Remove fork stem spacers = move seat slighly forwards?
Bikes: RichardZEP
Quoted: 21 Post(s)
Hi
I'm looking to get better leverage when climbing steep hills, like 14% and up. Question for those who have removed the spacers on their fork stem to get a lower handlebar position for climbing; have you noticed that you needed to move your seat slightly forwards or that hasn't changed?
mechanically sound
Saddle position trumps handlebar position IMO. IOW, no. I will temporarily slide to the front of my saddle for steep climbs, however.
Bikes: RichardZEP
Quoted: 21 Post(s)
I do the same, move up the saddle, but the front wheel comes up anyways, enough to through me off balance. Sometimes I can muscle it and keep moving up while the wheel is popping off the front, but I can only do it for a short while.
Hi
Bikes: RichardZEP
Quoted: 21 Post(s)
So i researched used bikes for sale, specifically those from ex-racers, and they all have the spacers removed.
Not sure what to think at this point! lol
Just remember, there's a reason they were racers and there's a reason they may be ex racers
Bikes: RichardZEP
Quoted: 21 Post(s)
For sure there's a greater risk of endo's, but they must be using techniques to counter that, like sliding the butt off the back of the seat or lifting the front wheel on a angled drop. Someone correct me if i'm wrong.
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
I used to race, but that doesn't mean I knew everything I was doing. Having come from a road and track background, I always felt too upright on my mountain bikes and had no spacers with the stem flipped DOWN. It seems that a lot of people used that setup in the 90's because we just didn't know any better, and I'm sure there are riders who still haven't gotten the message.
It's like riding a bicycle
Dropping the stem a few mm or even cm isn't going to make the difference between an uneventful descent and an endo into a ravine.
I guess if you were almost endo'ing on a regular basis with your stem where it is, there would be risks to lowering it.
Bikes: RichardZEP
Quoted: 21 Post(s)
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
I decided to see why everyone ditched their bar ends and went with wider riser bars. My grips now about the same height as my seat (back then, it was 3-4" below). I haven't found a reason to go back.
mechanically sound
Also, you can change your handlebar position without having to change your saddle position. My saddle-relative-to-crank position is the same on all my bikes(road,mtb,commuter) but the handlebar positions vary quite widely.
Bikes: RichardZEP
Quoted: 21 Post(s)
Hi
I left the spacers as is and just flipped the stem. Just doing that makes quite a difference.
I may later on remove the first spacer, which is a 1/4", to see how much a difference it can make.
Oh definitely, there must be a few of them that have stopped racing because of that. But for the sheer number of racers out there, it would seem to represent a small percentage.
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
Now that I'm home from work and can access photobucket, here's my set-up from 1995 to 1998
And here are my more recent rides.
Bikes: RichardZEP
Quoted: 21 Post(s)
[QUOTE=urbanknight;11589293]Now that I'm home from work and can access photobucket, here's my set-up from 1995 to 1998
Interesting transition! It seems you went a slightly more aggressive position with the razorback than the specialized.
Velo Mellow
Fitting Your Bike
34
10-13-14 10:09 AM
