What is bike stability to you?
Evil Genius
Bikes: '92 novara ponderosa, '74 schwinn le tour, Novara fusion, novara transfer, novara randonee(2), novara careema pro, novara bonita(2).
I've heard and read many discussions that state things like "Bike x is really stable." or "Bike y is twichy.". Well I'm here to ask what makes bike stable. I don't mean geometry, I mean its handling. Do not start talking about rake, trail, center of gravity, or wheelbase, this thread is not about those things and most of the "informed" people are misinformed about those items anyhow.
In other words do you consider stability to be; a bike that tracks straight and turns slow, one that is neutral in corners, that fights to stand up in corners or tries to fall into the corner, a bike that does S turns quickly without loss of composure, low speed, cruising, or ZOOM down the hill, etc.?
Aaaand.... discuss!
[edit add] In other words, how would you describe stable handling or a stable bike?
Aaaand.... discuss!
Stable to me is defined by my old Serotta:
1) I can ride it no hands without even thinking about balance
2) Lean it into a corner and it almost steers itself through the curve.
Damn I loved that bike. It was so stable in a corner... like it dared me to lean further.
Evil Genius
Just to clarify, how was it at turning corners no handed? By "steers itself through the curve" do you meen that it was neutral? Neutral in that it didn't want to stand up or 'fall' into the corner, without much handlebar input.
The Specialized I ride now feels like you need to hold it in place when cornering... the Serotta just leaned in and stayed where you put it. I noticed it the first time I rode the bike. I felt like the bike did the cornering for me.
If you're familiar with how oval track racecars are setup with larger tires on the outside to make the car naturally turn then you've got the idea.
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
The most stable bike's my daily ride to work. Specialized 04' hardrock with 1.95" hemisphere ex semislicks. I can go around corners at 15 mph no handed and can spin almost 130-140 rpm without my ass bouncing around no handed. Can also fly into potholes no handed.
My OCR2 however, seems to have straight forks and is very twitchy.
hello
I don't know if this is a criteria for slow speed stability.....
My most stable bike can be ridden no handed at 3 mph. My least stable bike requires at least 10 mph to be ridden no handed.
Chairman of the Bored
Bikes: 2004 Raleigh Talus, 2001 Motobecane Vent Noir (Custom build for heavy riders)
stable to me is two factors
a) how well it can stay upright (minimal side-to side motion while in the saddle) while sprinting. i have one bike that it just cant be done with, it seems to just not work out...that bike's my commuter...my other bikes...you can go well beyond 100rpm on the pedals and still have that bike feel like you were cruising it at 60rpm.
b) the real important one -- how solid it feels around corners. A stable bike should not fight you around a corner. Once you get that ahndlebar and angle down the bike should pretty much steer itself. My commuter has some issues with this, but that bike is slightly malsized and, frankly, could use some upgrades..but it's a commuter...no upgrades for it. My Talus just loves hard corners...it takes corners and slalom duty with a very snappy and solid feel to it...even when I'm pushing the limits of the bike I still feel fully confident in the bike's ability to pull the turn off.
I dont ride no hands, so I dont use that as a factor.
Bikes: Trek 4900
I had always thought of the way a bike "handles" with no hands as a combination of various differences in the geometry of that particular bike. I was not even making the connection between great stability and one with not so good stability. This being the case, my Trek 4900 has less than acceptable stability as there is no way to safely remove your hands from bike without the bike going in every direction but the one you want. Can you go into more detail on this "stabilty" issue? I am finding this quite interesting. Thanks!! wfin2004
Evil Genius
Originally Posted by wfin2004
... I am finding this quite interesting. Thanks!! wfin2004
Any fully loaded touring folks out there? I'm sure you have a unique veiw of stability.
Quoted: 19 Post(s)
Liked 7 Times
For me its about handlling on a fast descent. If the bike feels neutral and has "thought control" steering, then descents are much easier. Ive had some really scary moments on big , fast, steep descents with twitchy bikes.
Its less about balance and weight distribution. I find that on a good bike, I can load up a single pannier and it stilll handles well.
I just had to switch forks on my nicest handling bike, and it feels a whole lot worse now. Maybe I just need to get used to the new feel.
Just ride.
I don't see twitchy and stable as opposites. Twitchy is just a derogatory (sp?) term for nimble handling. Nimble or stable... either can be found executed poorly in a design. Either can be a liability in the wrong situation. I have 3 bikes that fall into 3 decidedly different categories... a Bridgestone RB-T, Litespeed Classic, and Cannondale R3000.
