Whats wrong with my bike???
ok i have some chain slack when the right crank arm is facing foward my chain is loose whenn the left arm is facing foward the chain is super tight whats wrong with my bike??
its not a stretched chain..? HELP!!!
Bikes: 1986 Fuji Allegro 12 Spd; 2015 Bianchi Kuma 27.2 24 Spd; 1997 Fuji MX-200 21 Spd; 2010 Vilano SS/FG 46/16
Quoted: 5 Post(s)
The front gear or rear gear isn't perfectly round. Might be that the front crank chain ring needs to be loosened, adjusted for being centered (if that's possible) and retightened ?
Yeah. Sounds like a bad chainring. Might just need to be re centered.
It sounds like your chainring is not centered on the cranks very well. Read the paragraph labeled "chain tension" on this page, it'll sort you right out.
https://sheldonbrown.com/fixed-conversion.html
Bikes: Raleigh Record Ace, Windsor The Hour
