come loose.
I have about 75 miles on it so far.
Is it a big deal to leave it?
Domestic Domestique
Bikes: Brand New Old Catamount! Schwinn Homegrown, Specialized FSR, Salsa Vaya, Salsa Chile Con Crosso
Liked 6 Times
What do you mean backwards? The left cup is in the right side and vice versa? If that's the case, the frame material may decide the fate of your bike.
Cartridge French and Italian , being RH thread both sides it.s possible, if its loose ball you could have just fit the axle in backwards
putting the rh thread end in the LH threaded frame ... wow thats gotta be worthy of a Darwin award ..
Well the threads in the bottom bracket have been fubared since day one. English thread BB, yes left cup on right, right cup on left. Funny thing is I just removed it, and re-installed it properly and it threaded in perfectly with no excessive force. As for the darwin comment..uhh.ever heard of dyslexia?
I should have taken a picture to who it installed in both manners.
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
I'm confused...maybe it will be more clear if I type it out.
Right side BB is reverse thread...left side of frame is not. Left side BB is standard thread, right side of frame is reverse thread. How can you even start either side threading?
Nope...not more clear now that I've typed it out.
Glad it worked out for you though.
2014 Specialized Roubaix2003 Interloc Impala2007 ParkPre Image C6 (RIP)
I'm not actually that surprised. I've found that some frames are a very sloppy fit on the threads to where the fit is so wobbly I'm surprised that they don't strip.
Compare the loose fit of many BB shells to the the thread fit on a camera filter lens. It's like night and day for quality.
Engineer
Bikes: 1989 Krapf (with Dura-ace) road bike, 1973 Sputnik (made by XB3) road bike , 1961 Peugeot fixed gear, 2010 Trek 4400
Quoted: 38 Post(s)
About mounting backward.. for left/right thread is plain stupid, but is achievable if the threads are already mashed.
I installed the spindle backward on purpose to adjust the chainline (i swapped double rings with single ring for fixed gear).
Also on italian/french (same thread on left/right), the cups have different lengths from the face to the raceway of the bearing, so that gives more options to adjust chainline by installing the cups backward, or the spindle backward or both.
benbunton
Classic & Vintage
14
11-01-13 09:04 PM