The Bridgestone has a low BB, and a long wheelbase. I think it's along the lines of a touring geometry. It's a land-yacht, just no fun to ride on the road. Dead-stable and boring. Since I can mount wider tires on it (700x32, 700x35), it's been relegated to commuter and ride dirt road use. It's good for that. Disclaimer: I'm not dissing touring bikes. This was an inexpensive, heavy bike... not a good example of a touring design.
The Classic is an all-around recreational design. The handling is not boring, but it's not in the realm of 'if you sneeze, you'll run off the road'... sort of like you don't have to be concious of it. I can get on this bike and motor away for hours happily and comfortably. In cornering, it has what the NASCAR community would describe as a "push." Lean into a sharp corner, you feel like the bike wants to straighten out again. I'm not comfortable 'pushing the envelope' on this bike through sharp turns.
The R3000 is nimble. Analogous to a sports car. The handling is significantly better than any of my other two bikes. A long descent at 50mph, the bike is rock-solid... no resonant vibrations. Lean into a fast turn, it stays neutral, it gives me confidence to take the turn faster next time. It's more comfortable in fast groups, because the handling responds faster. You *do* need to pay attention to where you are going, but it's not like it's a problem. It's all good, so the handling is nimble, not twitchy. Stable, but lively. This bike is wayyyy light, and the ride is plush, which help make it fun and invigorating to ride. But, this bike, more than either of my others (past or present) is designed to have the rider further forward, weight more centered. That probably helps the handling. It's also a downside for me, since it requires more front-of-the-leg strength. I prefer a balance of front, back, and glutes, which I get from the Classic.
I guess what I'm getting at is that I think stability can be had in any geometry... it's not just a matter of, e.g. wheelbase. My preference? Well, the Classic and the R3000 get about equal time. If the RB-T were a better execution of it's design, who knows, maybe I would find more recreational uses for it as well.
Treking
Bikes: Trek 520, Schwinn Le tour luxe, Schwinn High Plains, Sakkit Expedition signature.
Having been touring for 30+ years on only two bikes, (1st is a Schwinn Le Tour Luxe, and 2nd is my current Trek 520) I haven't been plaqued with bike stability, only BODY stability. i have learned that the body posture is paramount when fully loaded touring, when we tour (wife and i) i usually carry the heavest loads (anywhere from 55-70 lbs) and here in NC we do the Blue Ridge Parkway every other year in segments. On the downhills (mountains) where speeds can approach the TDF speeds you have to be always on guard of your body posture on the bike on the downhills, ex. leans on the curves, down on the drops for lower center of gravity, etc... Not once have we observed wobbles or shimmys that others have described. I deffinetly disagree with the idea of taking your hands off the bars when your touring or for that matter anytime because of unexpected road hazzards. When we're on the flatlands the same is true, the bikes are always comfortable. This is just a tourers point of view, we're not racers, and our bikes are set up much differently.
hors category
Quoted: 8 Post(s)
Liked 5 Times
I don't believe there is a universal definition of stability since it depends on how a bicycle will be used and what a given rider "expects" in terms of how a bicycle should handle throughout the speed and cornering envelope.
Some riders will define a bike as stable based on its slow-speed handling characteristics whereas others have a bias towards high-speed handling characteristics. Therefore, good or bad is relative. And, of course, what constitutes stable for an off-road bike may be of little consequence to a road bike, just as much as what is stable for a comfort or leisure bike vs. a road bike optimized for criterium racing.
All that said, I define bike stability as being what works best for each individual rider. If a bike "spooks you" with the way it handles then it is not "stable" (generic). I have been "spooked" by bikes at both slow speeds and high speeds.
My preference is for having road bikes that handle more predictably when ridden in an aggressive manner; slow speed handling can be mastered with experience. The same cannot be said for a bike with a lot of understeer at high speed.
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
stable = slow steering
i can bomb down my local hill at 50mph without the fear of death in me... like on my old 87 Trek 400
my fuji is more sensitive to steering input... seems like steering is more sensitive... gotta concentrate on keeping the bike straight or kerplow
Evil Genius
This is all good stuff. Gotta keep them brains a burnin if Anyone thinks of a better way to describe their prefered or dreaded handling then feel free to post again. I'm trying to get to the base of how the different veiws of stability affect handling.(I think... I don't feel tired but I haven't had a lot of sleep either.)
Yes yes good point. I'm not looking for a universal definition, but rather what different folks "expect" stable or good handling to be.
So what, this is general cycling. MTBs need to handle well too.
