bicycle chain and rust
Old 10-23-10 | 09:42 PM
hey you guys, my bicycle chain just got a little rusty and i sprayed it with wd40 however, i then found this link https://bicycletutor.com/no-wd40-bike-chain/
should i not use wd40?
if not, what should i use? ...im sort of in the middle of a tour right now and am in the middle of nowhere in a grocery store...all they have is automotive oil...should i use motor oil?
burningredphoen is offline
Reply
Old 10-23-10 | 09:53 PM
AEO's Avatar
AEO
Bikes: Bianchi, Miyata, Dahon, Rossin
you can use anything, that's an oil, really.
for WD-40, you just need to apply it very frequently, since it doesn't leave a lot of oil to protect the metal.
you could use 10W30 or a lighter engine oil straight, but they're toxic and don't come in a bottle size you'd want to carry around on a tour.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
AEO is offline
Reply
Old 10-23-10 | 09:57 PM
what about cooking oil...im in the store right now and they have alot of that for cheap.
Reply
Old 10-23-10 | 10:10 PM
AEO's Avatar
AEO
if you don't mind the fact that it'll go rancid after a while, sure, that'll work.
AEO is offline
Reply
Old 10-23-10 | 10:31 PM
lol
ChrisENC is offline
Reply
Old 10-23-10 | 10:32 PM
Go with the motor oil.
Mondoman is offline
Reply
Old 10-23-10 | 11:00 PM
Ira B's Avatar
Bikes: 84 Raleigh Technium- 89 Shogun Mt. Bike-96 Miyata 914
Don't use WD-40 except as a cleaner. It is too thin and will simply wash away any oil that is already there.
Don't use vegi oils. They not only turn rancid quickly but also get gummy and will hold onto every speck of road grit and shorten chain life.
Motor oil would work well. Use plenty of it, then plenty of paper towels to remove as much from the outside of the chain as possible.
Ira B is offline
Reply
Old 10-23-10 | 11:17 PM
AEO's Avatar
AEO
WD-40 leaves a very thin film of oil. WD stands for "Water Displacement".
It's very thin and doesn't have the same sticking power as thicker oils, that's why you have to apply it very frequently.
AEO is offline
Reply
Old 10-24-10 | 01:12 AM
Bikes: 8
Then again if you over run the runway at NY JFK airport and end up in Jamaica Bay
using gallons of WD 40 will keep you from nessisarily buying 4
complete new pratt and whitney jet engines.
fietsbob is offline
Reply
Old 10-24-10 | 03:35 AM
Bikes: 2006 Trek 7.5FX, 2010 Trek 7.3FX, Nashbar Cyclocross
Motor oil . Then again if the OP is still at the grocery store, he has other problems.
USAF1C1X1 is offline
Reply
Old 10-24-10 | 04:55 AM
20 Anniversary
You can usually salvage enough oil from a discarded engine-oil container to treat a chain. Add a squirt of WD40 to gear oil to help it flow better.
MichaelW is offline
Reply
Old 10-24-10 | 05:42 AM
Bikes: Trek Madone 5.5, Klein Q Pro Elite, Surley LHT
Wake up guys. Or is all above in jest? DO NOT use WD-40. As has been stated it is a water displacement. Basically a solvent, very good for cleaning not a lube. Get a specific chain lube. My preference is a dry lube or a waxed base type. These are formulated for chains ant as a cooking oil.
kycycler is offline
Reply
Old 10-24-10 | 06:01 AM
rumrunn6's Avatar
15 Anniversary
Community Builder
if you're on tour you'll eventually pass a bike shop so stop in and get some proper chain lube. in a pinch - use the motor oil.
rumrunn6 is offline
Reply
Old 10-24-10 | 07:25 AM
JonathanGennick's Avatar
Titanium Club Membership
15 Anniversary
Bikes: Priority 600, Priority Continuum, Devinci Dexter
I'm w/rumrunn. Use motor oil for now if that's all that's available. Pick up some bicycle-specific lube when you have the opportunity.
FWIW, I usually apply oil, run the chain backwards a bit, maybe let it sit a bit, then wipe off as much as I can from the outside of the chain. Enough will generally stay behind to protect from rust.
JonathanGennick is offline
Reply
Old 10-24-10 | 08:13 AM
JanMM's Avatar
rebmeM roineS
20 Anniversary
"if not, what should i use? ...im sort of in the middle of a tour right now and am in the middle of nowhere in a grocery store...all they have is automotive oil...should i use motor oil? "
If that is your situation and you are limited to what is in the grocery store, then go with the WD40 - spray and wipe daily. I'm thinking that a small spray can of WD40 is smaller/lighter than a qt of motor oil.
You might find White Lightening lube in a WalMart.
JanMM is offline
Reply
Old 10-24-10 | 08:49 AM
Retro Grouch's Avatar
20 Anniversary
Oh yuck!
I agree with the part about removing as much from the outside of the chain as possible. "Use plenty of it", not so much. It only takes the tiniest drop that you can manage on each link. Give it a while (15 - 30 min) to migrate into the innerds of the chain and then wipe away as much as you can.
Retro Grouch is offline
Reply
Old 10-25-10 | 06:54 AM
rogerstg's Avatar
Fred-ish
FWIW, even most grocery stores have 3in1 oil. The original special purpose bicycle chain oil. The container is small enough to pack.
rogerstg is offline
Reply
Old 10-26-10 | 08:38 AM
Duo
Bikes: The Good Book of bicycling
Anyone use penetrating oil?
I am thinking of PB blaster or maybe a generic penetrating oil. It could also be used for cleaning too.
Personally i use a home mix of mineral spirits and gear lube. To clean i brush on mineral spirits and wipe.
Duo is offline
Reply
Old 10-26-10 | 02:22 PM
Oostal's Avatar
still climbing
Bikes: vintage steel bikes
I'd rather ride another 100 in the tour until I eventually find a bike shop than buy 1l of motor oil and then figure out what to do with the rest of it as it would be a pain to carry.
Oostal is offline
Reply
coolkid_cody
Bicycle Mechanics
52
04-16-21 06:16 AM
ben4345
Bicycle Mechanics
20
09-11-13 02:09 PM
one-headedboy
Bicycle Mechanics
12
03-15-11 09:42 AM
kmcrawford111
Bicycle Mechanics
38
03-04-10 10:12 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
