Brake Levers and my Crossbar
I have an older peugeot from the 70s I've made into a fixed gear, I want to install an e-brake with a cross-top lever.
Will a mountain bike lever made for v-brakes work? Those seem to be the only levers that fit my 22.2mm french handlebars from the time.
Constant tinkerer
Don't get a lever for V-brakes. You won't have enough mechanical advantage with your caliper brake. You'll pull really hard on the lever and not get enough "power."
Any lever made for cantis or caliper brakes should work, provided it has the correct clamp diameter. There should be lots of options out there.
Constant tinkerer
I'm not sure if you're looking for something new, but most mountain bikes made up through the 1990s had cantilever brakes. Almost all upright handlebar bikes have 22.2mm bars, so a lever from any old mountain bike should work.
Edit: oops, looks like you found your solution.
Your cog is slipping.
I was told by my shop they didn't sell shims and that I would have to make one myself. Anyways thanks for the help I just need to find an older mtb lever
Bumping this because now that I have a proper lever the nipple on the end of my brake cable doesn't fit the lever
*rage*
I guess I will be forced to go to a bike shop
*rage*