Originally Posted by livngood
I don't believe there is a universal definition of stability since it depends on how a bicycle will be used and what a given rider "expects" in terms of how a bicycle should handle throughout the speed and cornering envelope....
Originally Posted by jukt
Trek 4900 is a MTB, Dude.
Differant animal.
Differant animal.
無くなった
Bikes: I built the Bianchi track bike back up today.
Mines pretty stable, but it is really nimble, too. That's the nice thing about track bikes. I like that I can just zip around anything with a really brief turn of my wrist. It tends to stay upright through the corners, which is good because I can't stop pedaling through the turn. I can bring it almost all the way to a stop no-handed, too...
Don't know if that helps much...
World Champion, 1899
Bikes: Litespeed Vortex
You had better be very careful taking your very first turn, at speed, on it. You're likely to find yourself headed straight for the inside curb. Again, you think it will turn later, but it turns NOW! However, there is not another bike I trust as much going downhill through sharp switchbacks. The sharper the switchbacks, fewer and fewer riders will be able to follow its line. (I love downhills!) My bike goes exactly where I tell it to go. It will take that last millisecond correction without any negative consequences.
So, is my bike stable? I think so. A less experienced rider would probably think not. Is my bike twitchy? One of my instructions to its builder was: "Build me a bike just short of twitchy." They could not have done a better job. My bike is stable, but only if you like a very nimble bike.
Bikes: trek - lemond
Differant animal. Sorry, but they are not the same. Steering is differant, Genuis.
So, well is a universally deep subject.
Try riding a MTB with no hands off road, please ?
Say you will.
Say you will.
Evil Genius
Say you will.
Say you will.
This is general cycling. For good reason, I did choose here, to put this thread. It's not a road bike thread, it's not a 'no handed' thread. That mostly road bikers replied, is just happenstance.
Now get out of my thread if your going to be a beatle headed chode eater.
kipuka explorer
Bikes: 1994 Trek 820, 2004 Fuji Absolute, 2005 Jamis Nova, 1977 Schwinn Scrambler 36/36
-=- '05 Jamis Nova -=- '04 Fuji Absolute -=- '94 Trek 820 -=- '77 Schwinn Scrambler 36/36 -=-
Friends don't let friends use brifters.
Evil Genius
Originally Posted by bkrownd
Labels, labels, labels... There's a whole spectrum of bikes out there. Isn't this issue relevant to all of them?
Now thats the end of that. Lets all get back to issues of countersteering, osillations, and sub trans-sonic fluid flow. or something of that nature.
Maybe somefolks will be willing to describe their prefered handling in terms of the forces they experiance rather than generic terms like neutral or push or understeer.(Try it, it'll get ya pondering for sure.)
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
I think people define stability differently because there are different axis of stability. In the world of aviation, dihedral angle of the wing effects roll-axis stability of an airplane such that when something causes it to roll away from its neutral position, it will attempt to right itself by side-slipping in the direction of the lower wing. This causes a lateral flow across the wing and thus produces an increase in relative lift because the dihedral forms a positive angle of attack relative to that lateral flow. The lower wing will then rise until the relative lift is equalised. For a "stable" bike, much the same thing should happen. The bike should try to resist movement about the vertical plane (parallel to the angle of the wheel) and hold its roll-axis such that with no steering input, it will not want to increase or decrease its angle to the road. Likewise, stability in yaw can be thought of as the bike's tendency (assuming once again a neutrally stable bike) to not want to steer itself such that the front wheel will have a tendency to try and track the longitudinal forward vector of the bike's motion rather than the other way around. Both of these forms of stability, while independent, are also tightly coupled and tend to effect the overall stability of the bike.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Evil Genius
DEADBEEF
Liked 6 Times
You make it to hard. Dihedral makes an aircraft stable do to the lift force vectors of the wings' relative to the center of gravity and to a lesser extent by raising the center of lift relative to the cg. In a roll the lower wing has more horizontal area and thus resists the pull of gravity better than the upper wing.
Side slip will have negligable effect and will actualy have a slight destablizing effect if the roll angle exceeds the dihedral angle, which is most rolls as dihedral is only a few degrees normally.
(Highwing planes don't need positive dihedral because c of lift is higher than c of g, some even have negative dihedral because they are too stable, like c-17 cargo planes.)https://www.edwards.af.mil/gallery/ht.../c17-1_072.jpg
You forgot that it needs adaquate resistance to harmonic low frequency vibrations in the steering assembly within the operational envelope of the bicycle lest it suffer the wrath of the head shake and shimmy dance.
