Wheel problem on new bike
In the spring I bought a Bianchi Brava. After a couple hundred miles I had spoke problems and the LBS took care of it. Less than 75 miles later is happened again only worse and again the LBS took care of it. Less than 100 miles later, this time it was basically unfixable so I shelled out some bucks for a better wheel. My question is: Why won't Bianchi replace or compensate me for my wheel as there was no abuse and I am 185 pounds. If I by a road bike, shouldn't I be able to ride it and expect the wheel to hold up at least the first few months or is this just something that happens and I should just accept it?
Thanks!!
Thanks!!
yes... You're on my left
Bikes: Specialized FSR XC/Trek 930
Thanks!!
Thanks!!
Did your LBS contact Bianchi about replacing/repairing the wheel? Did you ask them to after the second incident? The first one I can understand (sort of), Things loosen up at first, but after a readjustment they should be fine (although a well built wheel should not). I would suspect a bad batch of spokes, and Bianchi should support their products, but it's possible that now, after so much (probably) unauthorized work, and a (possibly) unauthorized wheel change, they may not feel responsible. Harsh I know, but business.
Bianchi was contacted after the 3rd incident and they are not giving me anything.
I feel your pain then. Shame on Bianchi... I always thought they were better than that.
Could there be something in the way I ride that would cause this? I weigh 185 pounds and ride often but only on roads. In my younger years, the wheels lasted forever and took a lot of abuse.
Thanks for all your help on this!
Bikes: Peugeot Hybrid, Minelli Hybrid
I think the original wheels didnt have spokes that had been tensioned and stress relieved properly. I dont think your shop did a good job when you went back the first time.
Did anybody contact the wheel manufacturer. I agree Bianchi should stand behind the wheels but my guess is they didn't make the wheels somebody else did. Have the bike shop contact the wheel mfg.
Two wheel escape!!
Bikes: Trek 5200
Don't give up...I had a great experience with Bianchi in replacing my frame. The FD hanger split and they replaced my Giro frame with a new Repart Corso AL-3. Who mfg. the wheelset? Have the LBS go to them for replacement.
185 lbs. is nothin....I'm 195 and have been on a set of Bontrager race for 10K miles and still no problems.
