Advice on a removing crank with rounded bolt
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I don't have an attachment to saving the crank arm, so I'm wondering if it would be easier to cut through aluminum than to try to drill out the bolt.
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
If you are also not attached to the BB spindle, you could remove the other crank arm and avoid that bolt altogether.
jim
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
Oldtimer
Bikes: 1972 Raleigh LTD, 1985 Cannondale SR300 (2), 1986 ROSS Eurotour, 1991 Giant Sedona MTB, 1992 Trek Antelope MTB
A picture would go a long way toward fully explaining the situation but you may be able to drill the bolt for an Easy-Out. That might be easier than cutting the crank off.
You might be able to use a dremel to cut a slot in the bolt head and remove with an impact driver. That is, if you have those tools, and the patience to grind the slot.
Quoted: 525 Post(s)
Liked 931 Times
Cartridge BB and unfortunately not a hollow spindle. Everything else on the bike has come out pretty easily. I accidently put my 15mm peanut butter wrench on the bolt before I realized that it was a 14mm bolt. Now it slips with the 14mm socket on it. I started drilling a couple of holes in from the side of the crank arm hoping that I can at least get some WD40 to the actual threads instead of just on the bolt head.
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
Don in Austin
Engineer
Bikes: 1989 Krapf (with Dura-ace) road bike, 1973 Sputnik (made by XB3) road bike , 1961 Peugeot fixed gear, 2010 Trek 4400
Quoted: 38 Post(s)
Take a hammer and mark the center of the bolt with a punch
Drill a hole in the center
Use an extractor to remove the bolt:
just pokin' along
Quoted: 11 Post(s)
I had a similar issue and found these locally. As long as there's enough space to fit the tool, you can get plenty of leverage on the bolt without concern over tool slippage or breakage.
https://www.mysears.com/Craftsman-Bol...er-Set-reviews
Bikes: Alloy Mountain Bike
Ask around and see if any of your friends have a set of 'Metrinch' brand spanners.
They are unique in that they drive on the flats and not the angles of a nut or bolt, allowing you to remove rounded bolt.
Regards,
Roger
Regards,
Roger
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
OP: We've removed cranks at the shop where the crank didn't need to be saved - 1 minute with an angle grinder on an AL crank is all that is needed to remove it.
Engineer
Quoted: 38 Post(s)
Works every time, I have used it numerous times especially in broken bolts to remove the rest of the bolt still inside. Well that's why it's called a SCREW/BOLT EXTRACTOR
Extractors are good for removing broken off pieces off pieces of bolts stuck in a tapped hole for some reason, not for removing bolts with stripped heads.
My advice: Drill through the head of the bolt working your way up to a size at or near the diameter of the bolt (5/16" or 8mm) and the head will pop right off as the tension exceeds the strength left in the small amount of bolt cross section left. Don't go any deeper than necessary and you will likely salvage the bottom bracket along with the crank arm. The remaining "stud" in the BB spindle will likely unscrew by hand. Attempting to use an EZ-out on a fully tensioned bolt is a recipe for breaking an EZ-out that offers zero benefit over drilling the head off.
Bikes: Tons
Either an angle grinder or what Joejack said.
I'll add to that and say if you can find left handed drill bits, use those. They work great for this kind of thing. I've used them at my buddy's shop on numerous car bolts that were stuck.
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
That is just an example.. they come in sizes for removing bolts from M4 (smallest) to M30 (this is some serious stuff!). They have tapered left hand thread that as you turn them into the loosening way it will bite into material of the bolt, wedge itself in, lock into place and for sure it will at some point turn the bolt loosening it. The size of this thing is accordingly to the size of the thread not of the head.
Do you remember which size(s) you used? I'll have to pick some up in case I run into a similar problem some day (which with my buying habits I'm very likely to). Thanks for the tip!
