What's a good pump that's not a Topeak?
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
I bought a Topeak DX Master Blaster about a year and a half ago, and used it about 3 times before this morning when I wanted to use it to replace the air pressure in the rear tire it lost on the way in. I couldn't get the pump to work, and when I called Topeak customer service they told me I needed to buy a rebuild kit. Even when I pointed out the pump was about a year and a half old and had been used a handful of times. Paying $5 to rebuild a $20 pump that only worked a handful of times doesn't appeal to me, I'd rather buy something that's going to work better and last longer. What would you recommend?
Quoted: 3375 Post(s)
Liked 5,513 Times
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Unlisted member
Liked 432 Times
I also forgot to ad I'm riding a commuterized mountainbike, 60 psi will do it for the 26x1.5 tires I use.
Hello
I had an identical experience with the coveted morph. Never again will I buy Topeak.
I was just about ready to buy a lenzyme when I got my Morph re-pumping with a new o-ring from an Autoparts store.
After multiple auto parts stores including all LBS and Todson, I found a slightly oversized o-ring that was for refrigiernt that worked. for 99 cents.
Todson wouldn't even sell me a $15 rebuid kit until they diagnosed my pump over the phone during there working hours.
https://www.silcapompe.it/index_en.htm
for at home:
https://www.silcapompe.it/pista_en.htm
I have 20 year old Silca track pump for my presta valve types
for at home:
Quoted: 3352 Post(s)
Liked 1,056 Times
The Bontrager pump I have is 5 years old and working fine. The air gage is at the top and the hose is is fairly long and easy to use.
Quoted: 45 Post(s)
Liked 12 Times
I've come to the conclusion that bike pumps are all universally crap largely made in China these days, and you should buy the cheapest one on sale at Nashbar and regard it as a consumable that will get replaced in a couple years.
I had a great dual-chamber Zefal for about 25 years and was disappointed that I couldn't get parts for it when it finally needed servicing, and ended up getting a top-of-the-line Silca for like $60+ made in Italy, thinking it was going to last the rest of my life, and that any parts would be available. Sent the first one back after it stopped pumping air which I thought was sort of a negative thing for a bike pump. The second one wouldn't pump air after about 6 months. Construction quality was trash. I kept the nice presta valve attachment from the Silca and the rest went into the nearest trash can. I've been using el-cheapo Nashbar pumps ever since. When the original valve attachment wears out, which is usually pretty fast, I use the old Silca valve attachment. When that wears out, they actually have replacement parts for that.
wannabe
I've had good luck with SKS Rennkompressor. Six years of 1-5 uses per month and still going strong. Have had to replace the head a few times. The new ones were supplied free from SKS USA. Sorry to hear Todson isn't working out to well. I needed replacement parts for a road morph and they were mailed free after an email exchange.
Bikes: All 70s and 80s, only steel.
I love my new Lezyne steel shaft floor pump; far superior to the Topeak Joe Blow I used to use. I also have a bunch of Zefal frame pumps, all of which work wonderfully at 20+ years old.
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 704 Times
I have a Blackburn floor pump that's worked fine for 3 years, since I got it at a Christmas gift exchange. I also have a Topeak Morph pump that's lived on my bike for 4 years. I got a flat yesterday (first one in months) and it worked perfectly. My only problem with it was that my crappy eyes couldn't read the inline gauge.
Jeff Wills
Jeff Wills
Retro-guy
Bikes: 1980 Raleigh Super Record
https://www.lezyne.com/products/hand-...ure/road-drive
(The above is for a "carry on bike" pump. My home pump is a "Hurricane" model from Performance that I got at a really good price - it has a red barrel, and is unusual in pumping up to 260 psi. My thinking was that if it could do that, it would probably be pretty robust and trouble-free when only used at 125 psi or so...)
Bikes: 2020 Veego 750, 2011 Specialized Roubaix Elite, 08 Trek 7200, Very Old Schwinn Cruiser
Quoted: 5 Post(s)
+1 on the Lezyne Road Drive. I have one and the internally storing hose made this a winner for me. Useful, will not snap your valve and it is invisible.
Quoted: 38 Post(s)
Liked 11 Times
Zefel HPx3 if you can find one or the newer HPX - If you have an old Zefal pump,don't throw it away,rebuild parts are available online from Zefal.
Unlisted member
Liked 432 Times
It's been about 5 years since I've been bicycling again, and I've been really lucky with most of the stuff I've bought in that time. I've got a few things I've used that I've kind of "outgrown" to help me get to where I am today, stuff like some lights that aren't bright enough for the faster speeds I'm able to ride at now and the first saddle that felt really comfortable. Stuff that I could recommend with confidence after mentioning how what's better today might not be the right thing later. These Topeak pumps are the only purchases I've made that have been bad enough to recommend avoiding.
Palmer
Quoted: 1663 Post(s)
Liked 1,817 Times
Note: you gotta check these things out on a regular basis at home between rides. I wonder how many times over the years I've stopped to help another cyclist who had a pump - that didn't work - or a spare tube - that had fold cracks - or a patch kit - with dried out glue-tube/patches?
Palmer
Liked 1,817 Times
I've joked for many years that I carried a Topeak Road Morph G on my tandem because - due to its pseudo-floor pump design - it's the only pump I'd found that my stoker could get a tire back up to pressure with.
Seriously, in the real world of roadside repair a lot of the little mini carry along pumps can't get tire pressure up out of pnich flat range.
That Lezyne Micro Floor Drive HPG looks promising.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Can't go wrong with the Zefal's HPx aluminum frame pump. I had mine that worked flawlessly for over 20 years till I lost it a year ago. The pump has been unchanged since the mid 80's and is still available in better bike shops. I found it to perform much better than newer frame pump I've ecnountered in the recent years on easily inflating HP tires.
Chombi
Chombi
Quoted: 802 Post(s)
Liked 704 Times
After my flat Sunday I was checking my patch kits at home (it was threatening rain when I was riding, so I threw in the spare [uncracked] tube and got gone). I checked the primary kit: dried up glue. I checked the back-up on-bike kit: dried-up glue. I dug out the spare kit from the back of the bike stuff bin: yep, dried-up glue. Sigh... although it's kind of nice to not get flats frequently enough to need patch kits.
Jeff Wills
Jeff Wills
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
17yrold in 64yrold body
One thing I do that might help is service the working parts of my pumps. A little strategically placed grease does wonders for their longevity.
what is wrong with using puncture resistant tyres and tubes? no need tocarry a pump then.
I have the michelin pro race 3 tyres on my road bike and they have proved to be bomb proof. I started using them on my mountain bike last year after gettng two flat tyres on an off road trail and ended up walking home which was about 60 miles, I had no repair kit, no spare tubes and no pump. I was on a trail only used by cyclicts, dog walkers and horse riders (on a seperate track at the side) I never even thought I would get a flat on there let alone two, so hitting a patch where someone had smashed a bottle in the middle of the path was very unexpected.
I had no spare tubes anyway so I had to buy new tubes and tyres after mine were pretty cut up. I was also looking at buying a few spare tubes and a pump instead of a repair kit, I don't really trust repair patches. so I ended up getting puncture resistant tyres and tubes and I have never had a flat since.
in reply to badamsjr, I second the Joe Blow floor pumps, I have the sport.
they are well built and the gauge is very accurate, upto 160 PSI.
all in all, a very good pump.
