steel vs aluminum 20" wheel
Old 10-26-10 | 07:19 PM
How much weight can i save if I replaced the Raleigh Twenty steel rim with aluminum rim?
And would the baby jogger 20" rims work? A little concerned since they say child should not exceed 70 lbs.
For those who mod their Twenty, where is the greatest weight savings if not the rims.
cyclingd is offline
Reply
Old 10-26-10 | 09:49 PM
AEO's Avatar
AEO
Bikes: Bianchi, Miyata, Dahon, Rossin
quite a bit.
I think the steel rims from an R20 are about 1kg each.
the entire thing is quite heavy. Aside from rims, you can save weight by not using the SA-3sp hub, another 1.5kg alone, seat post, saddle, handle bars and cranks.
the stock parts are almost all steel, so changing any of those to an aluminum part will save weight greatly.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
AEO is offline
Reply
Old 10-27-10 | 03:53 AM
wahoonc's Avatar
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Not sure, but I am sure the rims add up, along with all the other steel parts. I swapped out the stock steel seat post for a Kalloy, but I suspect the savings weren't that great because I had to get the 400mm Kalloy.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"
_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"
_krazygluon
wahoonc is offline
Reply
Old 10-27-10 | 08:08 PM
folder fanatic's Avatar
I just swapped out the original steel rims on mine. It seem a bit lighter, but the real crucial reason why I did this upgrade soon after my Twenty's purchase was improving braking paired with the Kool Stop Continental Brake Pads. The rest of the bike has the original parts as these parts appear superior to what's available in my price range.
folder fanatic is offline
Reply
Old 10-27-10 | 11:38 PM
Agreed. There's no great need to replace the bars or seatpost.
But moving to alloy wheels will make a Raleigh Twenty handle better, particularly in wet weather.
NormanF is offline
Reply
Old 10-28-10 | 05:49 PM
social suicide's Avatar
15 Anniversary
Because the rims are rolling, the lighter the better. Alloy rims are also stronger. I bought a beat up but high quality BMX bike at a police auction for $8.00 and swapped the rims to my twenty. Make sure that the rims you get are 36 hole. I was lucky my stock spokes fit some rims are double walled and new spokes of a different length might be needed.
social suicide is offline
Reply
Old 10-31-10 | 06:07 AM
SunnyFlorida's Avatar
Bikes: Sun Miami Trike - 2007
I'm almost finished with Sybil's (my R20) redo. I opted to keep the steel wheels. I did buy the Continental Kool Stop brake pads. Please tell me it will do the trick for stopping?
I expect my R20 to be heavy since I opted to keep most of the original parts. The only exception has been the handlebar, stem and pedals (those original pedals do weigh). I think I'll get an alloy seatpost and hopefully a lignter Spring (Sprung?) saddle.
SunnyFlorida is offline
Reply
Old 10-31-10 | 06:57 AM
wahoonc's Avatar
Yep the Kool Stops will do the trick. I run them on several steel rimmed bikes. One trick is to wipe the rim braking surface and pad surface down with an alcohol wipe every now and again to keep the braking up to par. They to take a bit of time to break in, but once they have been used a bit they are a huge improvement over the OEM stuff.
Aaron
_Nicodemus
_krazygluon
wahoonc is offline
Reply
Old 10-31-10 | 12:11 PM
randya's Avatar
20 Anniversary
Bikes: who cares?
the original brakes that came with R20s work equally crappy on steel or aluminum rims, with or without salmon kool stop pads. the only improvement aluminum rims will make with braking using the stock brakes is a slight improvement in wet weather stopping power, which is just about zero with the steel rims, so any change is an improvement.
randya is offline
Reply
Old 10-31-10 | 05:16 PM
Schwinnsta's Avatar
Schwinnasaur
15 Anniversary
+1
I found the same thing. I switched out the pads first. Not much difference. I put on aluminum rips. Still not a lot of stopping power. I finally added a modern V-brake on the front and now the stopping power is adequate.
If I had it do again I would switch to 451 rims and duel pivot long reach brakes. I did not go in this direction before due to the greater availability of 406 tires.
Schwinnsta is offline
Reply
uncle uncle
Classic & Vintage
154
10-30-18 11:22 AM
David Bierbaum
Bicycle Mechanics
26
07-23-14 08:26 AM
aetius
Classic & Vintage
25
02-04-12 09:30 AM
GoatHead73
Classic & Vintage
6
05-08-11 12:39 PM
chico1st
Bicycle Mechanics
12
04-29-11 06:34 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
