So what's the downside of using MTB components on a road bike
All work and no play...
I have an XTR rapid rise derailleur on my '98 Fisher Joshua Z0 (yes, thank you, it's a friggin' awesome bike). While out riding today I re-realized that the XTR derailleur on that bike is truly awesome. Are there any good reasons for not considering an MTB derailleur for my TT build?
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
it's a bit heavier
rapid rise reverses the direction of the shifting, so your levers will do up on a down and down on an up.
it's a bit slower, not that most people would notice it, due to the angle and distance from the top pulley to the cassette. closer and more parallel to the ground gives smoother, faster and crisper shifts.
other than that, there's no real downside.
oh, I think I've heard that the latest generation of XTR rear derailers do not match up to road cable pull ratio. The front derailer never matched up between road and mtb, but barcons in friction mode could fix that.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
STFD
Bikes: '80 Windsor Carrera Sport, '02 Specialized Sirrus A1, '10 Giant Escape 2
Aside from the technical things AEO metioned, the only issue might be whether you care if road snobs will laugh at you. Personally, I don't care whether people don't approve of my bike, but some people worry about such things.
Pro Paper Plane Pilot
I think MTB parts are often seen with touring road bikes like the Deore models. I am thinking they are prolly more "hardy" than the road bike cousins.
Pwnerer
Broom Wagon Fodder
Bikes: Fuji Supreme; Kona Wo; Nashbar road frame custom build; Schwinn Varsity; Nishiki International; Schwinn Premis, Falcon Merckx, American Flyer muscle bike, Motobecane Mulekick
Quoted: 52 Post(s)
Liked 64 Times
Some mountain derailleurs don't have the barrel adjuster on them -- I have an LX that does and an XTR that doesn't. If it doesn't you will have to find a place to insert an in-line adjuster.
Bikes: Nishiki Prestige, Reign, IH Warrior, Rockhopper, Brompton, Q-Bike, Forever, Free-Ride, Dahon, Merckx Premium, Litespeed Teramo, Raleigh MTi 1000, Motobecane Fly Ti, OnOne 456, Kona Unit, Transition TransAM
B) What's a "REAL" roadie and why do you care if someone laughs at you? I've never actually ever witness anyone laughing at others in public. I've also read that "Real roadies" will laugh under any of these other circumstances as well: Wearing a Camelpak; wear MTB shorts; ride without road specific shoes with their mating clipless pedals; and don't meet up at the local StarBucks before every ride.
C) Why would anyone bother to laugh at someone that might need more gearing? At least you're out there riding. Isn't that what matters?
If it works on your bike, use it.
tk
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
I have an XTR derailleur on my "road bike": https://home.comcast.net/~jeff_wills/...-grr%20006.htm . My low gear is 24/34... 18 gear inches. I used this gear on a long, 10 to 15% climb last summer. I get along fine with "real roadies".
Jeff Wills
Jeff Wills
smitten by саша
Bikes: Salsa La Cruz with Rohloff; mutt parts
i used to run an XT rear derailleur on my 1x9 road bike (with Ultegra brifters). it would confuse many roadies as i passed them, up hills and down; but mostly up hills. for my riding style, i found that the rapid-rise was less necessary on road riding than MTB, because i could pretty clearly anticipate hills and i never up-shifted more than one gear at a time.
here's to never mashing and happy knees.
Liked 7 Times
I don't understand why you would want a mountain type derailleur on a TT bike unless you plan to use it with a mountain cassette for a mountain time trial.
Mountain type cassettes don't work so well on long flat rides because the ratio jumps are too wide and cause big changes in cadence.
Having said that, if you need it you need it.
It begins to function like a Touring bike, and the guys that can climb in a 39/23 gear will hammer off ahead.
It's about tuning the range of gearing to your needs and to hell with "style". Because I used to live in a location where there's normally heaps of hills I used MTB cassetes and derraileurs on all my bikes so I would have the range of gearing options to deal with all the climbs that came up. However I've recently moved out to where the valley around me is very flat with hills around the edges. I'm finally in a place where I can "safely" set up a bike with a proper road cassete and derraileur. But I think I'll likely keep a triple up front just in case I want to explore the hills around the edges now and then.
17yrold in 64yrold body
Probably true about guys that can climb, but if the OP needs these gears (like me and others), he would NOT be keeping up with them in any event. I do not really care if 'real road riders' think my gearing is funny. I use what works for me, and they can go 'hammer off ahead' all they want. I have 24/34/52 with 11-34 9spd. The only hill I have had to walk is the VERY steep section at the top of Mt Diablo, but I am not alone there.
AdamDZ
Bicycle Mechanics
36
02-14-10 11:39 AM
